Like Tree4Likes
Viper RC -
Old 01-06-2014 | 02:14 PM
  #9676
silvalis's Avatar
Originally Posted by nikos2002
For the EPA 100 or 150 question -- 100 will give you the linear feel the software is designed to work within. 150 (you set it to 150 and then calibrate your esc) will make it feel softer throughout the throttle throw, because you are traveling a longer distance with the trigger to full throttle. Maybe with a low turn mod, it might make it different to drive, but under most circumstances I would stick with the 100, as designed.
What? On what radio does adjusting to 150 EPA give you a physically longer throttle throw???
silvalis is offline
Old 01-06-2014 | 05:17 PM
  #9677
Originally Posted by jkas10
Rheal,
180 degree turns on a medium size indoor track. You will be fine running a 15 tooth. That is safe. Always check temps a few minutes into a run to ensure all is good. Also, remember to practice no longer than your main event. If you run a 7 minute main, then practice for 7 minutes at a time. Ensure you never run a battery pack all the way down to low voltage cutoff as that is not good for your battery and the additional run time may allow your motor and esc to continue to generate too much heat, causing a premature end of life of your electronics...
Have fun!
Jkas10,
Thank you for all the advise. I will follow it and do my best to track temps and not run until I hit the cutoff.
Rheal
Dubreuil is offline
Old 01-06-2014 | 08:04 PM
  #9678
If a capacitor fails on a VTX series speed control, what happens to the speed control?
I ask because I just recently has to speed controls shut down mid race in my 22sct and not restart. When the 1st one died I soldered in my spare, I reused the capacitor (http://www.shopviperrc.com/ProductDe...ode=6VSPCAP005). I'm going to try to solder in the old capacitor but I'm doubtful. The 1st speed control ran the capacitor for 3 months.
Any other things to brainstorm as to why the speed control might just die mid race? I'm going to toss the motor, just-in-case. The motor is almost a year old, no overheats though.
Edit: Makes me wish I purchased more then one VTX10r from the Black Friday deal.
thefatkid is offline
Old 01-07-2014 | 06:42 AM
  #9679
nikos2002's Avatar
Yes, the trigger only travels so far -- but if you increase the end point adjustment it changes how the esc will react to the every little application of the throttle. If the EPA is too high, it might make you feel like you have the pull the trigger more, to get a reaction from the motor. Conversely, if you lower it, it will feel like a "hairpin" trigger.
nikos2002 is offline
Old 01-07-2014 | 06:44 AM
  #9680
DustinH's Avatar
Exactly. At 150% calibration 1% is more like .75%.
DustinH is offline
Old 01-09-2014 | 11:08 AM
  #9681
nikos2002's Avatar
Good Luck to everyone running Viper products this weekend at CRCRC Mid West Champs in OH. I spoke with a couple guys already getting set up and everything last night and this morning. Look around - JP Richards, Paul Sinclair, Bob Barry, Mark Samuelson and more!!!!
Old 01-09-2014 | 11:11 AM
  #9682
nikos2002's Avatar
I have seen unit stop because the cap came off, I have seen other run. It shouldn't run if it comes off. Generally unless there is some other type of problem, a replacement can be solder on. Make sure to use the Viper capacitor for your unit. Cap sets from other speed controls may not have the proper values to use as a replacement.
Old 01-10-2014 | 09:10 PM
  #9683
pumpkinfish's Avatar
Need some help with gearing with my Vtx10/17.5 setup. I am running a RC10 T4.2 with a FDR of 5.48 mid timing on end bell and blinky mode on esc. It had no pop. It felt flat and I really had to concentrate and keep momentum up. Track is a small indoor carpet with the fast guys running 17/18 second laps in their buggies.Motor was temping between 150 and 160.
pumpkinfish is offline
Old 01-11-2014 | 06:44 AM
  #9684
silvalis's Avatar
Ok, question.
How many bits does the ESC sample the throttle signal at? And during calibration is full throttle on the tx (at whatever pwm full throttle on the tx is) mapped to the highest number of bits? ie, if it's 8 bit, is whatever is calibrated as full throttle equals 2^8?
silvalis is offline
Old 01-11-2014 | 11:14 AM
  #9685
MaplestreetRC's Avatar
Pumpkin, all signs point to you being over geared. Recommended FDR for 1/10th truck is 7.0 with 17.5. On carpet you could probably take that down into the 6is but I would start your gearing around 28/75. To give it
Even more "pop" turn off your deadband and adjust your throttle pwm down to around 4000.
At this point you are over geared so the motor can't spool up to its optimal RPM which is why you have less low end and high temps.
MaplestreetRC is offline
Old 01-11-2014 | 11:15 PM
  #9686
Building an SC10 4x4 right now. Will be running the Exotek chassis. The chassis weighs about 140g more then stock. Trying to decide on a motor and esc. I had a 4000kv Tekin Pro4 in my SCTE and hated it. It was too much torque and hard to control. I want something smoother. Race on a medium indoor track about 15 second laps. Trying to decide between:
VTX10R or VTX8
and
VST 4.5 XL or VST 5.0 L
I run a 7.5 wheeler and 8.5 in 2wd buggy. Just not interested in 4 pole. Thanks.
chevmaro is offline
Old 01-12-2014 | 07:41 AM
  #9687
Cain's Avatar
Tech Legend
I would suggest the VTX8 ESC personally.
Standard 2 pole 550 motors in general feel like they have less torque than the 4 poles.
You may like one of those.
Cain is offline
Old 01-12-2014 | 02:17 PM
  #9688
shanwright's Avatar
Smile Vtx1 question
Hi guys,
I'm thinking of trying a VXT1 in my 1/12 scale.
Any feedback about the results you guys have been getting.
Question? I see the specs say up to 5.5v on the bec.
Is this true? Can it go higher?
My current speedy's spec says 6v.
Looks like a very nice speedy
Steve h
shanwright is offline
Old 01-13-2014 | 12:35 PM
  #9689
nikos2002's Avatar
Steve,
VTX1 is 2 time and current defending ROAR National 1/12 17.5 class winner -- to mention performance possibilities.
Yes the SBEC is rated at 5.5v, would mean you might use slightly different dual rate or expo, wouldn't be a huge difference overall. I have used it in my 1/10 buggy and didn't notice difference between 5.5v and 6.0v from my VTX10.
chevmaro - I agree with Cain - VTX8 for anything 4wd SC. will run the VST XL motors easily. Using a VXT10R would be making it work at the maximum of its performance range, it could do it, but the VTX8 would be safer overall.
Old 01-13-2014 | 05:04 PM
  #9690
VTX10R or VTX8
and
Chevmaro, I ran vtx10r with the 4.5xl for awhile with no issues however... really need to watch the temps because they can creep up depending how hard your running it (size of track and time of the race). I decided to take the worry of overheating and got the vtx8 and ran w/4.5xl. No issues and still quick with the right gear.
urluzn is offline
