Like Tree4Likes
Viper RC -
Old 01-06-2014 | 03:54 AM
  #9661
Wildcat1971's Avatar
I have heard of people having issues with over 100% on radio. Since your esc cant go over 100%, why would you calibrate it at 150%?
Wildcat1971 is offline
Old 01-06-2014 | 04:25 AM
  #9662
I can't tell you that you shouldn't go over 100%. But I do know that I set mine at 100% and I don't have issues. I am a firm believer that we should be setting it at 100% but I have no scientific data to say one way or another.
Bob Barry is offline
Old 01-06-2014 | 05:23 AM
  #9663
DustinH's Avatar
Yep, racing at 150%. Makes throttle even smoother.
DustinH is offline
Old 01-06-2014 | 05:31 AM
  #9664
rob martin's Avatar
I tried setting my EPA at 150% awhile back. What I got in return was full throttle at about half throttle on my radio(no fun)
rob martin is offline
Old 01-06-2014 | 08:02 AM
  #9665
Cain's Avatar
Tech Legend
I know this is more about onroad but this was interesting to me at least:
Originally Posted by DARKSIDE
...Tekin Viper Reedy and others want to be part of the USVTA, but we have to make sure there isn't going to be an esc war....
So, what do you guys have up your sleeve??
Cain is offline
Old 01-06-2014 | 08:03 AM
  #9666
Cain's Avatar
Tech Legend
Cain is offline
Old 01-06-2014 | 11:24 AM
  #9667
Need some help with my combo. I am running a axial exo with a Viper vx4r.45 combo, JR 9000S servo. Gearing is 15/52. Radio is the stock Axial RTR unit. I just upgraded from a Hitec 5645MG (stripped servo gear) and the Viper VX4.39 which was running 16/52. Witht he new set up it seems I am having "brown outs" but I want to be sure. I drive away and once it a bit, I lose all control and response. I can walk over to vehicle, and drive again no problem until I get a distance, and same thing happens. I have not installed a glitch buster yet, just want to make sure I am experiencing a "brown out". My lipos are 30c 2s units. Settings on esc are profile 5. Never had this issue on the old set-up.
NorCalLump is offline
Old 01-06-2014 | 11:38 AM
  #9668
sounds like your running out of radio range. browns are typically a partial or complete loss of steering while accelerating.
Old 01-06-2014 | 12:15 PM
  #9669
I thought that too, but it seems odd that this never happend with the previous system. Think this happens at maybe 50ft.
Old 01-06-2014 | 01:40 PM
  #9670
nikos2002's Avatar
The 4 pole motor in the Copperhead system may be pulling more voltage than the battery or receiver can handle. especially if you are using NiMH batteries.
nikos2002 is offline
Old 01-06-2014 | 01:44 PM
  #9671
nikos2002's Avatar
We don't have anything up our sleeve directly. From my understanding depending on the area of the country you live and race in the USVTA is strict about what the esc software can do. The market world wide for an esc that will not have a boost option is small, most parts of the world encourage boosted set ups, so our esc's are capable. Yet, we have legal blinky systems (no "special" software, or trick lights), but in some places that isn't considered USVTA.
Old 01-06-2014 | 01:47 PM
  #9672
nikos2002's Avatar
For the EPA 100 or 150 question -- 100 will give you the linear feel the software is designed to work within. 150 (you set it to 150 and then calibrate your esc) will make it feel softer throughout the throttle throw, because you are traveling a longer distance with the trigger to full throttle. Maybe with a low turn mod, it might make it different to drive, but under most circumstances I would stick with the 100, as designed.
  #9673
since the viper 1/10 motors were not allowed to be run at the worlds, are there plans to revise the motors to prevent the issue in the future?
Old 01-06-2014 | 01:48 PM
  #9674
nikos2002's Avatar
Originally Posted by Kevin_M
Nick what is the length of the sensor wire that is sent out in the VF8 motors?
Believe its 120mm.
Old 01-06-2014 | 02:03 PM
  #9675
Thats something along what I was thinking Nikos. I am only using "30C" lipos. Time to step it up...
