Like Tree4Likes
Viper RC -
Old 06-14-2013 | 02:43 PM
  #8161
Originally Posted by tony montana
I can say I seen his car running saturday, He is running a b4.2 just like me and has the stock spur and a 23 tooth pinion. Im running the vtx10 and the vst 8.5 motor and I also run the same car and gearing as him and my esc and motor were much cooler than his. And he is using the vtx10r and the 7.5 motor. That is the only difference. His car would shut down after running for just a few minutes. It wasnt hot outside either, prob 80. I do not know his settings, but Im running blinky, not sure if he is or not
That gearing is fine. Just venturing a guess. Switch to blinky and switch off the motor temp cutoff built into the ESC. Most people forget that the temp is measured off the sensor board internally so it's much higher than an external temp. 150 externally might be 220 internally. That's why I disable it.
Bob Barry is offline
Old 06-14-2013 | 04:55 PM
  #8162
nikos2002's Avatar
I would not think a 2wd car would get that hot, even with a 7.5. something with the settings -- maybe boosted with a high slew rate (that causes a lot of heat).
nikos2002 is offline
Old 06-14-2013 | 10:46 PM
  #8163
H0LESH0T's Avatar
Originally Posted by Bob Barry
Sorry if I missed it, but which car, motor, ESC, and profile on the ESC?
Things that will help:
lower the throttle freq (PWM)
increase the punch
make sure forward power is turned up
adjust gearing / slipper (if applicable) properly
Also we will be releasing more info on the new Pro 9 caps soon too
Thanks will give them a try.
Motor: 2100kv
Battery: 4S 5300 30C
Gearing: 14/46
I do have extra pinions but was considering changed some settings before going up a tooth.
H0LESH0T is offline
Old 06-15-2013 | 07:27 AM
  #8164
trx498r's Avatar
Why does the vtx8 not hold neutral position? After programming Neutral, fwd, rev everything zeroed a couple races later after not touching the trim it will be blinking red or orange then I have to throttle trim either way to get power back.
trx498r is offline
Old 06-15-2013 | 10:20 PM
  #8165
picco007's Avatar
Hey everyone, I'm in the process of getting a new speed control for 1/10 stadium truck or 1/10 buggy running an 8.5 motor or lower. Which Viper speed control would be best for that application? I see that there is a black edition and both of the VTX10 versions have R as well, what does the R mean? I would also like to get the proguage with it but I also see the ezlink and the ezlink comes with certain speedos. I'm thinking about an orion R10 but not sure about the setting box and it's features compared to the Viper set up. Please let me know your thoughts. Any help would be appreciated.
Ronnie
picco007 is offline
Old 06-15-2013 | 11:49 PM
  #8166
84 GT 5.0's Avatar
has anyone ran a vx4r 4500 combo in a 2wd st ? im looking to build a basher for 2s and occasional 3s speed runs in a rustler and want it to run stone cold and be fast. I like the fact that the esc is water proof and i already have the progauge for my other 2 vtx10r in my other cars
84 GT 5.0 is offline
Old 06-16-2013 | 12:47 AM
  #8167
hey niko can you reaply to my email plz mate or pm
RavensNightFury is offline
Old 06-16-2013 | 12:51 AM
  #8168
silvalis's Avatar
What radio are you using?
silvalis is offline
Old 06-16-2013 | 01:34 AM
  #8169
CarlCrocco's Avatar
Smile
Ronnie
Ronnie,
I think for your applications the VTX10r will be your best bet. The standard VTX10 is more than capable of handling motors down to 6.5t, but in your case it's best to have no limitation on motor turns.
The main difference between the black edition is that the black editions are focused mainly for 2s applications, whereas the standard VTX is 3s capable.
The progauge and ezlink are both very easy to use. The ezlink is just a simplified version of the progauge. It doesn't have the Rpm tachometer the progauge does.
Go with the viper, it has more features like the adjustable BEC so you can run your servos at their highest settings. The viper esc is easier to program, the warranty is twice as long, and easier on your wallet.
CarlCrocco is offline
Old 06-16-2013 | 06:42 AM
  #8170
Ronnie
Hi Ronnie, you won't be disappointed!
The VTX10 Black Edition is definitely where you want to be. The 'R' is built for lower turn motors / 4wd. So if you plan on running lower than a 6.5T or 4wd, get an 'R'. For 2wd buggy / truck, the std is fine (it's what I run )
Proguage vs EZLink: Proguage has battery tester as well as a few other items. EZLink is strictly a setup box. We just introduced that option to lower cost to the consumer. Proguage will still be offered separately for those who still want it.
I've never run the Orion products, so I can't offer any comparison. I can only say that the VTX10BE is everything I could ever ask for in an ESC.
Old 06-16-2013 | 06:44 AM
  #8171
99.999% of the time this is something in the radio / receiver combo. I would say 100% of the time, but I've learned to never say never. The Viper ESC's are super sensitive to input, which is a good thing
Try a new model on the radio and rebinding everything to rule that out, then try a different receiver. If you still have the issue with a different receiver, try using a different radio all together.
Old 06-16-2013 | 09:37 AM
  #8172
trx498r's Avatar
Dx3r pro and sr300 but my buddy has a vtx8 and it does the same thing with his dx3c.
trx498r is offline
Old 06-16-2013 | 09:43 AM
  #8173
common theme is Spektrum. when I first got my VTX10BE I had an M11 with the Spektrum module. It did the same thing. I only had that radio for a short period of time though. I ended up getting the Futaba 4PL and never had another issue.
Old 06-16-2013 | 11:44 AM
  #8174
Ran the viper copperhead 4500kv combo for the first time this weekend in my losi scte.This weekend was the king of the hillbillies race at tcrc,I was able to tq and win the main.The viper system worked flawless I'm very impressed for the low cost of these systems.Does anyone use the 3900kv in 2wd sct.like to put viper in my 2wd also but want to keep it cheap and simple.
xxxntwv is offline
Old 06-16-2013 | 06:10 PM
  #8175
picco007's Avatar
Originally Posted by CarlCrocco
Ronnie,
Thanks, that was the info I needed. Thanks for your help!
picco007 is offline
