Viper RC -
#8131
twisted - there are lots of different ways the voltage could spike.... its not just jumps.
manatrams - you're going to like it
bds81175 & mulepic - agreed, but somehow it became standard. there are always tricks up the sleeve...
#8132
#8133
Finally managed to give my VTX8 a good run yesterday. Temps were good around 110/115F and motor around 140F. Instead of going up gears im considering changing some settings on the ESC 1st. What would be some good setups to try? (Motor is 1/8 buggy 2100kv on 4s)
#8134
good luck and enjoy the speed, quality, and reliability that viper has to offer....
#8135
Also jot down what your current settings are, current car, and current gearing. Then we can help you fine tune
#8136
I'm running a 2100kv in my buggy and I've had to tune down my VTX8 to make it controllable. I'll check out some of the settings I'm using when I get home tonight and post them up.
#8137
I'm running 2050kv motor right now. I run profile 1 with 16000mhz pwm and 55% punch in my MBX6ECO geared 16/46. That setup is more than enough power. I'm actually going to back it down to a 1900kv once our new motors come out.
#8140
I have been running the pwm fairly low around 8K.. and use 7 degrees of boost from 16-26,000 rpm.
But that is with a 2150 6 pole. and I know those motors like timing.
I normally like running low punch, but could not get it to respond fast enough with punch below 80.
#8142
you can mount it with double sided tape - there is a card in the box with drill holes to match some cars with the hole pattern.
I know some drivers use shoe-goo -- others zip ties. This thing is ready to give you power - you have to nail it down somehow!!!
#8143
I use mega black from autozone, it will absorb shock and is temp proof and scrapes off with your fingernail but holds great. Don't use the bottom holes, there's really not enough material there and will strip easily.
#8144
I use the 3m clear tape. It hold really well and provided shock absorption. But, I have fund that you MUST clean both surfaces with rubbing alcohol and do not touch the stick part with your fingers. Let it setup over night and it hold really well. With the vtx8, I would use 2 strips to cover most of the bottom. If you dont clean the surfaces like I said, it wont last long.
4Likes
