Like Tree4Likes
Viper RC -
Old 06-09-2013 | 11:47 PM
  #8116
I'm not sure what the length is, but 200 should be a safe length.
shagnat is offline
Old 06-10-2013 | 01:21 AM
  #8117
H0LESH0T's Avatar
Must common size for sensor wires is 200mm.
H0LESH0T is offline
Old 06-10-2013 | 04:03 AM
  #8118
Due to the long layout on the SCTE 2.0 I had to purchase a viper 280mm sensor wire.
SixxGunnz is offline
Old 06-10-2013 | 04:48 AM
  #8119
Jim Hustins's Avatar
Originally Posted by twisted
ran a large pro series race this week end and made the show but i had some problems a couple of times. power to my motor/esc stopped during a race briefly. once on a hard hit then again in the A main for like 20 seconds. the whole time i had power to servo so i dont think its a brown out. gonna go through the truck and check for loose plugs etc but was wondering if anyone here had similar problems. i also dont think it was a thermal as a friend picked up my truck during the race that it stopped in and said he could easily touch the motor and esc. he set it down and it worked again..
Another team driver and myself both had a similar thing happen. Both of us found it to be a bad Deans connector. After switching out the bad deans the issue went away.
With Lipos lasting a long time, they are outlasting the Deans connector.
Jim Hustins is offline
Old 06-10-2013 | 05:19 AM
  #8120
bds81175's Avatar
Moderator
Took first place at the Turf vs. Dirt Shootout in Foley Minnesota at the 510 raceway running a VTX8 powered Losi SCTE. There weren't many entrants in 4x4 short course and my main competition at this track dropped out fairly early but the truck was awesome and the ESC supplied effortless tsunami's of power. Installation and setup were a snap and my initial settings were spot on. I think I may have sold a Progauge too as I showed a fellow racer with a Copperhead system how easy it is to program with. Don't forget to get a Progauge, folks. They are awesome!
bds81175 is offline
Old 06-10-2013 | 05:56 AM
  #8121
Genebaby's Avatar
Also check your sensor cable, it can cause this type of issue and get progressively worse until it just won't go.
Genebaby is offline
Old 06-10-2013 | 05:57 AM
  #8122
godofcable's Avatar
in this case its an unsensored system (Copperhead R 5150 motor)
godofcable is offline
Old 06-10-2013 | 06:07 AM
  #8123
Genebaby's Avatar
Ah cool, don't know much about the other Viper systems off the top of my head. Still, gotta watch those sensor cables, I have a feeling they don't like being pulled out.
Genebaby is offline
Old 06-10-2013 | 09:24 AM
  #8124
bds81175's Avatar
Moderator
Viper design engineers...you would be an even bigger fan of mine if you would develop an integrated power/sensor cable to run between ESC and motor. I have no idea how our hobby has managed to get this far with the chintzy little sensor wires dangling out of the back end of the motor but something substantially more robust would be sweet!
bds81175 is offline
Old 06-10-2013 | 10:08 AM
  #8125
Originally Posted by nikos2002
probably had a voltage spike from the hard hit. these 4 pole motors we all use now a days put a big strain on the system and it can happen. Sometimes lowering settings like Punch, battery type (how old it is), motor efficiency - are all things that can help contribute it that happening. If it was a more series issue it would happen constantly - like every jump.
the 2nd time it happened where it lasted for like 20 seconds there was no hard hit. it happened in a long switch back.
twisted is offline
Old 06-10-2013 | 11:06 AM
  #8126
+1
mulepic is offline
Old 06-10-2013 | 01:05 PM
  #8127
I have a new Platinum Slash 4x4 (LCG, GTR etc.) That I have been running on backyard and outdoor tracks. Just for fun not competitive racing. I was looking at getting the
Viper R/C Copperhead-R ESC & VX4R.45 4-Pole 550 Sensorless Brushless Motor Combo (4500kV)
any thoughts on the combo? I am sure it will be a power increase over the stock Traxxas VXL system
I just upgrades the driveline ahead of time lol
Manatarms25 is offline
Old 06-10-2013 | 01:07 PM
  #8128
godofcable's Avatar
ive been running mine over a year in an LCG Slash race truck. been a reliable system, and runs super cool
Old 06-10-2013 | 01:57 PM
  #8129
Mind if I ask what KV motor you use and your gearing ? Need to know what pinions to order.
Thanks in advance !!
Old 06-10-2013 | 02:03 PM
  #8130
godofcable's Avatar
4500kv. 13/52, but I could go 14/52. The 13/52 is fast enough for me so I just leave it.
