Like Tree4Likes
Viper RC -
Old 06-05-2013 | 08:57 AM
  #8086
BillyCaldwell's Avatar
I have not had any problems with the fans either. I think the cf brace across the fan on the vtx8 really helps with the longevity.
BillyCaldwell is offline
Old 06-05-2013 | 09:19 AM
  #8087
DavidAlford's Avatar
I've had some big air in my E8. And raced on some dusty tracks. Fan is still kicking strong. I think Billy nailed it with the brace. Helps a ton.
DavidAlford is offline
  #8088
nikos2002's Avatar
Derek check your PM
nikos2002 is offline
Old 06-05-2013 | 05:19 PM
  #8089
Genebaby's Avatar
If there is info on fan replacement can we all get it please?
Genebaby is offline
Old 06-05-2013 | 06:26 PM
  #8090
nikos2002's Avatar
6VSPFAN003 - that is the part number for the fan itself. cost is $9.99 US
Old 06-05-2013 | 06:46 PM
  #8091
Genebaby's Avatar
Ok, so no info on fan swapping, thanks.
I asked about these new capacitor kits, what are the advantages/changes for the VTX8?
Genebaby is offline
Old 06-05-2013 | 07:01 PM
  #8092
Wildcat1971's Avatar
what does a cap do? well it stores power and acts like a buffer. It can make the esc work a little less as hard and thus run cooler. If your experience dips on power under heavy loads it can smooth that out.
Wildcat1971 is offline
Old 06-06-2013 | 01:02 AM
  #8093
Genebaby's Avatar
I know and understand that, I am his wondering what the deal is with supposed cap kits? Things seem fine, what are they meant to achieve over what we have now.
Genebaby is offline
Old 06-06-2013 | 02:03 AM
  #8094
H0LESH0T's Avatar
Does any screw the VTX8 using the screw hole template?
Does it void the warranty removing the 4 screws on the bottom of the case to use the template that was included with the ESC?
H0LESH0T is offline
Old 06-06-2013 | 08:25 AM
  #8095
nikos2002's Avatar
????? Fan swapping? The part I listed is the fan for the VTX8, if a replacement was needed. Sorry don't understand that question.
New capacitor kits. The capacitors help to store energy so when you pull the throttle it releases an extra amount and provides more punch. If you ever had a jump right after a turn and had issues clearing it --this would help that situation.
Old 06-06-2013 | 08:32 AM
  #8096
nikos2002's Avatar
Its my understanding that some 1/8 kits provide for this - so I cant say exactly what screw. My thought would be what you have around.
The cases are sealed with epoxy, even though they screw together. So its not that easy to take off - I would try it - I just did -- couldn't get it off.
If you follow the template, there are openings in the board, obviously you won't be using 10mm long screws or drill hole - just enough to go through the lower plate.
Old 06-06-2013 | 01:21 PM
  #8097
Genebaby's Avatar
6VSPFAN003 asked about parts needed to swap to a different fan, which is the information I thought was being pm'd.
I think my caps are fine, thanks for the info.
Genebaby is offline
Old 06-07-2013 | 04:07 PM
  #8098
Gabriel2010's Avatar
Post
You can get a lot Viper stuff at www.shopviperrc.com
Gabriel2010 is offline
Old 06-08-2013 | 05:01 AM
  #8099
hdmm's Avatar
Well....I got tired of the backorder for a Teking RX8 Gen2 and ordered a Viper VTX8 from A-Main for my SC8.2FT. After I checked out my buddy's VTX8 I had to get one for myself, cant wait to get it!
hdmm is offline
Old 06-08-2013 | 05:05 AM
  #8100
Genebaby's Avatar
Excellent choice!
Genebaby is offline
