Like Tree4Likes
Viper RC -
Old 06-01-2013 | 11:56 AM
  #8056
Wildcat1971's Avatar
i had a guy ret a 10r with a 4.5 xl and only bad things happened, but he did not have the fan kit.
Wildcat1971 is offline
Old 06-01-2013 | 08:39 PM
  #8057
is it advisable to take apart the Viper VX4 5.1 motor to clean? i ask because my rubber boot keeps coming out of the can where the wires enter(im gonna silicone it in place). i assume its dirty in there from the tracks i run on.
thanks for any info.
twisted is offline
Old 06-01-2013 | 08:51 PM
  #8058
nikos2002's Avatar
twisted - I wouldn't worry about taking it apart -- but blow it out with a compressor or air can before you add the silicone. Just make sure keep the silicone on the outside.
Wildcat, Grasshopper and others -- you can run the VTX10R with a VST4.5XL - Travis has put the combo in many a Amain with all the pros running. But it is pushing the top end of the envelope. The VTX8 would run the 2 pole 4.5XL without breaking a sweat.
The bigger question is running 2 pole vs. 4 pole. Honestly, 4wd SC has been a catch up game for us from the beginning. 3 years ago, ROAR said 540 only, then they allowed 550. So we had to go make one of those. Now 4 pole - there are no official 4 pole rules, yet motors from other mfgs are "approved". So we waited for an official ruling, one has not come. So we made one to throw our hat in the ring. Surely, once we do good with it, some sort of rules will be published.
If your running on a bigger track, with larger jumps, you need 4 pole power. If the track is small or medium sized, flowing with rhythm jumps then the 2 pole can keep pace if geared and set up right.
Once the VF4's come out, all questions will be answered!! Sorry for the book, it just explains our position.
nikos2002 is offline
Old 06-01-2013 | 08:53 PM
  #8059
nikos2002's Avatar
Originally Posted by DustinH
I have a friend having a issue with his viper 8.5 combo. Unfortunately I'm not there with him but he says everything is fine but the motor won't run. The lights on the switch respond to trigger inputs but not the motor. They have tried a different sensor wire and motor, same issue. Any ideas?
There is a sensor or connection issue somewhere. If the lights are showing the response, it should transmit that response as long as the motor is receiving the signal.
Old 06-01-2013 | 09:03 PM
  #8060
silveraider14's Avatar
how are they vst motors? I am thinking about getting a 7.5 for my 2wd buggy and a 6.5 for my wheeler.
silveraider14 is offline
Old 06-01-2013 | 09:14 PM
  #8061
DustinH's Avatar
My thoughts exactly Nick
DustinH is offline
Old 06-01-2013 | 09:25 PM
  #8062
thanks nikos2002
twisted is offline
Old 06-01-2013 | 09:42 PM
  #8063
LosiPRRACER's Avatar
hey everyone, i have a vst 10.5 and vtx10 combo. running 10 top speed timing and stock can timing. slew rate of 3 - rest of settings are stock profile #1 on race open
i am getting 171F(at motor) after 10mins on the pace, high traction.(motor isnt shutting off with cutoff at 170F
however my ESC is only 75F or there abouts...
my system is only 2 months old an have all settings good.
LosiPRRACER is offline
Old 06-02-2013 | 05:58 AM
  #8064
what car and gearing
Old 06-02-2013 | 11:39 AM
  #8065
AndrewTom's Avatar
viper motors are generally very torquey, you may find your self a tooth taller then other with similar turn motors.
I have a 10.5 in my 22T, and a 17.5 in my 22SCT (blinky), very good product.
and you have a lot of very sharp and friendly Team Drivers on this thread.
Viper guys- Can we expect the BE VST motors this summer?
AndrewTom is offline
Old 06-02-2013 | 01:19 PM
  #8066
As Nick said, we aren't ready with the 10th scale motors yet. They are down the road some. I haven't heard any dates mentioned at all.
Bob Barry is offline
Old 06-02-2013 | 01:21 PM
  #8067
do they run hotter than other motors? and torque is good cause I run on small tracks.
Old 06-02-2013 | 03:34 PM
  #8068
22sct, 86 spur 21 pinion(as advised by losi) trans ratio 2.43 , 9.95 FDR
Old 06-02-2013 | 09:59 PM
  #8069
My VTX8 Viper powered Caster Racing Rapture 4wd SCT ran great today and got me a 2nd place finish in the Expert A main...
bring it on is offline
Old 06-03-2013 | 11:06 AM
  #8070
DustinH's Avatar
2wd Buggy - Ballstud pulled out of steering rack arm
+ YouTube Video
Mod SC
+ YouTube Video
4WD SC
+ YouTube Video
DustinH is offline
