Viper RC -
#8026
#8027
Its the best way, but you can also just change profiles - if you are using 4 or 5, then go to 3. If using 3 you can try 2. Basically the profiles in the esc are designed to be slightly more aggressive as you go higher
#8029
there were a few pics on a BE motor over a year ago:
http://www.rctech.net/forum/10263549-post869.html
I like the idea of a fan. those traxxas brushed motors with the internal fasns seem to hold up fine to about all the abuse in the world.
#8030
wondering the same on a due date.
#8032
set can timing to 40 and watch it fly!
#8034
It will work, but common thought process is lower gauge transmits more voltage, which should mean more power. I didn't tell the difference between 12ga and 14ga. But only used 16ga/18ga with my 21.5 F1 car.
#8035
As for the new motor development -- best thing I can say, is this..... we aren't going to release one until we have it doing everything we want. We have tested a few different ideas. Each had their own good qualities, but nothing that checks every box just yet. Still working on it.
#8036
Quickly proving to be the new standard in 1/8 electronics the Viper VTX8 and its durable all metal construction are taking on and winning events at tracks all over the country. From hard packed clay, to loose loamy, and even worse – the VTX8 is delivering smooth sensored power that drivers can depend on to handle the rigors of 1/8 battle. Chris Giraldo helped us put together a video showing a VTX8 powered car going through its paces – enjoy the new standard and find performance without boundaries.
http://www.youtube.com/watch?v=kPFJhNlNubI
VTX8 and other Viper products available via your local hobby retailer or www.shopviperrc.com
#8037
#8039
#8040
4Likes
