Viper RC -
#532
For me at least I have been comparing what is stated to be included with the ESC package to what speed passion offers as they also include a programmer that doesn't need a laptop, and I believe also can update the firmware of the ESC. I loved using the speed passion stuff for that reason versus the Tekin where I needed a laptop.
I am leaning towards the Viper stuff due to the better warranty.
#533
Most of the features can be accessed on the Tekin itself. No biggy there. The Castle you can use the Tx to reconfigure the esc or the program card. So no biggy there as well.
I would like to see how refined the software is on the 1/8 Viper ESC. I want to see good startups with overgeared buggy's in sensoreless mode. I want to see good brakes from high speeds with overgeared setups. Are there additional cap banks available for example. Can the 2650kv motor handle drifting on 4s without blowing it's rotor?
#535
I would like to see it tested with the ESC mounted directly to the vehicles chassis with mimimal servo tape (ie- no cushioning) to test survivability of the electronic components as well as the case itself. Also would like the case to not use any form of plastic tabs to hold it together. And no fan reliance for use would be great.
#536
Electronics in general do not like vibrations/shock of any kind. I cushion all my esc's for this reason. If I would stick the Viper esc to the metal chassis, I would use 1 or 2 layers of thermal conductive foam tape. You get the benefit of one giant heatsink that way and still reduce those micro vibrations.
I've done it with the Quark 80B and 125B. I've even done it with the Tekin RSpro with good results.
#537
I agree, but I figure if to test the durability of the components, go with the worst case scenario and work from there. Sort of like having the best drivers in the world test your vehicle for durability may not be the best idea since they proably crash the least. The common joe always seems to be able to find durability issues LOL.
#539
It depends on the size of the track you will run on, the traction on the track, and the class you will run. In a 2wd buggy on a small to midsize track alot of racers are using 13.5 motors, with timing advanced. If the track is a little larger I would go with a 10.5 motor. Dont forget that with the tunability of these speed controls, either setup can be crazy fast. Try a vtrax10 with either one of those motors.
#540
4Likes
