Like Tree4Likes
Viper RC -
Old 05-20-2013 | 11:09 AM
  #7906
Bobby Z's Avatar
Originally Posted by Bob Barry
start with profile 2
- Increase punch to 85%
- PWM around 8000mhz. Raise it some if you need to smooth out the delivery more due to low grip
- Disable dynamic brakes
- set drag brake to around 8-10% and adjust to your preference
- reg brake 85% and adjust to your preference
- brake PWM 2500mhz
- EPA on radio should be 100 Forward 85 Reverse (adjust for grip level)
Thanks for the quick reply. I'm fairly close to this but will make some tweaks. Because I'm running 10.5 I tried no timing in one of my heats and it felt slow. The straight is fairly long so I added 15 degree timing and used Profile 3. I also had 10 degree top speed timing but used a very small slew rate.
I think I was running 75% punch and 9600mhz. dynamic brakes were disabled and 10% drag brake.
Bobby Z is offline
Old 05-20-2013 | 11:43 AM
  #7907
Is "punch" equal to the "expo" on the transmitter?
Also, am I correct that higher PWM gives smoother "feel", but increases ESC temperature?
Toyman is offline
Old 05-20-2013 | 11:50 AM
  #7908
DustinH's Avatar
Punch is not expo. Punch is linear. You are correct about the pwm.
DustinH is offline
Old 05-20-2013 | 12:01 PM
  #7909
Thanks! What does Punch affect?
Toyman is offline
Old 05-20-2013 | 02:09 PM
  #7910
DustinH's Avatar
I think of punch like a slipper adjustment. It's the torque adjustment for the motor. Run more punch when there is more traction. Running stock though don't run too much.
DustinH is offline
Old 05-20-2013 | 02:30 PM
  #7911
singlemike's Avatar
You just described the exact setup that is in my RB6, so yup, it will work just fine.
Would you also keep the motor at its out of the box 30 degree timing? I've never used a motor with end bell adjustment-
singlemike is offline
Old 05-20-2013 | 02:34 PM
  #7912
nikos2002's Avatar
for lower turn motors yes. for spec motors - 13.5 or 17.5, you will probably want to turn it up.
nikos2002 is offline
Old 05-20-2013 | 03:56 PM
  #7913
weyant's Avatar
I turned my boys 7.5 endbell timing down, is that not the way to go? and what would it do if I did?? raise temps? or anything.
weyant is offline
Old 05-20-2013 | 05:31 PM
  #7914
I'm really curious about "end bell timing" as well.
Is this a situation of "borrowing from Peter to pay Paul" situation, or does turning the endbell timing up just give more power throughout the power band?
Please help me.
shagnat is offline
Old 05-20-2013 | 05:51 PM
  #7915
Advancing endbell timing produces more RPM, more overall power, LESS torque, and generates more heat. Mod motors generate enough RPM that you don't need to change the timing. with my 17.5 motor, I will generally run around 45 deg timing depending on the actual motor and conditions. And most cases I am geared 34-36 / 69
17.5 (and 13.5) motors don't turn enough RPM, so you in turn hang more gear on them. In order to get the top end, you hang a huge pinion on. Problem is, the bigger the pinion, the more heat you generate and the more torque you need to turn that gear over. That's why you read about some guys trying High Torque or HT rotors. I tested one at Motorama in my B4.2. Here's the pic of the gearing I ran. after 6 minutes I was at 84 degrees. Granted air temp at the track was mid 60's. But you get the idea.
40/69 with 12.8 Rotor. I did NOT stay with this as the track simply wasn't big enough and I couldn't put any bigger of a pinion on while still adjusting the motor screws
Bob Barry is offline
Old 05-20-2013 | 08:26 PM
  #7916
Bob, thanks for the explanation. I kinda' thought there was no "free" power, but, just didn't know what was given up and what was gained.
I'm guessing a little extra end-bell timing is good on my 17.5 buggy and adjust spur/pinion from there. Make sense? (I hope)
shagnat is offline
Old 05-20-2013 | 10:03 PM
  #7917
just run it for 2 min and check the temps. then run for 4 min, check the temps..... do this until you hit the length of your quals and again for your mains.
Don't practice longer than a qualifier.
keep the temps under 150. Also remember the temp cutoff that's built into the ESC reads the temp from the board, which is higher. So if you set it for 150 deg, you'll likely hit your temp cutoff. 150 internal is closer to 100 on the can from the outside. I personally disable the motor cutoff temp setting on the ESC and just monitor it with an temp gun externally since this is what I'm used too.
Old 05-21-2013 | 05:18 AM
  #7918
Great explanation, Bob. Very much appreciated.
shagnat is offline
Old 05-21-2013 | 05:21 AM
  #7919
nikos2002's Avatar
Thanks Bob!!
One point I want to stress especially with 17.5 classes, but it applies to all types of racing. When you gear for performance (or use boost, or motor timing) you have to be mindful of how long your race is. Judge the heat you build up by that. If you want to practice for 10 or 15 minutes - gear down, calm it down - so it lasts. This way you get a balance of performance, and products that last for a while.
Old 05-21-2013 | 06:48 AM
  #7920
rider313's Avatar
At the MN series I race at has 15 minute electric A Mains. You have to gear quite conservative to still have motor at the end, let alone battery. Lol
rider313 is offline
