Like Tree4Likes
Viper RC -
Old 06-24-2013 | 08:33 AM
  #8236
Originally Posted by AndrewTom
okay, I am considering picking one up!
good man! I know they are available on our site, but I'm not sure if they have trickled down to the normal mail order chains yet. They might have. I just haven't looked.
Bob Barry is offline
Old 06-24-2013 | 09:31 AM
  #8237
nikos2002's Avatar
For the two posts that stated that their systems would not turn on. Even though they are different systems - things you can try to look for at home are the same.
- try a different battery. even though it may register on a charger, connecting to a car speed control is different, so it better to take the battery out of the equation if you can.
- unplug the speed control from everything else, motor and receiver. and see if it powers on - to confirm one of those are not "shorting" the system.
- check any plugs, connectors or solder joints that were changed after the units were opened. If you if think it has a good solder joint - retouch so the solder flows. again trying to eliminate things that could go wrong.
If you have tried those steps and even checked with a different unit if you have one to see if it works. If none of it works, lets go ahead and send it in via the RMA Warranty form on the website to be evaluated. Please include all details like gearing, chassis, did you monitor temperatures - as all those can help resolve the issue.
nikos2002 is offline
Old 06-24-2013 | 09:46 AM
  #8238
I am sure this has been covered but i will ask since i could not find it. I am running my B4 with a 17.5 and a 10R. The Throttle Frequency changed by another racer. Since I did not do it when i got my progauge what should it be set to? track is 100x60 and I am geared at 69/35 lots of tight turns and jumps.
MikeFrazer is offline
Old 06-24-2013 | 10:21 AM
  #8239
For blinky 17.5 I run this
pwm 5000mhz (can't remember exact number but closest one to 5000.)
Punch 100%
45 deg endbell timing (Viper VTS 17.5t with std rotor)
Geared 34/69
Shorty battery (50c 4300mAh)
Old 06-24-2013 | 05:29 PM
  #8240
Thanks Bob.
Old 06-24-2013 | 06:08 PM
  #8241
Suspended
Hey Viper guys what are the vtx8 dimensions? I currently have a sp sav2 and its just a tad too big to fit safely in my eb48.
MattP is offline
Old 06-24-2013 | 06:10 PM
  #8242
Jim Hustins's Avatar
I run a VTX8 in my EB48. Fits like a glove.
Jim Hustins is offline
Old 06-24-2013 | 06:13 PM
  #8243
Suspended
Thanks Jim. Glad to know it fits well.
MattP is offline
Old 06-24-2013 | 06:43 PM
  #8244
Genebaby's Avatar
It fits snug with a T8 motor. I placed the power switch on the side of the fan cage.
Genebaby is offline
Old 06-24-2013 | 07:14 PM
  #8245
Suspended
I'm running a 70mm long 1900kv motor in my eb48. With all the gen 1 rx8s I've seen go up in smoke I'm thinking of trying a viper vtx8.
MattP is offline
Old 06-24-2013 | 07:48 PM
  #8246
ksarantakos's Avatar
Not sure how but the little red button on my vtx8 switch popped out. Switch still works fine if I stick a pin down in there to actuate switch, but is there any other solution that's a bit less tedious.
Thanks! love the speedos so far. Team drivers Jim Hustins and Steve Charles have been very helpful.
-Kyri
ksarantakos is offline
Old 06-25-2013 | 03:43 AM
  #8247
Hi guys.
Just wanting to get some thoughts on the vst21.5 as a blinky motor, especially for F1 onroad.
Thanks,
Steve
stephenianjames is offline
Old 06-25-2013 | 07:20 AM
  #8248
Originally Posted by stephenianjames
Hi guys.
Thanks,
Steve
Nick is the man to talk to about F1 But I believe that motor combined with the 12.0 rotor would be lethal
Old 06-25-2013 | 09:49 AM
  #8249
nikos2002's Avatar
Hi guys.
Thanks,
Steve
I ran the VST21.5 with the 12.0 rotor and the VTX1 to be in the F1 A Mains at Snowbirds and IIC.
Old 06-25-2013 | 09:51 AM
  #8250
nikos2002's Avatar
-Kyri
Don't know how that button can come out, I haven't had that happen in 3 years of using the systems. Yes it will work as you describe - see PM for some more details.
