Viper RC -
#8836
I do not think this is an esc problem but I could be wrong, it was my first weekend out with the vtx8. Ran great for practice and first 2 heats then....When I power up my car goes like half a runaway. The throttle keeps feathering and wheels are turned all the way left. I have rebound it several times & calibrated esc to radio.Sometime it works for a sequence or 2 then it does it again. If I where on frequencies you would swear someone was on my channel warming up a nitro. Is it a receiver or radio problem maybe. I have a M11x with standard fhss 3 reciever I use it in my other car with FHSS 2 and it seems all good. Once I had steering but no throttle the lights would sequence correct with trigger movement but no motor movement. Any Idea's.
Brian
#8837
Any tips for soldering the Pro6 Capacitor on.
I was trying to solder it to the main terminals coming off the ESC (VTX10R-BE) and i'm not making a dent in that solder in 6s. Running my brand spanking new fancy soldering iron with a 5.2mm chisel tip at 650deg.
Guess I'm just a little paranoid because it seems like too much heat on those terminals will destroy the esc.
#8839
#8840
I have a glitch buster installed, I'am leaning towards a Radio problem, going to try a different receiver tonight. Just so weird how the throttle was feathering like that. 10% to like 30% throttle no more no less. Maybe there is a Gremlin in my radio lol
#8841
Ok, I cycled it about 15 to 20 times with the old receiver, the first time the blue led flashed like it was in binding mode the throttle feathered a touch then it caught and turned solid blue. every time after that it worked. Its defiantly Radio. Don't know weather to trust the old receiver or put in a new one at a $100 a pop
#8842
My VTX8 is on it's way under RMA 082620132713.
As I mentioned in the form, I didn't use it for a couple of months after purchase while organising parts and then doing the build, but it seems the Vport wires are damaged from racing.
I would like it repaired, just let me know what I need to do when you get it, thanks!
In the meantime I'll use buggy 2 with the other VTX8 I purchased later on and race with that on the 8th. It's had about 15 mins of runtime in it but did go well when I used it for the last race on Sunday.
#8843
What do folks think of 18/87 gearing on an SC10 on a small medium size medium/high bite track? I over motor-temped during the 7 minute main this last week (no boost whatsoever and 12K frequency). It over-temped with the same gearing on an indoor carpet track a few days before too. Motor cut off was at 220 during the carpet race and then I jacked it up to 240 for the outdoor race. It was hot out this weekend (96°). Wondering if the motor is starting to go bad.
#8845
Too sum it up, the factory soldering is used with very high heat, professional grade equipment and probably soldered on before the terminals are even connected. Because of this the regular hobbyist needs to own a very high quality soldering iron, capable of pushing those watts in order to desolder the factory wire.
I was very worried about frying my new speed control with too much heat, so what I did was cut the wire as close to the terminal as possible and solder on top of it. This fixed all the issues I was having, I just needed to install additional heat shrink/wire protectant.
#8846
Another option is to install the 12.8mm rotor. I think that they will add torque and allow you to run cooler. Here's the rotor options available for tuning.
http://www.shopviperrc.com/searchresults.asp?cat=1839
#8847
I have nothing solid yet, but I'm testing a theory of mine that the newer generation of radios have a super high speed setting that messes with the ESC's. I believe this setting was intended to be used for dual servo setups like you would find in a nitro car. So go through your radio's manual and look for anything like that and then disable it or set ch2 to std speed.
Let me know if this helps.
Also what model transmitter and receivers are you working with?
#8848
check your radio settings for anything that says High Speed or HRSS something along those lines. If you have the option to disable it for your throttle channel (Ch2) do that. Set it to std.
#8849
Ok I looked it up. Airtronics calls it SHR. You can set it for each channel independently. Turn SHR off for ch2 and test again. If it still is doing this, disable SHR for all channels and test.
Look on page 48 of the manual for instructions on how to do this.
http://www.competitionx.com/pdf/radi...11x-manual.pdf
#8850
4Likes
