Viper RC -
#8822
So, got a new VTX8 in an mp9e. Worked fine for days 1 and 2 practice and quals. Day 3, finals, esc boot tones are correct but running lights are wrong - only P is lit up. R flashes if I hold reverse. When I press to switch to program mode and connect a progauge, it does not power the progauge up. Basic ESC operation still works - forward/brake seems to be the same as what I last set it as...
Any ideas? Or is it warranty time?
#8823
Im sure Bob will back me up or correct me here but i personally would not recommend it. By removing the switch your removing the functionality of the EZ Link which plugs into the switch itself for setting adjustments.
#8825
Cappy is correct. You don't want to bypass the switch.
If you have nothing and have tried different electronics with it, then you may need to RMA it. I can't give you a quote on turn around time, but we are usually pretty quick.
#8826
#8827
What I'm seeing on this VTX8 is no lights from F, N and S - in any mode, any throttle position. During the boot up sequence, I see P and R flashing, but not F. The tones play correctly. R blinks when I hold reverse, but when I let it go or press throttle N or F do not light up. When I press the button once as if I was going into program mode, R lights up solid, but F does not.
#8830
I'm in Australia too, been using this since April, what do I need to do to send it in to be fixed?
#8833
Just go here for your RMA needs
http://www.viper-rc.com/contact.php
I can't promise turn around times as that would be determined by the guys working there and the issue at hand, but everyone I know that has sent anything in has always said that they have a quick turn around.
#8834
If you have the time to do a trial and error test, then that would be the best bet. I know I personally don't.
What I mean by a trial and error test is set the cutoff at 150, run til you hit cutoff and check the outside. Let it cool down, bump it up 10 degrees and repeat. You would continue the process until you have determined what is the best ESC (internal) number.
Not a hard process at all, just time consuming and for me it's easier to just monitor the old fashioned way
#8835
I do not think this is an esc problem but I could be wrong, it was my first weekend out with the vtx8. Ran great for practice and first 2 heats then....When I power up my car goes like half a runaway. The throttle keeps feathering and wheels are turned all the way left. I have rebound it several times & calibrated esc to radio.Sometime it works for a sequence or 2 then it does it again. If I where on frequencies you would swear someone was on my channel warming up a nitro. Is it a receiver or radio problem maybe. I have a M11x with standard fhss 3 reciever I use it in my other car with FHSS 2 and it seems all good. Once I had steering but no throttle the lights would sequence correct with trigger movement but no motor movement. Any Idea's.
4Likes
