Like Tree4Likes
Viper RC -
Old 05-26-2013 | 06:15 PM
  #7981
bds81175's Avatar
Moderator
Eper, how hot are you getting? I'm not familiar with Kyosho gear ratios. Are you maybe getting a lot of wheel spin that is driving the temp up? You can't raise the spur...can you lower the pinion? I can't remember if you were the one we talked to about this before...you could try raising the throttle frequency to 16K. That should cool down the motor but might heat up the ESC a little.
bds81175 is offline
Old 05-26-2013 | 06:51 PM
  #7982
bigbadbasher's Avatar
Originally Posted by eper
also where can i find pdf's of instructions for motors and the progauge
http://www.sjhobby.com.tw/ezfiles/sj...manual_Chn.pdf
bigbadbasher is offline
Old 05-26-2013 | 08:23 PM
  #7983
Hey nick. Im running the vtx10r be and a 7.5 in my scr and geared at 17/82. Still running hot any ideas. Drive train is as free as it gets and i turned down the timing in the motor.
You're geared down compared to what I ran my SC10 at.
I ran 19/84, which is a 11.494
you are running a 12.541
I would try the 19 for a few minutes and see if your temps go up or down. If you aren't hitting the power band, you can be over revving the motor. Timing should be around 30 deg.
18/82 = 11.844
19/82 = 11.221
Bob Barry is offline
Old 05-26-2013 | 08:25 PM
  #7984
Kyosho's gear ratios are identical to Associated.
Old 05-27-2013 | 05:28 AM
  #7985
eper's Avatar
Thanks everyone for the help. Im going to go with what bob said and try going up on pinion for a few minutes.
Bds 81175 Yes i had a lot of wheel yesterday
eper is offline
Old 05-27-2013 | 07:14 AM
  #7986
ridgerunner1's Avatar
Originally Posted by nikos2002
If the temps were low and it cut off, it hit voltage cut off, due to a spike for some reason. Look at settings, try and lower punch a couple of points and see if that helps resolve it, because of less current to pass through the system.
nikos2002 i didn't explain very well from the beginning, i had ran for about 2 min. and shut off my system then took a little break for about 5 min, then i turned it back on and used the pro gauge to change a punch setting then i disconnected the pro gauge and rebooted the system and that was when it got hung up i then manually set it to profile 5 and has worked great after that using the pro gauge and raced two quails and a 8 min A main. that same day.
ridgerunner1 is offline
Old 05-27-2013 | 07:43 AM
  #7987
Default Two Dead ESCs?
@Nikos
I think I may have two dead escs...
Copperhead R - ran about 4 packs through it with no problems, excellent performance, happy happy! Decided to take car (4x4 Slash w/2800 Tacon motor, stock Traxxas servo, and Futaba r6033ff/4pks rx/tx) over to friends house to demo for kids, dads, etc. The car ran fine for a few minutes then suddenly died. A characteristic tiny puff of smoke came out of the speedo.
The only setting I changed, via my new Proguage that came with the VTX10R, was the motor direction so that I could connect the Tacon in a normal ABC configuration. Previously, the motor had to be run with the wires switched so that the motor could run normally. Incidentally, I changed this setting before the demo in which the esc apparently died...
VTX10R/VST 10.5 combo - Initial set up. Wires soldered correctly (no overheating), no issues with installation into car (Associated SC10B.2 FT, ProTek 150ss, Futaba r603fs/4pks). Did initial rx/tx calibration but throttle/brakes were reversed, so I changed REV setting on the tx (I had to do the same thing with the Copperhead, btw.)
I powered down everything and recalibrated again. The motor ran, but only in reverse. I switched tx setting again, powered down and recalibrated, but this time the motor ran forward for a few seconds then the system shut down. I disconnected the battery and checked its power levels - OK. Reconnected battery, powered up the esc and tried the same - power shut off after only a few seconds. The only sign that the esc wasn't fried was there was no smoke or visual cues to a failure.
...and now for my mea culpa.. the pinion wasn't fully tightened on the shaft when I first throttled up the VST and quickly spun off, perhaps causing a no-load power spike(?). This only occurred for a second or two before I realized what was going wrong, but is that enough to fry the esc/motor?
Before I send this two units in for service, could this also be a compatibility issue with Futaba? It seems like most of my rx/tx calibration time stems from getting the motors to run in the right direction with my rx/tx. Also, these are the only setting I've had to change on both escs before things went south.
Please advise?
festusss is offline
Old 05-27-2013 | 08:23 AM
  #7988
nikos2002's Avatar
festusss - shouldn't be the futaba system, I use the same radio and receivers in my cars for years. More concerned about having to change the motor direction. I say that because some companies run extreme timing on their motors (even though timing may not be adjustable). When you reverse the direction of the motor, not that timing is working in a different fashion and could cause issues.
On the SC10 - only if the ABC wires were not attached correctly or the calibration was done wrong would effect motor direction with that set up. FOR/REV should not matter once you do the calibration. Where there any issues during calibration? PM me and let me know.
nikos2002 is offline
Old 05-27-2013 | 08:24 AM
  #7989
nikos2002's Avatar
also where can i find pdf's of instructions for motors and the progauge[/QUOTE]
on our website
Old 05-27-2013 | 08:27 AM
  #7990
nikos2002's Avatar
Originally Posted by bigbadbasher
I just traded my buddy for a brand new Losi TEN SCTE Rolling Chassis and a brand new Viper VX4R.45..
What are you guys getting good results with as far as gearing with the VX4R .45? I know it's probably been posted in this thread but i don't want to sift through over 500 pages to find it lol..
Also want the Viper guys to know that i am very impressed with this system. We had it on the track yesterday and we was impressed. So impressed that i ordered the VTX8 today to try out.. It looks promising to..
Yes, the Copperhead/VX4.45 combo is very potent for racing - great value also. it will run competitively with much more expensive combos, and you can use the ProGauge for easy fine tuning if you want. You're going to like the VTX8!!
Old 05-27-2013 | 08:29 AM
  #7991
nikos2002's Avatar
Originally Posted by spider882009
I picked up TQ and the win in 2WD 17.5 Short Course off-road w/ the VTX10 and Viper 17.5 on friday. The 22SCT was flying. Need a Viper 21.5 for my 3racing F1 car. Where can I put my hands on 2 Banners for my local tracks???
Congrats!!! I miss running my F1!!! its awesome with a VTX1!!
Track can submit a request via our website, lower right corner, events form. If they sell our products, they can just contact us via sales, we'll include it in the next order.
Old 05-27-2013 | 02:53 PM
  #7992
PM sent, thx
festusss is offline
Old 05-27-2013 | 03:37 PM
  #7993
JEFFRO503's Avatar
Nikos....I went back a good 4-5 pages here and didn't see any mention of this , but when will the VT8 come back into stock at places like Amain? I'm in no hurry but would like to pick one up here in a few weeks.
JEFFRO503 is offline
Old 05-27-2013 | 04:10 PM
  #7994
22Racer's Avatar
Here is a pic of Kendall's pro4 setup he won the JConcepts Spring nats with. In the 6 minute heats he ran a 15 tooth gear on the Xtx8/ 4.5xl combo. Coming off at 170 deg. he thought it would get too hot for the mains. After calling Nick he went to a 13 tooth with some timing and top speed timing. He said the truck was just as fast but came off the 8 minute main at 140 deg. and using less than 4000 mah.
Rex
22Racer is offline
Old 05-27-2013 | 04:49 PM
  #7995
Nice
bring it on is offline
