Like Tree4Likes
Viper RC -
Old 03-20-2013 | 03:46 PM
  #7231
silvalis's Avatar
Originally Posted by OMG23RC
I have an rb5 to with a vtx10. I wanted to put my esc all the way down the very back of the battery tray but i can't because the battery hold down hits the wire going to the motor. any ideas? I really don't want to put the esc up front because it will be too hard to balance..
Like that b4 above, I just chopped the plastic battery strap. Didn't have to chop much, my vtx10 was mounted sideways too and I just had to clear the caps.
silvalis is offline
Old 03-20-2013 | 03:54 PM
  #7232
OMG23RC's Avatar
Well i have soldered my wires to a horizontal angle instead of vertical so now it fits without having to cut down my strap will put a photo on tonight. does soldering the wires to a different angle void the warranty?
OMG23RC is offline
Old 03-20-2013 | 04:31 PM
  #7233
Jowers's Avatar
Originally Posted by nikos2002
Don't be afraid!!!!!! Try the performance!! If you want to be faster than everyone else you have to use something they are not, unless they have the VTX8, in which case, we can try and make yours faster!!!
What is the warranty program and customer service like?
Jowers is offline
Old 03-20-2013 | 04:43 PM
  #7234
symmetricon's Avatar
I got my cap today and wired it up, and...... nothing...... Any tips or things to check for?
symmetricon is offline
  #7235
Wildcat1971's Avatar
365 day warranty. I have not had to use it yet, but everyone that has come on here seems to have walked away happy.
Wildcat1971 is offline
Old 03-20-2013 | 04:47 PM
  #7236
well soldering it on is not rocket science, so I am sure you did that well. you can post a picture of the replaced cap and just get confirmation on the install. But i think you said its under warranty, so I would start the RMA process if its doa.
Old 03-20-2013 | 06:41 PM
  #7237
Well i have soldered my wires to a 90' angle instead of 180' so now it fits without having to cut down my strap will put a photo on tonight. does soldering the wires to a different angle void the warranty?
OH YEAAHHHH
I forgot about that LOL. I did undo all the solder leads and stand them up vertical.
Bob Barry is offline
Old 03-21-2013 | 09:48 AM
  #7238
I'm looking to buy a new sensored ESC and motor for 4x4 SCT racing. ( running budget sensorless stuff currently )
Will the VTX8 pair well with a tekin pro 4 motor?
Or does viper have a 4 pole sensored motor for 1/10 sct racing? ( I'm not seeing one )
KTMDirtFace is offline
Old 03-21-2013 | 10:03 AM
  #7239
it will work with the pro4. No there is not a 4pole sensored at this time
Old 03-21-2013 | 10:13 AM
  #7240
Cool thanks. Now to go measure and see if it will fit
Old 03-21-2013 | 03:57 PM
  #7241
nikos2002's Avatar
Or does viper have a 4 pole sensored motor for 1/10 sct racing? ( I'm not seeing one )[/QUOTE]
Not yet
BTW, what are you trying to fit it in, should be fitting about everywhere.
nikos2002 is offline
Old 03-21-2013 | 04:33 PM
  #7242
Not yet
1/10 Traxxas Rally, converted to a Slash 4x4..so basically the new LCG Slash.
I did some measuring I can make it fit.
I'm going to order the VTX8 tomorrow. pairing it with a Tekin Pro 4 4000kv. Shouldnt be a problem as the Pro 4 is about 10mm shorter than the can I currently have in there.
Old 03-21-2013 | 09:23 PM
  #7243
Just got my stuff in the mail today, and it looks REAL good . Cant wait to get it installed and going. Now I have to go poke around and see if I can find a good setup for 4x4 buggy
mlemorie is offline
Old 03-22-2013 | 05:39 AM
  #7244
Genebaby's Avatar
I'm looking to install some bullets inline between my VTX8 and the Tekin 1900 motor. What size bullets should I use for this? 4mm?
Genebaby is offline
Old 03-22-2013 | 05:41 AM
  #7245
I'm thinking 5mm.
shagnat is offline
