Like Tree4Likes
Viper RC -
Old 10-25-2012 | 02:58 PM
  #5731
yes it's needed to change the settings and profiles. It's 20.00. That's a set of tires or couple drinks at the bar. suck it up buttercup :P
There is a USB interface that you can buy later. It's only NEEDED to update the firmware on the speedcontrol. The Black Editions all come with the latest firmware so you are covered there. Plan on getting it later
Bob Barry is offline
Old 10-25-2012 | 03:42 PM
  #5732
nikos2002's Avatar
All the units come with the latest software, unless they have been shelved somewhere - most retailers are turning them over quickly.
A few questions back about the VTX1 - biggest difference/advantage, is the 1s capabilities, its similar to the VTX10 versions. Mark Smyka just one 2wd Class at the Fall Clash at RC Madness with a VTX1 in his Durango 210.
Thanks for the help Bob - becoming quite the expert there!!!!
nikos2002 is offline
Old 10-25-2012 | 03:59 PM
  #5733
I just pay attention
Old 10-25-2012 | 04:01 PM
  #5734
ryanpatrickgore's Avatar
Alright thanks much guys. I get it now. Haha
Very helpful in here.
ryanpatrickgore is offline
Old 10-25-2012 | 04:39 PM
  #5735
ridgerunner1's Avatar
ryanpatrickgore go to the viper site and order from there if its come from Seattle only be a couple days here is there link for there stores and free shipping, i really like mine i have the vtx 10 BE and the VTX 10
http://www.shopviperrc.com/SearchResults.asp?Cat=1477
ridgerunner1 is offline
Old 10-25-2012 | 04:42 PM
  #5736
Thanks ridgerunner
Old 10-25-2012 | 05:02 PM
  #5737
savannahmick's Avatar
Originally Posted by FLHX1550
Looking at the settings / gearing I think you are under-geared almost 15%
Your roll-out would be a 1.08"
Many of the AE drivers run 7.5 motors and run either 22/78 or 22/81, and on my B4 with a VST8.5 / VTX10R-BE I am running 23/81. My roll out is at 1.18"
I would suggest going up at least one tooth, turn down the brake freq to 2500 or 4000hz, and turn the motor back to stock timing. Set the end point at 80% on the throttle and start testing there. Again, set the motor and esc temp settings ESC 170 and motor 200.
Thanks again guys! I have ran a 23/81 and your right ESC temps did drop a little but motor got around 165f after 10min. so I guess I'll try the 22/81 or maybe even 21/76. I also did drop my brake freq. to 4000hz and double checked other settings but can't test yet due to a layout rebuild at my home track Phil Hurd Raceway which has the popular Colonels Classic coming up in Jan. I got third in 17.5 SCT last year and excited about this year. Anyway thanks for all the help and will post back after I get a chance to put it on the track!
savannahmick is offline
Old 10-27-2012 | 06:31 AM
  #5738
silvalis's Avatar
What has happened to the VSE 1/8th motors?
discontinued until the 1/8th esc launch?
silvalis is offline
Old 10-27-2012 | 07:55 AM
  #5739
nikos2002's Avatar
Needed to make them better!!!! Current test samples better, still work to be done. We want you guys to have faster, more reliable motors. Faster and more reliable than everyone's stuff.
Starting final testing of VTX8 items, getting closer.
Old 10-27-2012 | 09:39 AM
  #5740
King DORK's Avatar
I'm in the market for a new esc for my Losi Comp Crawler that I run on 3s lipo. I'm eyeballing the Viper VTX10R, given it's impressive internal bec, ability to run 3s lipo, and it's very small footprint. The question I have is, with the pc link does this esc have a forward/instant reverse profile that crawlers use?
King DORK is offline
Old 10-27-2012 | 02:32 PM
  #5741
jaydits's Avatar
hi Guy,s
i race (well my son does) the viper stuf from the moment they came out
my son wesley van helmond drove it to the national championship this year in 2wd mod
i race myself for over 20 years so its not that i,m a noob with this stuf
we have been very pleased with the performance of the esc and motors
we updated the firmware to the a55 and found it run much cooler so all wel here
now we had an weird thing with one of our vtx10 esc,s last race
at the run in lap it didnt had brakes anymore when you picked up throttel and then braked it just spin freely and rebooted
we did the transmitter esc pairing again but dint help
we tryed it in the pits and after 2 times the esc just stopped and never got it to work
no lights no beeps nothing
different motor lipo reciever nothing helped
now today we had the same with our second and last vtx10
dont understand it it worked flawlesly this whole year
i found some other people on the net with same problems now but no solutions
what should/can i do
thanks in advance
jaydits is offline
Old 10-27-2012 | 06:24 PM
  #5742
silvalis's Avatar
Will you be keeping the KV ratings the same?
My R8pro just let go
hurry up vtx8!
silvalis is offline
Old 10-27-2012 | 08:03 PM
  #5743
nikos2002's Avatar
king dork - with the ProGauge you can set reverse mode (in Practice setting). Its brakes, then a slight delay, then reverse. And you can program how much power you get in reverse. Also with 3s applications, we really only recommend 10.5-25.5 motors, and even then, be careful to check temps often when first running to guarantee proper gearing.
jaydits - need more info, check your PM
silvalis - sure we will do all the regular kv ratings. I actually have a 1500kv, which is quite a mover with some boost added!!!!
Old 10-28-2012 | 09:53 AM
  #5744
spider882009's Avatar
I have a Truggy and Buggy def in need of a 1/8 Viper Motor & ESC.
spider882009 is offline
Old 10-28-2012 | 06:41 PM
  #5745
King DORK's Avatar
Thanks for the response. Unfortunately, that won't work for me. I need a speed controller with instant reverse. The motor I run on 3s is a 21.5 540 crawler motor so it's well in the limits of just about any esc. Thanks again.
