Like Tree4Likes
Viper RC -
Old 10-19-2012 | 11:32 AM
  #5701
justchris's Avatar
Default 1/10 on road 13.5
Hi all
Complete newbie to programable esc
Coming over from 17.5 blinky and any help
on a start up set up would be great.
I have the VTX 10 black edition.
Will i need a viper pc link or can it all be done on
the pro-guide. (told you i was a newbie)
Many many thanks
For got to say will be a thunder power or a tekin 13.5
justchris is offline
Old 10-19-2012 | 03:01 PM
  #5702
ekim628's Avatar
Hi Justchris-
Welcome to Viper. You can do all the adjustments on the Proguage so there is no need for the PC Link unless you want more visual User Interface
For 13.5 blinky, here is a good starting point
ESC Parameters
Leave everything stock and change only the Throttle freq edit***8000hz and the Throttle punch 100%
Drag brake is up to you and the size of the track, also 13.5 motor should be geared around 4.3 for larger tracks and 4.5 for small technical tracks. A 17.5 motor should be geared 3.8 for larger tracks and 4.0 for smaller tracks. Endbell motor plate timing @ 45 degrees. That should be a good starting point. If you have any more questions let us know. Enjoy your new system
Originally Posted by justchris
Hi all
Many many thanks
ekim628 is offline
Old 10-20-2012 | 12:02 PM
  #5703
justchris's Avatar
Many many thanks ekim628
As soon as rain stops this will be my start point
If not needed what does the PC link do
(Will still order one anyway)
One thing I will try is 0 drag brake
Thanks again
Old 10-20-2012 | 12:25 PM
  #5704
nikos2002's Avatar
It allows you to connect to a computer if you want and update firmware when needed.
nikos2002 is offline
Old 10-20-2012 | 12:29 PM
  #5705
AndrewTom's Avatar
Thanks again
the PC link alows you switch/update firmware. otherwise it just lets you see every adjustment on your PC screen. if you can read the screen on small calculator, i dont think you will have any issues reading the LCD on the proguage.
AndrewTom is offline
Old 10-20-2012 | 01:54 PM
  #5706
Is there a way to set profiles back to default using the proguage?
underway is offline
Old 10-20-2012 | 02:00 PM
  #5707
nikos2002's Avatar
re-flash the software via VLink - or see instruction manual, to see stock settings.
Old 10-20-2012 | 02:07 PM
  #5708
nikos2002's Avatar
Celebrate the Grand Opening of the Official Viper Shop, Get 10% off Everything and Check out the Limited Time Free Shipping Program!!!!
www.shopviperrc.com
Old 10-20-2012 | 02:15 PM
  #5709
www.shopviperrc.com
Very Nice
bring it on is offline
Old 10-21-2012 | 03:08 PM
  #5710
nikos2002's Avatar
Hope everyone had a great weekend racing. We did!!!!!
Mark Smyka won 2wd Open at RC Madness' Fall Classic by a full lap. Hot lapped the field by .8 of a second. VTX1 speed control - VST motor!!
:t ire:
Old 10-23-2012 | 07:40 PM
  #5711
www.shopviperrc.com
I was hoping the VX4R motors would be available I have the 5150 copperhead combo would like to try the 4500 without buying the whole combo again
Throwindirt is offline
Old 10-23-2012 | 08:53 PM
  #5712
nikos2002's Avatar
Throwindirt -- check you PM.
Old 10-23-2012 | 10:11 PM
  #5713
www.shopviperrc.com
I took advantage of this and suggest everyone else does too
Got my VTX10BE for my SC10.... should be here in a couple days.
Bob Barry is offline
Old 10-24-2012 | 04:22 PM
  #5714
savannahmick's Avatar
Originally Posted by FLHX1550
There are several factors that can contribute to ESC temp other than just timing. As Nick said, if you are under geared you can actually get the ESC hot.
First. Make sure you have the ESC temp setting set!!!!! I would set it at 170 or 180 degrees.
But, things like Drive Freq, Brake Freq, Drag Brake, punch, etc..... all can get an ESC hot
I myself tend to only run 80% brake or so, I find that once you have enough brake energy to lock the wheels on the strait-away, that you can turn it down. It helps keep from looping the car out when you get on the brakes.
First thanks for helping me out guys! I have not really done much to the profile other than turn off dynamic and drag brake but I do have 95% brake and the wheels still aren't locking up so thats why I have it high. The timing is 0deg. on both accel. and top speed /brake freq. 6400/thr. freq. 6400/punch 30%/slew 15deg./SBEC 6.4/motor is at 15deg./ and geared 21/81 in a b4.1 no bind smooth as silk. Any ideas on what I could do to get temps down just a little on esc. with the settings? 160f on ESC and 150f motor 8.5 vst. Thanks!
savannahmick is offline
Old 10-24-2012 | 05:45 PM
  #5715
Bobby Z's Avatar
www.shopviperrc.com
Added VTX10 and motor combo to cart and price was $299 instead of $229
Bobby Z is offline
