Like Tree4Likes
Viper RC -
Old 03-19-2013 | 03:17 PM
  #7201
MAD-MAXal's Avatar
Originally Posted by shagnat
I'm under the impression the electricity is pulled, not pushed. How does an ESC "push" power?
If you want to be critical its neither !!!
http://lmgtfy.com/?q=How+does+electr...nt+flow+%3F%3F
MAD-MAXal is offline
Old 03-19-2013 | 04:14 PM
  #7202
DaveG28's Avatar
I assume Nikos means that the esc allows more current through than many others, and that's what may cause drop!?
Question before I order, do both the standard and "R" versions of the black edition come with the different capacitor (eg not soldered straight to esc but with a length of wire)? I have a car with a tight fit in it!
Never did fix my temp issue fully at cactus, but I am wondering if that is probably because the first time toasted the magnet and made it less efficient? On one run it came off at 210 degree's!! To its credit it still kept working, but definitely felt soft!!
Dave
DaveG28 is offline
Old 03-19-2013 | 04:23 PM
  #7203
Wildcat1971's Avatar
Dave
huh, the BE comes with the cap on a wire and presoldered to the esc. The orange esc has a low profile cap soldered to the esc.
Wildcat1971 is offline
Old 03-19-2013 | 04:29 PM
  #7204
ryanpatrickgore's Avatar
getting an error, "connection fail" on my progauge. my system is new from christmas and came in the VTX10R 7.5 combo. the system works great now and the progauge worked fine the 2 times i used it in the past. now it wont connect to the esc. however it powers on and i can scroll through the first menue set and look at voltage if I want. always kept in the box and stored safely, looks perfect still. I have only used the system maybe 10 times total,
Is the problem coming from the progauge, esc or what? my gut is telling me esc as i have not even really used the progauge. yikes
thanks much
ryanpatrickgore is offline
Old 03-19-2013 | 04:44 PM
  #7205
tony montana's Avatar
yeah I get the connection fail sometimes as well. I usually get it to work. But to be honest I cant tell you what I did to get to the part were you adjust everything lol. I may be wrong but make sure your radio is calibrated. Just have to keep messing with it.
tony montana is offline
Old 03-19-2013 | 05:07 PM
  #7206
spider882009's Avatar
Had a warranty issue with me Viper 4.5... As stated in an earlier post. VIPER did an awesome job and get my motor turned back around in under 10 days!!! THANK YOU for the great service!!!
Now all I need is a 1/8 motor for my 2.0T and 2.0B to go along with the VTX8!!! When will those be available???
spider882009 is offline
Old 03-19-2013 | 06:15 PM
  #7207
thanks much
ryan, make sure it is in program mode BEFORE you plug the PG in.
Old 03-19-2013 | 06:22 PM
  #7208
Oh, ok I will try again tonight.
I don't think it was in program mode last time I did it. I think it just worked. I might be wrong tho, it's been a while.
Thanks wildcat
Old 03-19-2013 | 06:29 PM
  #7209
Gigasipke's Avatar
Originally Posted by nikos2002
Did you try our motor with the Copperhead? Just curious (unless I missed it on a previous post).
No I did not, my SC10 4x4 previously had the MMP paired with the Pro4 4600, and before that it had the CC 3800kv. But the MMP died so I was just looking to replacing the ESC. I now wish that I spent the extra $30 and got the combo with the VX4R.45 though. All I can say is that I am now a big fan of Viper and will be my ESC of choice from now on. Haven't tried a motor yet though so maybe in time I will try them out as well.
Gigasipke is offline
Old 03-19-2013 | 07:25 PM
  #7210
ok, I love the vtx10 and I love the button switch. So here comes the but....lol. At first I thought it was just me, then I talked some guys at the track into buying vipers. A week later they asked me if I had issues with the switch. My first reaction was no. Then they told me, "Ok, I keep trying to turn it off and half the time it goes into program mode". Then, I had to agree with them. I was having issues, but then just started to unplug the battery to turn it off. So now everyone here just unplugs the battery and ignores the on/off switch. I am sure 30+ people will chime in with how easy it is to hold it for 5 seconds, but I sometimes how it for 10-15 seconds and it still goes into program mode. Like I said, we just unplug it and call it a day. Just my 2cents if you guys every come out with a new firmware. Maybe some sort of fix there.
Old 03-19-2013 | 07:47 PM
  #7211
DaveG28's Avatar
Hahaha I thought it was just me being a bit "special" that meant it didn't turn off half the time!! Glad to hear it isn't just me!
DaveG28 is offline
Old 03-19-2013 | 07:49 PM
  #7212
godofcable's Avatar
you gotta hold it until the three lights come on, then let it go
godofcable is offline
Old 03-19-2013 | 08:07 PM
  #7213
DustinH's Avatar
Yeah, I just unplug the battery too. Have to charge it anyway, lol.
DustinH is offline
Old 03-19-2013 | 08:12 PM
  #7214
I also unplug the battery lol
Old 03-19-2013 | 10:24 PM
  #7215
silvalis's Avatar
I used to unplug the battery, but now I use the switch. Have to use my fingernail to turn it off; pushing with the pad of my finger will usually put it into program mode. hah.
silvalis is offline
