Like Tree4Likes
Viper RC -
Old 11-13-2012 | 09:57 AM
  #5881
Grasschopper's Avatar
Originally Posted by Wildcat1971
thanks matt.
I was looking over the manual online. it looks like there are 8 preset profiles. And you can pick the profiles with the red button after holding for 3 seconds.
Things I am unclear on.
- What is required to connect the esc to the pc for tuning? pro gauge?
- Can the profiles be edited with the red button? or only with pc link / pro gauge?
Honestly I've never switched profiles without the Pro Gauge so I can't comment there but you don't really need the PC Link unless you want to upgrade the firmware at some point. Pro Gauge lets you adjust every setting on the ESC and is easy to use. To connect to a PC you do need the PC Link.
I've got two 10Rs and a BE 10 now and I love them. The 10R in my XXX-SCT is barely warm when I finish a 10 min main running a boosted 13.5, no need for a fan. I run the BE 10 in blinky mode with a 8.5t and I have never felt it above ambient.
Grasschopper is offline
Old 11-13-2012 | 09:59 AM
  #5882
thanks matt.
PC link is what connects you to your PC. Thats honestly just important for firmware updates.
Progauge hooks into your switch on your ESC.
That allows you to change the settings within the profile or change the profile itself.
I have never changed profiles without Progauge, mostly because I haven't had to.
Bob Barry is offline
Old 11-13-2012 | 10:01 AM
  #5883
Anyone have a pic of the vtx10r in the b4? I might buy one and am concerned about the fit with the caps on top
If you haven't purchased yet, Just get the Black Edition. You don't need the R for 2wd mod.
The R is really only "needed" if you are running lower turn motors (below 6.5), although I would probably consider the R for 4wd offroad too so you have wiggle room for motor choices.
Old 11-13-2012 | 11:26 AM
  #5884
Wildcat1971's Avatar
ok, great info. Last question. When I look at the pictures online of the vtx10 and vtx10r, some come with shrink wrapped caps and others are just the 2 silver caps. Are the silver caps ones an older generation?
Wildcat1971 is offline
Old 11-13-2012 | 11:41 AM
  #5885
ekim628's Avatar
Yes they are the older generation speedos, the new ones come with bigger caps for better voltage spike regulation. Performance is still the same in both units. The new ones offer more protection
ekim628 is offline
Old 11-13-2012 | 11:57 AM
  #5886
ok, thank you. seems like the Black edition vtx10 with pro gauge is going on my xmas list.
Old 11-13-2012 | 12:37 PM
  #5887
Smart move. You will enjoy it. I'll try to post my setup and get Fred's too. Then you will see boosted and non boosted setups for mod buggy.
Old 11-13-2012 | 02:33 PM
  #5888
Default Best esc 17.5 tc
Hi was just wondering which viper esc would be best suited for 17.5 boost and blinky racing in a touring car?(also using a savox 1251mg servo)thx.
Greenant is offline
Old 11-13-2012 | 04:05 PM
  #5889
DoogieLee's Avatar
VTX10
DoogieLee is offline
Old 11-13-2012 | 07:03 PM
  #5890
OMG23RC's Avatar
Guys is the vtx10 b.e powerful enought to power 4wd buggy stock or do I need the r version?
OMG23RC is offline
Old 11-13-2012 | 09:57 PM
  #5891
What turn motor?
bring it on is offline
Old 11-13-2012 | 11:06 PM
  #5892
silvalis's Avatar
Stock in Aus means 17.5 blinky
silvalis is offline
Old 11-14-2012 | 04:14 AM
  #5893
FLHX1550's Avatar
The specs on the VTX10 and VTX10-BE say the motor limit is 6.5 turns for 1/10th scale 2wd applications. Now that doesn't mean if you put it in and pull the trigger that it will not work, but there is a higher risk in doing so.
I myself would recommend the VTX10R-BE for any 4wd application. 4wd not only has a dynamic increase in drag on the drive train (especially a belt drive car), but the driving dynamics of 4wd requires one to use much more brake (to get the car to steer) and you tend to be more aggressive coming out of the hole with 4wd. All of which will tend to get the ESC hotter.
I would think that most people would rather know that the ESC they bought will do the job for sure, vs trying something out and getting a day or two of racing in just to find out they have to add fans, turn down settings, etc....
FLHX1550 is offline
Old 11-15-2012 | 11:52 AM
  #5894
I just installed vtx10 -8.5 in my 4x4 buggy. Motor turned down. I dont recommend this at all. I did it for one race tell my vtx10r arrives I had a points race I could not miss.
SikKustomz is offline
Old 11-15-2012 | 01:13 PM
  #5895
brainiac's Avatar
Hey I'm looking at getting into 2wd buggy and I had some questions about your products. Sorry for asking these as I'm sure they've been asked plenty of times before but I'd greatly appreciate an answer.
What are the differences between the vtx10 the vtx10-r and the vtx1.
Also what are the differences between the regular and the black editions?
Also while looking on amain I saw that your 17.5 motor is 1900kv. While looking at others such as the new tekin 17.5 I noticed that it has something like 2700kv. Wouldnt this motor in theroy be much faster due to the higher KV or am I missing something?
brainiac is offline
