Viper RC -
#5866
The VTX8 will be able to handle both 2 and 4 pole motors, 2s-6s batteries. Yes we have tested with the motor you listed.
Tran- you can use the VTX10R with any 540 motor motor no problem. Don't think of it as overkill - think of it as extra precaution.
Kid, the choice is yours, depends on budget. Both combos are fast, powerful, adjustable and have performance.
Are you guys going to do the same 1 year warranty like the 1/10 scale stuff?
I really can't wait, I've been looking for something to try that will hold up to the rigors of outdoor 1/8th scale.
#5867
Hi all
Can you give me a hand to deal better with my controller
For the moment I'm setting the profile 1 no heating
I like self a DEX210 with combos VTX/8.5T
I have two crowns 87 and 81 with the pinion as 22/23/24/25/26
What would be a good report
I will participate in a race with indoor on carpet
Thank you for the help You to bring me
Nico.
Nico.
#5868
Hi all
Nico.
Nico.
#5869
Can't wait to try the VTX8 I'll be ordering 3 of them for Buggy, Truggy, and SC, Quick question, is the RX output voltage adjustable like the VTX10?
#5870
Team C equipped with Viper vtx10/17.5 ran flawless. I tq'd and should've won last Friday in our first club race on dirt. I'm geared 75/29 in blinky and my car is the perfect balance of torque and top speed. our track is 75x50 outside dimensions.
#5871
I run the VXT BE and 8.5T in my B4.1 and run an 81t spur (you called it crown) and a 23t pinion. Not sure of the Durango tranny drive ratio but you may need to adjust slightly with the pinion. I have so much speed I have the throttle end point turned down to 85% otherwise I can't control it...but that is a driver issue not car/esc/motor issue. Comes off the track barely warm.
9.5T = 24/81
8.5T = 23/81
7.5T = 22/81
Stay in that range and you'll be good. Hit me up if you need some help and I will see what I can do.
I just noticed he is running profile 1. Switch to profile 2 and try that. Add in some drag brake. Maybe 15%. Start with that. Profile 1 may be a little too sensitive as it's meant for 17.5 blinky. Profile 2 is still blinky, it's just got smoother throttle settings.
#5873
I don't have any with the body off that I can find...
http://sphotos-a.xx.fbcdn.net/hphoto...12957409_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...96525661_n.jpg
#5874
#5875
#5876
#5878
#5879
thanks matt.
I was looking over the manual online. it looks like there are 8 preset profiles. And you can pick the profiles with the red button after holding for 3 seconds.
Things I am unclear on.
- What is required to connect the esc to the pc for tuning? pro gauge?
- Can the profiles be edited with the red button? or only with pc link / pro gauge?
4Likes
