Viper RC -
#5837
Sorry to keep pushing this issue, But will the 1/8 ESC & Motor be coming out soon??? I need to replace my Tekin ASAP. Would like to get some practice with the system before the Midwest Championships and Motorama.
#5839
We have been working tirelessly to get our VTX8 in our customers hands. We have the final details in the works and it should be released next month sometime. Thanks for being patient. We want everything to be perfect before it comes out so hopefully you guys can understand the time we put in.
Eric
Eric
#5841
Some good results with my viper powered cars this last weekend at region8 regionals. 6th in mod truck,9th mod sc and went to the B in buggy. Regionals was stacked with fast guys! Tebo,Gosch.baumgardner,rippie,driemeier just to name a few. Overal I'm happy with the way i placed. Viper esc and motors ran flawless all weekend. Keep up the good work viper!
#5842
Some good results with my viper powered cars this last weekend at region8 regionals. 6th in mod truck,9th mod sc and went to the B in buggy. Regionals was stacked with fast guys! Tebo,Gosch.baumgardner,rippie,driemeier just to name a few. Overal happy with the way placed. Viper esc and motors ran flawless all weekend. Keep up the good viper!
#5843
My vtx10r (black cap/presoldered wires) was cutting out yesterday, usually after a jump. Once was a complete shutdown, the others I had steering but no throttle for a while.
What should I check/reflow? Power plugs? Motor wires? Change sensor cable?
#5844
Great run in both classes SikKustomz!!! Maybe post up your settings for all of us to see. Thanks
Eric
Eric
#5845
First check your power,if your using bullet conectors? They tend to get slop in them arking the battery and no power. replace sensor wire after power check. A bad sensor wire can make the wax and motor do diffrent things so it's nice to eliminate that first.
#5846
Also recheck you motor and esc temp cut off and battery cut off in the Protection section. If not set properly they the system will shut down the motor to prevent a run away situation. Example is motor temp cut off is 220, it will shu down motor until temp lowers. Remener these temp readings are internally measur so they wil be higher by as much as 50-60 degrees than what you read outside the can with a temp gun.
#5848
#5850
4Likes
One of the best 1/8th esc I have ever tested/ran.
