Like Tree4Likes
Viper RC -
Old 11-04-2012 | 10:00 PM
  #5806
cantrell8's Avatar
Originally Posted by 05PSD
I'm having issues with my second VTX10R. After setting it up, I can ramp up the throttle slowly and it's fine. If I pull the trigger too fast the motor stops.
This is the second brand new VTX10R that has done this. My M11x was on a new profile so I don't think it's radio settings. This is used with a Trinity D3 10.5 turn motor in a DEX210. Has anyone else experienced this?
what firmware is on you vtx?
cantrell8 is offline
Old 11-05-2012 | 07:43 AM
  #5807
FLHX1550's Avatar
Kendall Welch ended up with a 8th Place finish in Mod Truck at Spektrum, and Kevin Westindorf ended up 9th in 17.5 Buggy. Pretty fierce racing in both classes with a little bad luck in each.
however I have setup sheets from both drivers for their A-Main efforts, and my setup sheets from both my cars.
One ironic thing is that the configuration of the straightaway with a VERY tight sweeper at the end had us all able to be very aggressive with our drag brake and we were using different brake frequency settings to change the initial "grab" of the brakes when the drag brake engaged. I was running 70% drab brake at one point, and was able to hug the inside line very tight, yet was easy to drive and no worry about spinning out.
FLHX1550 is offline
Old 11-05-2012 | 07:47 AM
  #5808
Great job Viper! Thanks for the setups. I am going to check them out and see how mine compares.
One question, do you leave your radio EPA at 100 and Exp at 0 with these settings or do you adjust them as well?
Bob Barry is offline
Old 11-05-2012 | 08:54 AM
  #5809
nikos2002's Avatar
Originally Posted by techpro
After installing system tried to calibrate to radio, pressed the v-port button a light flashed and then no response,has anyone had this happened.Sending it to warranty office in the morning if no one has any insight
Before you send it in, let's verify the calibration process. We did a video that is ok you tube that shows the process. I don't have the link on my cellphone. But if you go to www.shopviperrc.com and look up a speed control, the video is on the page.
If your speed control can't follow that process, with the radio set properly them think about sending it in.
nikos2002 is offline
Old 11-05-2012 | 08:59 AM
  #5810
nikos2002's Avatar
Bob, I don't want to speak for Dave but I think the Throttle EPA would stay at 100, maybe only lower the brake EPA depending on how you set up the push brake (moving the trigger to get brakes). Yes the EXPO was probably 0 as well as you can make that type of adjustment on the speed control in a couple of ways.
Old 11-05-2012 | 09:51 AM
  #5811
Cool thanks. I figured as much but I didn't want to assume.
Old 11-05-2012 | 10:53 AM
  #5812
N8racer's Avatar
Hey guys!! Quick suggestion question! I have the Copperhead 4500 in my EXO Terra Buggy love the system so much I want to replace my MMP and 1410 3800 system in my SCTE for a Viper for racing. Which Copperhead system should I get that will be better than my castle, the 4500 or the 5150??
N8racer is offline
Old 11-05-2012 | 01:32 PM
  #5813
nikos2002's Avatar
Most racers use the 4500, but if you want to go a little crazy! Go up to 5150. The 4500 is more drivable. I have not ran on track that I got to full speed with the 5150. Don't forget even with the 4500, you can control the settings to help find tune the power and rpm you need.
Old 11-05-2012 | 03:04 PM
  #5814
Suspended
Hey Nikos, Where do I send my Sponsorship resume? It dose not say on the website what email, I love these esc's At my Local Race I took tq with 17.5 short course and ended up first. I have all my results if there needed! If you don't want to post the email up, you can p.m me about it that would be great, Thanks.
James
CT RACER is offline
Old 11-05-2012 | 06:06 PM
  #5815
nikos2002's Avatar
James, funny you ask... \/ \/ \/ \/ \/ \/ \/ \/ \/ look down \/\/\/\/\/\/\/\/\/
  #5816
nikos2002's Avatar
We are currently accepting resumes for the 2013 Team Viper. Please send your resume with your 2013 racing plan to [email protected] . Team managers will start to review the application and get back to you soon!!
Old 11-05-2012 | 06:45 PM
  #5817
Suspended
Sent mine, Thanks Nikos lol that was great timing. Hopefully I make it, Would love to make it and be able to support and represent Viper for the 2013 season.
CT RACER is offline
Old 11-05-2012 | 08:13 PM
  #5818
jnorwood_losi's Avatar
Default Help with VTX10R programming
OK, I have a TLR22 with a Viper VTX10R and a Viper 8.5T motor 76 spur 21 pinion.
My car drives good very smooth, but I drove a couple pro's cars this weekend and I am looking for the RIP or SNAP in throttle they have, if I pull full throttle I want ALL the power instant. I am mostly a 1/8th Nitro racer so I dont know much about the ESC ect...someone else set up my ESC as follows
Throttle: PMW Freq - 12000Hz
Punch - 70%
Curve - Linear
Dead Band - Narrow
Motor Power: Acc Boost - start 9500rpm finish 19500rpm Max Adv - 0 deg
Slew - 15deg/.1sec... Max 0deg... delay .35sec
So I played with some of it including boost but eveything I did only made it hit the rip I want after 10-15 feet and not instantly...it was poping wheelies down the strait but half way.
ANY HELP AND ADVISE IS VERY MUCH APPRECIATED
jnorwood_losi is offline
Old 11-05-2012 | 08:59 PM
  #5819
nikos2002's Avatar
Turn the punch up. Maybe the Throttle freq down slightly. Larger spur/pinion combo will give more torque as well.
Lower the start rpm and you might wheelie off the corner!!
Old 11-05-2012 | 09:01 PM
  #5820
nikos2002's Avatar
Also keep in mind that 2wd buggies have a flow to them, corner speed helps. Grip it and rip it, like a 1/8 doesn't always work -- but it does depend on the layout your are racing on.
