Viper RC -
#5956
Edit: found it and attached.
#5957
Run profile #2 and Race Blinky mode, Dynamic brake to 0%. Set punch and brakes as desired/required for your track conditions and you should be all set. There was a setup sheet posted a few pages back for 2wd Buggy running mod motor (I forget if it was 8.5 or 7.5). I run the VXT10BE in my B4.1 and it has been great. One of these days I hope to be able to get my throttle EPA closer to 100%.
#5958
Right that's why I said set the punch and brakes to suit. I am running a fair bit of drag brake though that may change with the new layout at Bumps his week.
#5964
http://www.viper-rc.com/pclink/updat...manual_A55.pdf
assuming your speedo has a55 firmware on it.
#5965
#5967
Did you get the setup worked out? The user manual and some stickers have been on the very bottom of the boxes of my Viper ESCs...under all the foam.
#5968
Yeah I got the stickes under the foam. It's no biggie on the directions since they are on vipers site thanks to the link above. The instructions on the site explain everything I needed. Shiuld I start out with just the stock profiles? Was gonna go with profile 2.
#5969
We had a huge race yesterday with 21 entries in stock buggy. I am pretty sure I was the only one running Viper products too. I ended up qualifying 8th and finishing 7th in the A. Pretty happy with that as I am just a "part time" racer and there were a ton of super fast guys there.
My question is how much drag brake are you guys running in 17.5 blinky buggy? I let one of the fast guys drive my buggy and he said I need more drag brake to transfer more weight entering the corner.
#5970
otherwise I would start at 5% and see if you can notice the difference. and add more from there.
4Likes
