Like Tree4Likes
Viper RC -
Old 11-19-2012 | 05:34 PM
  #5926
Originally Posted by Bob Barry
I'll leave the tech stuff to the pros but first thing you need to look at is what was the same / different as far as electronics between both times. Did you use everything the same? was any one piece different? if so, which piece? That's all stuff that will help in trouble shooting the issue.
Same battery both times, also my brother tried the battery with the same connector and worked just fine. Same steering servo and the same 4500kv viper motor both times. Someone suggested cleaning the bullet connectors and clamping them down a bit, so ill see how that goes, any other suggestions welcome
Hashbrowns is offline
Old 11-19-2012 | 08:34 PM
  #5927
nikos2002's Avatar
Thanks for the Bob!!
Hash- we have seen where the bad connections cause an arc and the system shuts down.
With the settings discussed earlier. Generally the faster the motor (lower turns) you want to run a higher freq to keep the power band smoother.
nikos2002 is offline
Old 11-20-2012 | 01:24 AM
  #5928
Hey Nick,did you get my PM?
Team STL is offline
Old 11-20-2012 | 06:42 AM
  #5929
ridgerunner1's Avatar
I had found on my vtx10 after a crash that mine would restart after a jump and some times just shut off, looking closer i found that the solder had cracked around the negative side of the power cap and the cap was bent up so i re-flowed the solder and used some double sided tap under the power cap to keep it from moving, that was two weeks ago and i have not had any trouble with it anymore, this wound be a nice little mod for people to use to keep the cap in place just be carefully lifting the cap just enough to put the tap under.
ridgerunner1 is offline
Old 11-20-2012 | 09:05 AM
  #5930
nikos2002's Avatar
Yea, last week, thought I replied. Guess not........
Old 11-20-2012 | 09:21 AM
  #5931
spider882009's Avatar
"VIPER POWER" Will be running 3 classes this weekend during the Turkey Bowl @ McCullough's Off-Road in Sarver Pa. 2 will be Viper powered!!! The only one that won't be is the Losi 2.0!!! Can't wait for that system.
Heading to the Reedy Race of Champions in Jan, will be taking a Viper Powered 22 Buggy! Just wondering if any of your Team Drivers will be there that I can ask questions???
spider882009 is offline
Old 11-20-2012 | 09:38 AM
  #5932
nikos2002's Avatar
Yes, we will have several drivers at the Reedy Race. As well as some factory support, out tech office is close by WCRC. I was talking with Travis about the Reedy Race yesterday as a matter of fact. I wanted to go, but looks like I might be heading south at time of year.
Old 11-20-2012 | 12:14 PM
  #5933
ekim628's Avatar
The Viper RC offices are 20 minutes away from WCRC and I will personally be there to support all our drivers. My email is [email protected] if you guys need to talk, thanks
Eric
ekim628 is offline
Old 11-20-2012 | 08:08 PM
  #5934
nikos2002's Avatar
Told you!!!
Old 11-21-2012 | 03:43 AM
  #5935
This is why i love viper, you guys are super helpful Truck worked fine after i cleaned the ports and took a pair of pliers to the bullet connectors.
Old 11-21-2012 | 06:44 AM
  #5936
PREACH ON Brother Hash
Bob Barry is offline
Old 11-21-2012 | 07:39 AM
  #5937
FLHX1550's Avatar
Just a FYI
Recently I have seen some cases of people having sensor wire issues (not with just our wires, but all brands)
Take a moment when you instal your ESC and motor to fasten the body of the senor wire down. Just a Zip Tie, clamp, etc.... that is a inch or two from each end of the wire.
I see the plugs get wore out or the wires fatiguing at the plug from the sensor wire moving up and down with tracks with big jumps or that are rough. It's not a big problem, but I have seen it get to the point of causing a car to cog and/or stop completely. What's worse is that It can take things to the point of ruining the plug on the motor to the point where the sensor wire won't stay plugged in. You would then have to replace the sensor.
FLHX1550 is offline
Old 11-21-2012 | 02:53 PM
  #5938
ekim628's Avatar
Happy Thanksgiving from all of us at Viper RC Solutions / ARC USA. You know its easy to forget what we are thankful for in our busy lives. At Viper we will never forget how thankful we are for our customers and our team drivers all over the world.
In observance of Thanksgiving Day in U.S. we will be closed on 11/22-11/23. Our email will be available so if you have questions please email us at [email protected].
ekim628 is offline
Old 11-21-2012 | 04:20 PM
  #5939
nikos2002's Avatar
Of course we will also be on rctech!!! BTW, rumor is some awesome deals for Black Friday -- but we are not supposed to talk about it here. Might want to sign up on the shop site in my sig.
Old 11-21-2012 | 09:00 PM
  #5940
nikos2002's Avatar
Just wanted to note that our friends at A Main Hobbies are going to have some really good Black Friday Deals -- if you know what I mean!!
