Viper RC -
#6077
Yes I am. I did have to change the response to NORM on the 4PKS. I was getting some glitching every now and then. It was like the receiver was getting interference. Once I changed to NORM in the radio I have had 0 issues. I dont think it was the speedo/receiver/servo issue more like a radio/receiver issue.
I am running a V10 red version and 8.5t motor.
I will post my settings up soon.
I will try that norm setting then i wont have that issue anymore...
on the viper note ....Love it LOL .... A55 is the cats meow .....17.5 boosted in a sct ....Iam 3 for 3 on TQ and wins in the 17.5 sct class at the local series in Bellingham WA Mikes RC world ..we getting on a Avg 150 entry's
I run viper in all my electric cars ......
#6078
Turned out I my steering expo got turned up to 100% lol
#6079
Trying to figure out what happened to my VTX10 this past weekend. On two of my heats, when it came off the track the top 3 lights were blinking yellow and the ESC wouldn't turn off using the button, I had to unplug. On those runs, the transponder also missed laps. Is there a guide to error codes for this ESC or can anyone help on what happened?
I don't have the manual here with me, but I believe that there is a listing of 'error codes' in it. I will dig mine out tonight and see if I can find yours unless someone else chimes in first.
Edit:
Found the manual online here --> http://www.viper-rc.com/pclink/updat...manual_A55.pdf
I don't see your error code though so I think we need to get one of the other guys to assist. Here is what it shows in the manual
Motor Temperature Cut Off:
Parameters from 160 Degrees to 270 Degrees (10 degrees incremental).
Motor temperature cut activation is indicated by blinking “F” and “R” LEDs.
ESC Temperature Cut Off:
ESC temperature cut activation is indicated by blinking “F” and “R” LEDs with solid “N” LED.
#6081
Brad, what kind of car and motor were you running. That is pretty strange - we don't have 3 yellow lights on the VPort - did you mean all three lights were blinking?
Can you tell us what your battery cut off, esc temp cut off, and motor temp cut off were set at?
#6083
naffer- I tend to agree. One thing I have seen especially with the top guys at big events - where you push the envelope a little. You can be right on the edge with the temps and when you come around after the race and stop, and that air stops flowing through the car - that little extra temp build up can trip the cut off. So knowing the settings, etc can help confirm it.
#6087
There are no issues with our systems and any radio company. I have used Futaba for two years (pretty sure Dave does as well), Spektrum before that. Josh uses KO, Eric uses Radiopost, Travis runs Airtronics. So there are no compatibility issues.
#6088
Ditto. Running Futaba exclusively with two VTX10s with out issue. One on A30 software and one on A55 software. Couldn't be happier with the Viper ESCs.
#6089
Experienced by many with all sorts of different combinations, including Chad Due (4pk Super, LRP Speedos, Futaba Servo), myself (4pk, Viper, Savox), etc....
The Futaba team over night-ed us some new 614FF receivers, still had the same issues. In the faster modes at least. I ended up running my 603 receiver and was fine. Like I said, some people just switched to NORM mode and were OK also.
However it IS NOT a Viper issue, it was happening amongst 15 people with every known combination of equipment. Wasn't isolated to anything other than 614 receivers.
4Likes
