Like Tree4Likes
Viper RC -
Old 04-11-2013 | 08:10 PM
  #7576
nikos2002's Avatar
ryan - fan-- maybe, not necessary, but if running outside in high heat, every little bit helps. I don't know if if would let you gear up. But it should give you a extra sense of comfort.
nikos2002 is offline
Old 04-12-2013 | 02:46 AM
  #7577
OMG23RC's Avatar
guys i got my vtx10r and 8.5 combo today and i'm loving the esc and motor. It's great!
OMG23RC is offline
Old 04-12-2013 | 04:21 AM
  #7578
DustinH's Avatar
Oh yeah!
DustinH is offline
Old 04-12-2013 | 06:20 AM
  #7579
I stopped my truck on a decline and it started rolling, but because it was rolling i couldn't reverse and the front end went into water for about 4-5sec.
I am letting the truck dry out for a day or two but I am worried it will continue to have electrical issues. When I hold down the start button on the v-port it runs, but as soon as i release it, it shuts off as if there is something permanently damaged. This speed control is supposed to be waterproof so I am pretty annoyed that it is having these issues (even the fan is still working fine).
Given my description, do you have any guesses as to what the issue might be or what I can do to fix/diagnose the issue?
boostem is offline
Old 04-12-2013 | 10:18 AM
  #7580
nikos2002's Avatar
Which speed control are you using? The VTX10 (original orange) series is fully epoxy sealed and considered waterproof. Copperhead and Black Edition do have epoxy in them but are considered water resisent not water proof.
Water and electricity don't mix no matter how much you try. Some things to check would also be different receiver and batter as water can also effect them. Put anything that has been in water in a bowl and cover it with rice for a day or so to see if the rice absorbs any water.
Old 04-12-2013 | 10:24 AM
  #7581
Wildcat1971's Avatar
+1 to the rice thing. but yeah, I would never get my RC's near water. I dont car if stuff is water proof or not.
Wildcat1971 is offline
Old 04-12-2013 | 10:37 AM
  #7582
Whats a good starting point for 10.5 on a low to med bite track. I am starting with profile 2, 70% punch, 12000 throttle pwm, dynamic brake disabled an the rest is stock settings. I am looking to soften the bottom a little so I can get the power down and not wheel spin. I also realize my trigger figure is a large part of it, lol.
Old 04-12-2013 | 10:59 AM
  #7583
go to 60% punch and 16000 pwm and try that first
Bob Barry is offline
Old 04-12-2013 | 01:13 PM
  #7584
ok, will do. so I was going in the right direction, maybe just go a little more.
Old 04-12-2013 | 01:20 PM
  #7585
profile 2 default setting should be 16000 and 60%. Usually you just need to tinker with the brakes to get the feel you like.
Old 04-12-2013 | 01:29 PM
  #7586
hmm, really? I know 8 is 60%. It could be. I might have messed with it a while back. A reset to defaults would be a cool PG feature. I know you can do it on the PC and I might tonight, lol.
Old 04-12-2013 | 08:31 PM
  #7587
nikos2002's Avatar
Be careful of how much power you wish for the ProGauge
Old 04-13-2013 | 01:45 AM
  #7588
OMG23RC's Avatar
Nikos i followed your gearing of 21/81 and my vst 8.5 is slower then a 4 year old novak? Anyhelp?
OMG23RC is offline
Old 04-13-2013 | 08:51 AM
  #7589
what's the rest of the settings? That gearing should be on point but the ESC settings can really make big difference.
Old 04-13-2013 | 11:19 AM
  #7590
check your temps, if they are good boost it a little
