Like Tree4Likes
Viper RC -
Old 04-13-2013 | 01:14 PM
  #7591
Originally Posted by Wildcat1971
check your temps, if they are good boost it a little
rule of thumb, don't ever suggest boost until you know all the settings.... if he has something off and throws boost on, then he cooks something, he isn't gonna be happy LOL.
I agree, boost will work wonders, BUT you can't perform surgery without triage.... need all the details before cutting in
Bob Barry is offline
Old 04-13-2013 | 01:17 PM
  #7592
Wildcat1971's Avatar
meh, just boost it. Be a man and apply moar powa
Wildcat1971 is offline
Old 04-13-2013 | 01:22 PM
  #7593
nikos2002's Avatar
Originally Posted by OMG23RC
Nikos i followed your gearing of 21/81 and my vst 8.5 is slower then a 4 year old novak? Anyhelp?
Ok, so PM me the settings and also let me know what the esc and motor temps were when you ran it. Only taking a guess at a gear ratio from the other side of the world.
nikos2002 is offline
Old 04-13-2013 | 09:01 PM
  #7594
ok so how do i reverse motor direction on vtx1.....i have it in a dex210 i just got and it is always reverse. Changing it in my radio doesnt do anything other than make my reverse on the radio make the car go reverse but then there is no forward.... ugh
hellssephiroth is offline
Old 04-13-2013 | 09:05 PM
  #7595
nikos2002's Avatar
There is not a reverse motor setting in the vtx1. If you are running the mid motor set up you need to run the 4 gear transmission, that will spin the correct way. That's how I do it with my X Factory!!!
Old 04-13-2013 | 09:07 PM
  #7596
is that a whole new transmission i have to buy .....
Old 04-13-2013 | 09:33 PM
  #7597
OMG23RC's Avatar
I just have it set on profile 2. But even though my motor is a bit slower I'm still winning so don't worry. Also is this ok for temps 60c for esc 75-80c motor?
OMG23RC is offline
Old 04-13-2013 | 09:39 PM
  #7598
silvalis's Avatar
DEX210 kits come with parts for 3- and 4- gear transmissions for both RM and MM configurations. Not sure about the RTR version.
silvalis is offline
Old 04-13-2013 | 09:43 PM
  #7599
Ya i have the rtr won it in a raffle so i guess its not a total loss if i don't figure it out. Just sucks i dropped a bunch of dough on new electronics and now i cant use it
Old 04-13-2013 | 09:55 PM
  #7600
silvalis's Avatar
Are you having issues with 3-gear RM? Or did you buy the MM bits and convert to a 3-gear MM? AFAIK you should only have this issue with 4-gear RM and 3-gear MM.
silvalis is offline
Old 04-14-2013 | 05:23 AM
  #7601
bds81175's Avatar
Moderator
To be honest, unless you are running on manicured grass, carpet, or super high bite blue groove, the rear motor configuration is probably going to be better anyway.
bds81175 is offline
Old 04-14-2013 | 05:44 AM
  #7602
actually someone at my track though it was a brilliant idea to cover our ramps with that no slip floor protector tape stuff and it rips through plastic like hot butter. I ran it for like 2 minutes with the stock stuff and already it looks like it wont take long to eat the plastic motor guard. Thats the only reason I wanted to change it honestly, it just grinds across and makes for some really crappy jumping
It is a carpet track as well so i wanted I try it.
Old 04-14-2013 | 05:47 AM
  #7603
Oh and the rtr came with the parts to convert to MM but it did not come with extra gears to do it. Oh well I will just 3 gear it and see what happens.
Old 04-14-2013 | 09:18 PM
  #7604
sickpuppy1's Avatar
going to bed now, but any known issues between VTX8 and the tenshock 411 4 pole 550 motors?
have a hobby wing sct pro and it worked fine, but set it up on the VTX8 and it wont move. double checked radio calibration and swapped sensor wires but it will not move the motor and all. Have not tried a different motor as its 1115 here and I get up at 515am so......I'll chk back in the morn, thanks
sickpuppy1 is offline
Old 04-15-2013 | 04:29 AM
  #7605
xrayrc's Avatar
Make sure motor is sensors and your in the
Right profile number 4 I believe is for 4 pole motor
And 2s lipo default is profile 1 for 1/8th scale
xrayrc is offline
