Like Tree4Likes
Viper RC -
Old 08-06-2012 | 12:41 PM
  #5206
Originally Posted by bds81175
I can't remember if you mentioned it or not...what motor temp cut off are you running at? If you were at 136° you can add 50-60° onto that for the internal rotor temp which is what you set the threshold to. I found that out too. Adjusted it to 220° and haven't had an issue with it yet. Your motor temp seems kinda high after 3 minutes too. I was a bit undergeared but I finished my 7 minute main with my B4.1 with an 8.5 T at 113°. Ambient temp here was only about 78° though.
I'm not sure what motor temp. I am running the stock profile 1 settings. which is 17.5 blink mode I didn't change anything. I will look with my pro-guage tonight, and test another servo.
Yea 136 seemed kinda hot to me too. I'm running 77/28 gearing which is the lowest that will work per the HPI blitz manual without going up to 83tooth spur. I overheat everything in my backyard not sure why..its really loose dirt and all my vehicles overheat back there, doesn't seem to matter what gearing...so it probably won't get so hot at the track. The HPI manual recommends 77/28 as a starting for 17.5 turn motors. and shows 28-34 or something as pinions to use. Can't drop the pinion from 28 without going up to a 83t spur
KTMDirtFace is offline
Old 08-06-2012 | 12:44 PM
  #5207
AndrewTom's Avatar
i am running my XXX-SCT with the viper vtx10r and vst17.5 motor
i am at 15 deg. on the can, 3000 boost start, 12500 boost finish, 36 deg.
17 deg./1000 rpm and 38 deg top speed timing. no temp issues here.
im running 21/84 but i could go up to 22/84. i just put the tlr tuning kit in my truck, which brings the final drive from gear diff 2.19:1 to the ball diff 2.43:1 trans
ktm dirtface, i would try turning bach timing on the motor to 15 or 20, if you haven't already.
AndrewTom is offline
Old 08-06-2012 | 12:50 PM
  #5208
spider882009's Avatar
Any word on the 1/8 Scale ESC and Motor??? Big races coming up soon in Sept. I've been holding out on a system in hopes that all my 4 vehicles could be Viper powered. Right now Mod 2WD SCT, Mod 4X4 SCT, and 2wd 1/10 Buggy. Just need a system for the E-Scale!!!
spider882009 is offline
Old 08-06-2012 | 01:01 PM
  #5209
Is that the indicators on the side of the can? I think it goes 15, 30, 45.. i think it came at 30 from factory.
Old 08-06-2012 | 01:27 PM
  #5210
Originally Posted by KTMDirtFace
Why do you think it glitches with the vtx10r? is this a known issue?
It doesn't glitch at all with my viper copperhead.
I don't buy random powercaps/glitch busters...if it needs that I'll get a ESC that works correctly and sell this one.
This is known... and not just with the VTX10R. It's not a problem with the ESC. Savox servos just draw more current than most others. Couple that with a spektrum receiver, and you're in for glitching and cut-out. It's not broken or the end of the world. It's all part of making multiple manufacturers' items work together.
If you want everything to be exactly the same, 100% compatible without any effort, Traxxas makes a FINE line of beginner gear.
NetFryer is offline
Old 08-06-2012 | 01:39 PM
  #5211
Scottmisfits's Avatar
Nik, I never knocked the line. Just said that it is a known issue that you guys are working on.
Netfryer, it's not just Savox servo's. It may come up with the Savox more often but it's not limited to them by any means.I have seen in with KO, Hitech, and Futaba servo's as well. Hopefully the black editions will all but solve these issue's. I want to see these things fly. They are a great ESC. We just can't seem to give them away in our area right now. When I had them work for me, they were fast as hell.
Scottmisfits is offline
Old 08-06-2012 | 02:26 PM
  #5212
nikos2002's Avatar
KTM - use the progauge and check what the motor temp cut off is set at. That can cause a motor to shut off if too low. Its a measurement of the inside of the motor - not the outside like we do with a temp gun. Something to check. because we were racing in 90+ degree heat geared 75-28 for 5-7 (with warm up laps). When racing - you can disable the setting and rely on the your own measurements - its a drivers choice. Only time I temped my motor all weekend it was at 161 after 1st round of qualifying.
nikos2002 is offline
  #5213
Lol @ Traxxas comment. Well I have a few things to test tonight I'll report back. ( first going to try HPI Radio/RX, then HPI Servo, may also try no servo at all ...thinking back it seems like it reboots itself when going from fullspeed to full brakes as it reboot itself every time I was pulling the truck into my driveway and slowing down yesterday, never had it reboot out in the middle of the street on me )
Old 08-06-2012 | 02:31 PM
  #5214
nikos2002's Avatar
Smyka laid some more knowledge on me --- we actually had 2 complete Viper Copperhead systems in the 4wd Modified SC A Main, plus another driver just using our VX4 Copperhead motor.
So 4 of the top 11 4wd Modified SC runners at the SC Nationals were running Viper Copperhead systems. Nice
4wd Modified - based on qualifying
Mark Smyka - 5th - Copperhead/R45
Zac - 6th --using Mark's spare R45 motor (sorry didn't get last name)
Joe - 10th using Copperhead system (sorry didn't get last name)
Mike Aliberti - 11th - Copperhead/R51
Old 08-06-2012 | 03:19 PM
  #5215
So*Cal AFDude's Avatar
Is there a temp cut off for the copperhead system? I know where to find it on the progauge for my vtx10 and 10r but do not see it when i plug it into the copperhead. I had it cut off twice on be during a race because of thermal. It wasn't super hot, but the esc and motor were both on the warm side. (in a Losi SCTE)
So*Cal AFDude is offline
Old 08-06-2012 | 06:11 PM
  #5216
Thing I have noticed with mine is from time to time when my truck feels overly hooked up OR really loose (lots of wheel spin) its best to knock the punch and timing down a level or 2. Had it thermal on me a couple times but always ran well with new settings. Also make sure your spur gear is clean had some really packed in dirt deep in the spur wd40 and a tooth brush lowered my temps by 10 degrees over very little debris in 2 tooth valleys. I always roll my truck to feel for grit if its there get it out.
mugenlife is offline
Old 08-06-2012 | 07:17 PM
  #5217
nikos2002's Avatar
With Copperhead, the longer your races are (total time running) and how hard you drive on the throttle can effect the heat. Yes turning timing or punch down a little (or both down a little) can effect how heat builds up. There is a big difference between a driver who uses the throttle "correctly", by using the trigger to increase throttle as you accelerate, as opposed to someone who just mashes full throttle and actual speed as to catch up. Its all part of that big jig saw puzzle we put together with our set ups.
Old 08-06-2012 | 07:23 PM
  #5218
hyperdesigns's Avatar
Had the same problem with my system also. I dropped to a 11t (TeamC TS4)and changed the fan!!! Never thermaled again but it dose cut out sometimes. Not sure what that's all about.. Going to install a cap and see if that helps
hyperdesigns is offline
Old 08-06-2012 | 07:35 PM
  #5219
I have a VTX10 with a 10.5 in my buggy but the motor will not turn. Things I have checked.
Known good sensor wire
Reflowed all joints
Different motor
Recalibrated esc
The lights where the pro gauge plugs in light up correct with throttle and brake. Thanks for any help Rusty.
blue t is offline
Old 08-06-2012 | 08:14 PM
  #5220
Well now I can't reproduce the ESC Rebooting issue .
Guess i'll take a couple servos and an extra radio to the track this weekend and see if I can figure it out there.
