Viper RC -
#5356
Tobz - the new Black Edition esc's are sold seperately, not in combos. They are out:
http://www.amainhobbies.com/product_...ESC-w-ProGauge
Congrats on the results Rick and Dan!!!!!!
#5357
It is really smooth and runs great, As far as I understand is that the esc "VTX8" might be ready soon but not the motors yet. If I hear anymore I will let you now. I was running a RX8 and Viper 2 pole motor and I like the Viper better mostly of the pro-gauge ease
#5358
the pro gauge is super easy, i'll have to give you that one. by far the easiest programming of an ESC i have ever seen
#5359
Bugger, looks like i'll be better off just getting the combo, much cheaper and not much difference from what i can see, and equipped with bullet connectors. much easier for me to grab the combo and bung it in, not too fussed on the pro gauge, i just like to set it up once and not muck around with fine tuning.
#5360
Couple questions
1. What is a good starting range for throttle and brake settings for 2wd mod buggy with a 7.5 and what about a 10.5?
2. When setting up the speedo, i have a spektrum dx3r pro, what do i set for epa? It says 100 percent but on the controller both epa and throttle go to 150. So if i set it with epa and 100 would i not be getting the right setting since its lower than the 150 that is max? Hope this makes sense, just want to make sure im getting full throttle and brake.
3. How does the motor power work and is that similar to the boost on the tekin?
Dave
Dave
#5362
Hey Rick, I'm gonna try to explain it from what I understand.......lol
Jump in here if I'm wrong Nick!!!!
The Copperheads come in 3 different combos. The only one that comes with the Copperhead esc is the 3900kv motor combo. The 4500 and 5150 come with the Copperhead-R esc.
Here's the differences:
Viper Copperhead
Continues/Burst Current:100A/550A
BEC Output:6V/5A Linear
ON Resistance:0.0009Ω * 2
Support Motor Type:Sensorless Brushless Motors
Support Motor Spec
2S Li-Po w/ 540 class: KV ≤ 6000
3S Li-Po w/ 540 class: KV ≤ 4000
Support Vehicle Weight: ≤6 lb
Motor Connection:3.5mm Bullets
Dimensions:45.5x39.8x29.25mm
Weight (with battery wires and connector): 96g
Viper Copperhead-R
Continues/Burst Current:150A/750A
ON Resistance:0.0005Ω * 2
Support Motor Spec
2S Li-Po w/ 550 class: KV≤6000
3S Li-Po w/ 550 class: KV≤4000
Support Vehicle Weight: ≥6 lb
Motor Connection:4.0mm Bullets
Weight (with battery wires and connector): 98g
Basically, from what all of this info tells me, it says don't put the Copperhead into a Losi SCTE!!!! You better use the Copperhead R...... and it has a cool looking little R on the speedo too. I think just the R on it makes it faster!!!! Gotta say that the Copperheads are some of the best looking esc's out there. Very pretty.
Here's the link from where I copied and pasted all this from:
http://www.viper-rc.com/vx4.html
Viper Copperhead
Support Motor Spec
Viper Copperhead-R
Support Motor Spec
#5363
Couple questions
Dave
Dave
My experience especially with spektrum keep it at 100..Good example, if u have it at 150 your full throttle would be around mid range on the trigger. I helped a friend with his viper/spektrum combo and this is what i found.
#5364
Viper Copperhead
Support Motor Spec
Viper Copperhead-R
Support Motor Spec
Viper Copperhead
Support Motor Spec
Viper Copperhead-R
Support Motor Spec
I just picked up the Cooperhead 4500kv combo for Project SSC Slash (dont have an official name)
I just went and checked. my ESC does indeed have a little R to the right of where it says Copperhead.
#5365
Thought I'd share some good news to all of you guys!!!! If any of you are in the same boat, it's nice to know that good things do come if you stick at it!!!!
Now, back to rc...........................
Last edited by DanielHolloway; 08-20-2012 at 03:11 PM. Reason: sarcasm type hinting
#5366
Just signed up for your giveaway Cable! Sure would love to be able to get a truck for my son!!!! After a 4 year fight, I finally got full custody of my 11 year old!!!!
If you don't win one of these 12, we have a raffle coming up in a few months with a bunch of vehicles. Could always buy a ticket for that when they come up for sale and try your luck then.
#5367
good deal. i wish you luck. you can come back and enter once a day to increase your odds of winning as well.
Trying not to get a too OT, but i signed up for the car giveaway, the page refreshed and didn't give me any confirmation of being entered into the contest, how do i know my entry worked?
#5368
well i am glad to report that my vtx10r black edition worked perfect in my desc410 with the vst 4.5 550
i raced this weekend in 110 degree weather and never had a problem super smooth and fast out running those pro4's down the straight
#5369
Well this past weekend I just put a VTX10 w/ 8.5 thru one very mechanical test that alot of others quit on. I ran 157 laps over 3 rounds (2 Heats and 1 Amain) of oval racing this past weekend in a Mod SCT XXX-SCT. It came off the track in great shape!!! Motor came off @ 140 Degrees and ESC @ 98 Degrees!!!
#5370
4Likes
