Like Tree4Likes
Viper RC -
Old 05-09-2012 | 10:59 AM
  #4606
Andybellus's Avatar
Originally Posted by FLHX1550
I have run the R.51 allot in my SCTE (which is a little heavier) but I think has a little less drag that the SC10 4wd, but my roll-out is a 1.09 (using a 3.89 Trans Ratio with 40/13).
Your gearing has your at a 1.06 (2.57 trans ratio and 62/13), so if anything it is a tad under-geared.
What I am thinking to to have you try is to turn down that timing to 2, and maybe the punch to 2 or 3, and start power up to 6.
On my truck on a real big track I was running the following and have had zero cogging / stalling with this setup.
Punch 3
Timing 1
Start Power 6
Thanks I'll give those settings a try and see what it does next Monday @ the track. For the record I've had no cogging/stalling, when not having problems like completely turning off and thermaling, it's been very smooth for a non sensored setup(unlike my MMM in the SC8e).
Question what is the optimum roll-out for this motor?
FYI, I came up with the following on my current set up. (4.30*3.1416=13.5088) /(( 62*13= 4.7692) * 2.75 =13.1153)= 1.0300
Not sure I want to step up a pinion as I don't need any more top end on my local track as I'm plenty fast on the straightaway and there are alot of tight turns.
Andybellus is offline
Old 05-09-2012 | 11:03 AM
  #4607
Andybellus's Avatar
Originally Posted by ekim628
Hey Andybellus,
Can you try the setting recommended by FLXH1550 and if your still having trouble you can call 1-866-206-8558. I am local as well so if you just let me know when you will be at the track i can bring an extra system to see whats going on. Please let me know and we will get this sorted for you.
Eric Kim
Thanks Eric, called that number yesterday, no call back as of yet. I will try those settings and will likely make it out to WCRC Monday for practice around 3:00. If your able to make it out there that would be great! Hopefully I have it figured out prior to then so I can work on getting some consistent laps in.
Andy
Edit, I'll get the temp gun out this time!!
Old 05-09-2012 | 12:23 PM
  #4608
symmetricon's Avatar
Andy
Just out of curiosity, what are you batteries reading for voltage after it shuts off?
symmetricon is offline
Old 05-09-2012 | 12:55 PM
  #4609
ekim628's Avatar
Andy
Yes for sure PM me and keep me updated, the phone lines get jammed at rush hour so you might of called when it was tied up. Phone calls come all at once and i can only switch over to one other line.
PM me when you can
ekim628 is offline
Old 05-09-2012 | 04:05 PM
  #4610
Andybellus's Avatar
Didn't pay attention as I was pretty frustrated and just packed up and went home, but I'll be keeping much closer tabs on everything, battery voltage, motor/ESC temps with IR gun and will also be installing the temp sensor telemetry before I hit the track again. So have all the data to get this resolved!!!
Old 05-10-2012 | 09:19 AM
  #4611
nikos2002's Avatar
Andy, sometimes if you have run several laps the amp draw on the batteries can get pulled to low - the system thinks it needs to shutdown. It can happen on batteries with un balanced cells or that one cell is weaker than another (happens with older batteries). That is where the lower settings Dave sent you might help - less spike on the amp draw. Keep us in the loop.
nikos2002 is offline
Old 05-10-2012 | 07:14 PM
  #4612
Andybellus's Avatar
Will do, thanks for the info and with this type of support I have no doubt my issues will be resolved user error or not
FYI, all battery's are less than a month old with very little use and always balanced charged.
Does anyone have the optimal run-out # for this motor?
Old 05-11-2012 | 07:14 AM
  #4613
FLHX1550's Avatar
I would shoot for a 1.06-1.10
I calculated you at a 1.06 (I use 4.15" Dia in my calculations, you said you used 4.35) and I run about a 1.09. I think you are right in the right area, I just think you should try turning down the timing / punch some.
FLHX1550 is offline
Old 05-11-2012 | 10:16 AM
  #4614
nikos2002's Avatar
I had a great time at Gallimods RC last night, who would have thought it would be so cold in May! But it was a good first outdoor race of the year. This place had a ton of traction from all the rain we have had recently. I could have TQ'd the 17.5 SC class, but choked on the last lap. The VST 17.5 was moving last night!!
Old 05-11-2012 | 10:41 AM
  #4615
Default Viper RC!!!
These guys are awesome! Fed Ex attempted to deliver my motor. The guys are on their way to pick up my motor from Fed Ex! Top notch guys!!!
Most other guys would just wait for them to try to redeliver at a later date.
Thanks for your efforts!!!!
Michael
AfterTithes is offline
Old 05-11-2012 | 11:11 AM
  #4616
84 GT 5.0's Avatar
I'm running a vtx10r and when I apply the brakes at speed it stops on a dime. When I'm barely cruising say 10 MPH and below the brakes suck ass and are almost useless is there a setting I can adjust to fix that
84 GT 5.0 is offline
Old 05-11-2012 | 02:22 PM
  #4617
nikos2002's Avatar
What is your brake strength, brake frequency and brake curve - on the ProGauge? You aren't running throttle expo on your radio, are you?
Old 05-11-2012 | 07:20 PM
  #4618
blade072's Avatar
got the pc link adapter the other day......and have now updated the vtx10
thanks nikos2002
blade072 is offline
Old 05-11-2012 | 08:30 PM
  #4619
I'm having some issues updating via PC link. The file is a VUF file and I don't know how to open or extract the file. I'm using a Samsung netbook with windows 7 starters edition. Any info will be great. Thanks in advance.
Hpifanboi is offline
Old 05-12-2012 | 03:44 AM
  #4620
FLHX1550's Avatar
The VUF file is the file for the esc itself, once you open the pclink software, you will connect the USB cable to the esc, then select PORT 0 USB. Then click FILE and it will ask you where the VUF file is at.
After you have the port set, the file set, you will plug a battery into the esc, turn on your radio, then turn on the esc. You will then set the esc in link mode, and you should see on the PC the old firmware. You can now click DOWNLOAD and begin the update.
When its complete, the esc will cycle and chime, then you can unplug and you are now updated.
Fyi - remember that you will loose your old settings, so you need to reset your temp settings for your profiles.
FLHX1550 is offline
