Like Tree4Likes
Viper RC -
Old 11-22-2011 | 07:53 AM
  #3106
stu541's Avatar
looking for a starting F.D.R for the 17.5 non boosted in team C SC truck. & also if I can put associated spurs and pads on without mods? 75/24 would be nice.
stu541 is offline
Old 11-22-2011 | 08:27 AM
  #3107
nikos2002's Avatar
You can modify a AE gear to work - I am sure you can ask on their thread for the details - you have to, they don't make the correct spur gears for 17.5.
nikos2002 is offline
Old 11-22-2011 | 08:30 AM
  #3108
tkge's Avatar
Default Pro Gauge
If you save over a profile on the pro gauge, can you reset it back to factory later on?
tkge is offline
Old 11-22-2011 | 08:35 AM
  #3109
Default Gearing help please.
Ok guys,
I have my 2wd sorted out. Runs great and stays cool. Thanks to all that helped out with settings.
Now I need help with my 4wd. I run on an indoor carpet track.
I am running a VTX10 ( A23 ) and a VST13.5
I run a Caster SK10. It has an 80T spur and a gear ratio of 2.437.
I tried it in blinky mode with a 30T pinion. It performed ok, but temps were a little high ( high 165*+ )
I then tried in Profile 3 ( boost ) with a 25T pinion, again performance was ok, but temps were up there.
Here is a vid of the current layout.
http://www.youtube.com/user/tsan76#p/u/1/H7nhkOrGbM0
Any help would once again be greatly appreciated.
Thank You
Jamie James is offline
  #3110
nikos2002's Avatar
yes, the notes of the set up are on the instruction sheet. Or if you ever update the software with the PC Link, it resets to default settings as well.
Old 11-22-2011 | 12:36 PM
  #3111
idrummerboy13's Avatar
Originally Posted by nikos2002
maybe, if not you will see the logos on all my stuff.
Going to try and make it today, but can't guarantee it, I will be there in the next week or so...
couldnt go today, ill be there close to every friday possibly sunday racing
next week i get my viper stuff anyway!
idrummerboy13 is offline
Old 11-22-2011 | 01:33 PM
  #3112
BashemSmashem's Avatar
Been a while since SaladFork has been on this thread anybody know whats going on with him ?
BashemSmashem is offline
Old 11-22-2011 | 01:57 PM
  #3113
losi_racer's Avatar
He just doesn't come on rctech much anymore . You can head over to viper forums and pm him there or if you have any questions you can post on the forums , http://viper-rc.com/forums/
losi_racer is offline
Old 11-22-2011 | 03:39 PM
  #3114
smyka's Avatar
Jamie is their a reason you only run 13.5 in a 4wd ? But I run off road carpet all the time run a Losi in 2wd b44.1 4wd I run a 6.5 on profile 3 geared 18/74
smyka is offline
Old 11-22-2011 | 04:20 PM
  #3115
Did you look at the vid I posted? The track is way too small for an 6.5 Most run 13.5 in both 2wd & 4wd...the odd 10.5 is there too.
Old 11-22-2011 | 04:38 PM
  #3116
smyka's Avatar
Yes I did our carpet track is about same size 90/40 we run shuie mini spikes 4wd we run 6.5 or 7.5 2wd most run 13.5 boosted just so it don't pull wheelies
smyka is offline
Old 11-22-2011 | 05:03 PM
  #3117
So*Cal AFDude's Avatar
Also I realized I had it on profile 1 with an 8.5, but changed the drag brake and stuff.
Would that cause any problems.
So*Cal AFDude is offline
Old 11-22-2011 | 05:12 PM
  #3118
Need gearing and esc setting suggestions for a 13.5 in a xxx-sct on an indoor carpet track. Esc is cool motor is heating up
rtkota360 is offline
Old 11-22-2011 | 07:15 PM
  #3119
i am looking for the amp draw of the vstXL 5.5 turn 550 class motor it will be in a losi scte, can someone please help me with the answer
thanks
calo247 is offline
Old 11-23-2011 | 06:09 AM
  #3120
FLHX1550's Avatar
Gearing - 25/88 or 26/88 (depending on how tight the track is)
Start at zero Accel Timing (A.T.) and zero Top Speed Timing (T.S.T)
Can Timing - 30 Deg
Power PWM Freq - 4000hz
Mode - Race-Mod
Start RPM 7000
Finish RPM 13000
Brake Linear
Drag Brake 15%
Brake PWM - 2000-4000hz
Test 2 min, check temps. If temp is good, run to the 4 minute mark, check temps, if still good run to 6 minutes and check. Temps should be quite reasonable.
If you need more in-field power, add A.T. - start at 4 deg, test temps in 2 min intervals. If you need more infield power, add another 4. Repeat testing.
If you need more strait speed, add 2-4 deg of T.S.T. and test temps as above.
Remember, the VTX esc will combine all of the timing together (both your AT and TST)
I have seen several threads here referencing profile #3, and that is fine, but be aware that some of the profiles add allot of timing. For example, #3 is 30 Deg AT and 20 Deg TST, combined with a stock VST motor timing of 30 Deg, you are running a total of 80 DEGREES OF TIMING. This setup, irregardless of gearing will be sensitive to temps.
When running boost, the theory is to gear down with the more boost you use. Because the lower gearing lets you have more punch, while the boost will let you get your top speed back due to the lower gearing.
FLHX1550 is offline
