Like Tree4Likes
Viper RC -
Old 12-05-2011 | 04:39 PM
  #3256
Well got new sensor wire still having problems with it might send it back and try something else..re did everything..and nothing still get the same issues really want to get this running
ohhhwee is offline
Old 12-05-2011 | 04:56 PM
  #3257
Bobby Z's Avatar
Have you called Viper tech support? Quite often you get better results talking to someone instead of trying to use the forum to troubleshoot
Bobby Z is offline
Old 12-05-2011 | 06:47 PM
  #3258
rider313's Avatar
Took a dissapointing third in 2wd sct this past saterday. The Viper powered TLR XXX-SCT was dialed. In the A main with two minute to go I was swapping positions with the leader and my voltage cap came unstuck causing my power hungry savox servo to drain the speedo if it pulled to much load. So I needed to back off to avoid this.
Next time I will have better results to post.
rider313 is offline
Old 12-05-2011 | 07:10 PM
  #3259
larlev's Avatar
Trying to program with Progauge...push and hold red button for 1 second with progauge connected and get nothing. If I hold longer than 1 it goes into calibration. Now when truck is turned on it experiences runaways. Did calibrate
What am I missing? Have to be doing something wrong.
larlev is offline
Old 12-05-2011 | 07:12 PM
  #3260
call me
bring it on is offline
Old 12-06-2011 | 08:33 AM
  #3261
Yeah I called them and there stumped so I'm re doing all my wiring just to make sure before I call back again or send it back..
Question I beep test the motor with a tester conductivity when I test the A/B/C on the motor all beep and there like touching like there's bridge.. example if I put the tester pin on "A" and put the other tester pin on "C" it beeps..it does it for all ABC..A/B beeps C/B ect..beeps this is normal? I didn't melt the solder inside the motor were they probably touching each other..I don't want to open the motor up might break it or something.
Thanks *
ohhhwee is offline
Old 12-06-2011 | 10:05 AM
  #3262
Ok I re did my wiring and calibration made sure all wires are where it's suppose to be..now I'm getting a problem were it won't pass the reverse light set up it stays orange for a long time after I push forward..100% end points on my DX3R full batts on all radio/power to esc..re bind my reciver..
I'm returning it..I really like the pro gauge ..
Sorry for turning this into a support thread..thanks for helping me out guys
ohhhwee is offline
Old 12-06-2011 | 10:11 AM
  #3263
rider313's Avatar
When you calibrate turn on your radio first. Now with the speedo off press and hold the on button for three seconds. You will here two beeps. Then hold the throttle and you will hear a beep. Then press and hold break, it will beep one more time and then go to the run mode.
I have had issues befor to only to find it was my DX3R calibration was off. Try this and you should get it.
rider313 is offline
Old 12-06-2011 | 10:15 AM
  #3264
How do I calibrate my DX3R? I notice when I bind it my servo go nuts and starts to twitch I did put 5.5MS on the radio..thanks
ohhhwee is offline
Old 12-06-2011 | 10:34 AM
  #3265
rider313's Avatar
Go to the menu. Scroll down to reset. The scroll down to parameter reset. Then you will see a bunch of line gauges, turn your wheel full left then full right. Then brake full then throttle full. Then scroll down to the save button and click it. And your done.
Now proceed to rebind the VTX10
rider313 is offline
Old 12-06-2011 | 10:55 AM
  #3266
Thanks I did it is it normal for all the numbers to ends up like 1324 ect.? I tot it was suppose to be all zero or all the same even like 1222 1333 ect..
Now It don't get stuck on orange light after I hit forward it cycles and goes to back to normal. Green neutral red power S green..but when give it power the lights responds to forward/reverse input but the motor won't turn
ohhhwee is offline
Old 12-06-2011 | 11:11 AM
  #3267
is your throttle channel set to reverse or normal? try setting it to the other option from what it is currently then rebind.
cm.stites is offline
Old 12-06-2011 | 11:14 AM
  #3268
It's normal on all..I'll give it a try..
ohhhwee is offline
Old 12-06-2011 | 11:49 AM
  #3269
i believe throttle needs to be on reverse.
Old 12-06-2011 | 12:26 PM
  #3270
Tried it didn't work same problem motor wont turn just lights responds to F/R input on the radio..calibrated the radio and esc..I even tried it on my DX2 same thing..
ohhhwee is offline
