Viper RC -
#4456
thank you. now gatta work a little with the dad and i will have it setup and ready! I'm not getting the ft....I see my self just setting and forgetting about this thing and just having fun not tweaking it.
im glad i could buy something like this, cheap and i honestly only hear good things about it.
#4457
Allot of variables that go into it. 17.5 is so on edge you can be ok one round, and if they water the track you will cook it (grip went up, loaded motor more)
The VST is low on kv, BUT is very high on Watts (Torque), this formula tends to let you run more gear (I have run as high as 38/70 on a TLR 22 - Which is geared higher internally than a B4), but I was down in the 15-20 deg range of timing. You have to test and experiment.
#4458
SO my on off switch came un servotaped tonight on my vtx 10r and was ripped off.
One of the wires pulled from the board in the switch so resolder the one I have is out of the question.
How can I get a replacement?
#4460
Hey Guys here is my setup for my team c evo buggy running the vtx10 and 8.5 vst combo ...the setup works great for me on any number of tracks including indoor high bite and out door loose ....please use this as a start point if you need to get going ......
TEAM C EVO 2WD BUGGY
vtx10 esc
vst 8.5 motor
gearing 21t pinion 86t spur
motor end bell +35
ESC SETUP
profile 1
brake strength 100%
brake frequency 2500hz
brake curve linear
dynamic brake n/a
drag brake 0
thr pwm frequency 2000hz
throttle punch 100%
throttle curve linear
deadband off
accleration boost +20
start rpm 1000
end rpm 50000
top speed timing n/a
run mode race open
holeshot launch n/a
sbec voltage 6.0v
forward power 100%
reverse power n/a
auto power off 3 minutes
battery cut off 6.0v
motor temp disabled
esc temp 260
temps out at 130 motor 110 esc
vtx10 esc
vst 8.5 motor
motor end bell +35
ESC SETUP
profile 1
brake strength 100%
brake curve linear
dynamic brake n/a
drag brake 0
throttle punch 100%
deadband off
start rpm 1000
end rpm 50000
run mode race open
holeshot launch n/a
sbec voltage 6.0v
forward power 100%
reverse power n/a
motor temp disabled
esc temp 260
#4461
Hey buddies
i have been running this set up on my sc10/4x4 and it rips with no problems on overheating ...im running the 4.5r 550 system ....i have probably ran about 30 packs at this point ...not one single problem ...ok well i did have one problem ...i didnt plug the esc wires into my reciever good and it didnt power up the first time ......dooooooh.......after that its been smooth sailing .....couldnt believe how smooth it is to be non sensored .....heres my set up
COPPERHEAD 4.5R 550 SYSTEM
sc10 4x4
13t pinion 62t spur
ESC
profile 5
brake strength level 7
brake curve linear
drag brake disabled
throttle punch level 8
throttle curve +exp1
deadband norrow
motor timing level 4
run mode forward only
start power level 10
forward power level 10
auto power off 5 minutes
battery cut-off lipo 3v/cell
this thing rips its awesome temps never over 150 on either component
sc10 4x4
13t pinion 62t spur
ESC
profile 5
brake curve linear
drag brake disabled
deadband norrow
#4462
Just thought I'd drop in a quick note about my Viper powered XFactory X60. After the TQ and win last week I had a bunch of people asking me how my truck was so fast yet so controllable. Nobody believed me that I was running a 10.5 with no timing on the esc.....put it in Blinky mode. Motor came off after an 8 minute main at 100 degrees and had all the low and top end anyone could ask for. I let a couple guys drive it after the main, needless to say the shop owner had to order 3 10.5 combos for the guys. They couldn't believe just how smooth yet powerful the system was. 3 "converts" in 5 minutes of driving, gotta love it!
i ordered a viper 10.5 for it. what gearing are you using?
#4465
Jeremy- when you plug in the ProGauge - what does it tell you? Is there a software program listed? Does the steering work properly?
aprilliamille - I ran 86/23 with a 9.5 last year, maybe 24-25 depending on track with a 10.5. Don't forget to check temps when you start out to help verify.
Mugen - Congrats, not to shabby....
#4466
Steering works, can't go into programming mode.Oh and it is on a30. Tried a different motor still the same. Put in a buddies 10r with the original motor everything was good. You know how it beeps but will not go through the whole "song" if the radio is not on? it does that too. I could not re-calibrate to my radio. A viper sponsored driver told me that he had the exact same problem and was told it was a loss of memory on the esc. Also I can't turn it off once it is on.
#4468
Try this:
Plug in the battery, power on the radio, turn on the esc. If it is still not syncing with the radio, then unplug it from the receiver while it is still on. You should get the "N" light then. Take it to programming mode and plug in the ProGauge and link it. You will probably get something that says "Profile ##" or something like that. Try loading a different profile and save the settings.
Once you have done that, power it down. Unplug the battery for a coupple of minutes. Hook it to the receiver and go right into calibration and re-calibrate.
#4469
Took the TQ and Win this weekend in 2wd SCT in Staples, MN for the Minnesota Off-Road Series. Thought I would post my setup for people to use. For a slick track with a d 6.5 motor, this was a very fun setup and worked very well in the slick conditions.
I also qualified 2nd in 4wd SCT Running Copperhead R.51, and took the win at the end of the main. The truck was amazing and had power everywhere on the track
Copperhead Setup:
Losi SCTE
13T Pinion / 40 Spur
Punch 3
Motor Timing 1
Brakes 8
Start power 6
Drag Brake 0
Copperhead Setup:
Losi SCTE
Punch 3
Motor Timing 1
Brakes 8
Start power 6
Drag Brake 0
#4470
Nice!!! Congrats Dave
Copperhead Setup:
Losi SCTE
Punch 3
Motor Timing 1
Brakes 8
Start power 6
Drag Brake 0
Copperhead Setup:
Losi SCTE
Punch 3
Motor Timing 1
Brakes 8
Start power 6
Drag Brake 0
4Likes
