Viper RC -
#4486
It does not look like you did what I did but I had the same issue. I had turned up the punch and I would hit top speed in like .0000001 seconds lol. I would double check the punch set up. Punch on this ESC seems to have the most effect of any ESC I own or have ran.
#4487
It might work, or it might not. Just not recommended. The 10R is really the best ESC for Mod4
#4488
under which profile can i use the holeshot launch feature. i'm running the vtx10 esc with the viper 10.5 on profile 1. everytime i try to access the holeshot launch with my proguage it does nothing. am i doing something wrong? also i'm running the most current firmware
#4489
#4491
Can someone describe the variables that determine braking power? I had an RS in my 22, usually running a Tekin 17.5T in blinky but sometimes an Orion 13.5T. The buggy will pretty much stop on a dime if I apply full braking. I used the expo setting on my radio to tune down braking response.
But my stadium truck will come to a rolling rather than a halting stop. It brakes fine when I'm running so long as I crank up the brake strength. The ESC in the ST is an Orion R10 and I've been running either a Revtech 10.5T or the Orion 13.5T mentioned above.
Clearly there are a lot of variables here. The obvious one is the size/weight of the stadium truck vs the buggy. I've also read that lower turn motors may have less braking power, but so far I've not felt much of a difference in swapping motors around. What I haven't done is switch the ESC between cars--would that likely make a big difference? And if so, why?
Braking is actually allot harder on the ESC than running the motor, because you apply a current to the winding to slow it down. What you end up with is a big alternator and the motor is making more power than the ESC can use at that point, so it has to absorb it. That is why there are capacitors on there to help absorb this energy.
#4494
#4496
silvalis - with the VTX10 we don't recommend going that low with a 4wd. The VTX10R is designed to handle lower turn motors. I have run a 7.5 with the VTX10 in a 4wd during our development of the product. But if you are using a lower turn, the VTX10R will handle it better long term.
#4497
#4498
Thank for the input. The VTX10R is already getting hot after just a few minutes on our indoor track. I can only imagine the temp climb I will have to deal with on the outdoor track since the ambient temp will already be 40-50 warmer. So, what do you recommend? Anybody?
#4499
We would need to know more, like car, track conditions, motor, gearing, ESC settings, etc......
#4500
I have an associated B4.1 and B44.1 track is hard packed dirt, a lil loose, medium in size, 7.5 and 6.5 motors, geared at 23/78 and 19/81. The ESC is at 6400 on brake with 70% brake and 12000 PMW on throttle for the 4WD. The mod buggy is at 5000PMW on brake with 73% brake and 9600 PMW on throttle.
4Likes
