Like Tree4Likes
Viper RC -
Old 08-07-2012 | 03:58 AM
  #5221
Grasschopper's Avatar
Ok so I'm trying to find a good boost profile setup for my VST13.5T in a Losi XXX-SCT. I have an email from Eric at Viper with what he uses but I'm not using proguage or a Viper ESC so a bit of translation is needed and I want to make sure I have this right.
I'm thinking a boost starting point of around 3500 rpm with a slope of 550 rpm/deg and a max boost timing advance of 25 deg. So the motor comes from the factory with the can timing set at 30 deg. but I've seen people say to turn that back when running boost. Is there soem sort of general rule to that effect? Or should I just leave it stock?
Grasschopper is offline
Old 08-07-2012 | 05:18 AM
  #5222
nikos2002's Avatar
grasshopper - you can leave it there to start, run a few laps and see how the power band feels and what temps you are getting. Anytime you make big changes, make shorter runs at first to check temps before long runs.
When adding boost, you just want to be sure the power is coming on at the right point for your driving style and track. If it doesn't kick in until the end of the straight, you need to adjust it so you really use the extra power.
nikos2002 is offline
Old 08-07-2012 | 05:22 AM
  #5223
nikos2002's Avatar
Originally Posted by blue t
I have a VTX10 with a 10.5 in my buggy but the motor will not turn. Things I have checked.
Known good sensor wire
Reflowed all joints
Different motor
Recalibrated esc
The lights where the pro gauge plugs in light up correct with throttle and brake. Thanks for any help Rusty.
If you pull the throttle on the radio and the lights change accordingly its generally sensor related or cold joint on the motor side. Try a new sensor wire just in case. Like in NASCAR when they have engine issues, first thing they do is go to the plug wires!!
Old 08-07-2012 | 06:51 AM
  #5224
Great question, also I'd like to know if there's a video of how to do this? I have the progauge and plan to install it today or tomorrow. So, I really need help quickly.
shagnat is offline
Old 08-07-2012 | 07:48 AM
  #5225
Mr.juarez's Avatar
Got a bit of a dilemma here.
Viper copperhead with 5150 motor.
Running fine as far as temps (145ish) geared at 11 in a scte. The issues is sometimes stops or cuts out as if lipo cut off but comes back in a little bit and runs fine for the rest of 5 minutes. Also a little stumble will trigger that's and a mild hit as well. We swapped another new copperhead combo and same results as well. Some say it's the savox servo, but they added a castle bec and still does it.
Is this a motor hiccup thing? My 4500 never did anything stupid like at all and it's on profile 5 with the brakes turned down throttle curve at -3 no timing and start power at 1.
Mr.juarez is offline
Old 08-07-2012 | 10:43 AM
  #5226
nikos2002's Avatar
Originally Posted by spider882009
Any word on the 1/8 Scale ESC and Motor??? Big races coming up soon in Sept. I've been holding out on a system in hopes that all my 4 vehicles could be Viper powered. Right now Mod 2WD SCT, Mod 4X4 SCT, and 2wd 1/10 Buggy. Just need a system for the E-Scale!!!
I don't have an exact schedule at this time, testing has been good, but nothing finalizd yet.
Old 08-07-2012 | 10:45 AM
  #5227
nikos2002's Avatar
Mr.Juarez - check the bullet connectors to make sure they are tight. Had a customer who had a loose one and it cause the system to think it thermaled when it really lost connection.
Also note that if you have a hard crash, flip spin out. It can sometimes take a few seconds for the esc to figure out what pole to spark in the motor because it's not sensored.
Old 08-07-2012 | 11:39 AM
  #5228
Quick question, does anyone know what PMW in the Viper is closest to the LRP ESC's out there? Thanks
jrj1451 is offline
Old 08-07-2012 | 12:15 PM
  #5229
larlev's Avatar
I found during testing that a higher start power helped...3-5. I ran start at 7 for a few races and never had this issue. Started going down and now at 5.
I did have your issues when at a low value.
larlev is offline
Old 08-07-2012 | 02:38 PM
  #5230
Mr.juarez's Avatar
The bullets are rock solid tight. As far as hard crash it dies with a minor hit or sometimes 2 laps into the heat coming out of a turn then boom lights off but after that it's fine for the entire 10 minute race.
I tried 7-9 and it was too brutal for the 4500, but like I mentioned the 4500 ne'er did it at start power 1, but the 5150 is. I'll bump the start power up and run itbon Saturday as its going through a full rebuild right now.
Old 08-08-2012 | 05:41 AM
  #5231
I have had deans connectors that were fully together cause that symptom. I run a savox with no BEC on my vtx10R and its rock solid. Its a connector issue. Make throttle linear, anything else gives a funky feedback. (on all brands)
Outkast187 is offline
Old 08-08-2012 | 07:27 AM
  #5232
Thanks for the help but I believe its the esc. I changed every thing to a different esc and it works great. I've got my RMA and will get it sent back.
blue t is offline
Old 08-08-2012 | 07:35 AM
  #5233
nikos2002's Avatar
Thanks blue - quicker we get it - quicker it will get back to you.
jrj - don't know - doesn't LRP use a number system like 1-10? We show the real value. I don't know how their numbers work. With our stuff I generally start lower with stock motors (17.5, 13.5) and higher with mods (10.5 and lower) and tune from there to what feels good. At the SC Nats last weekend Royce and I ran exact motors, gearing, but he ran 5k and I ran 9600 - just liked it that way.
Old 08-08-2012 | 07:36 AM
  #5234
Mxer59's Avatar
I saw this product and was very interested, I was curious performance wise and power, how reliable can they be? It will be for a TLR 22 sct.
Sorry for the questions just nobody around here has this system or have seen it. I like the price point as well as the programmer box mostly likely be 8.5 setup.
Mxer59 is offline
Old 08-08-2012 | 08:11 AM
  #5235
Nikos2002,
I have a Viper 17.5 with the 10R. The speed control has one of the capacitors that has broken away from one terminal and my motor has overheated. These items are out of warranty, can I do an RMA and have them fixed and pay for the work done?
Thank you,
michael
AfterTithes is offline
