Viper RC -
#5251
Motor temp was disabled and the ESC temp was set at 220?
Yeah, I forgot to mention that. I'm pretty familiar with these systems. I ran them exclusively for a season of offroad and a season of on road but decided to use something else. Now I'm just trying to make sure that this kid can run his stuff.
#5252
You can turn the motor temp cut off higher. I have even disabled it, and checked then temp with a temp gun sometimes. It's not a bad thing to do that. If you temp the outside of the can you want to stay around 150-160 after a race distance. If your at a big race and want little more- try it. I have gone to 200 with my VST5.0L in the sc104x4.
When we give you temps (and the settings in the esc) they are a guideline. You can run them hotter if you choose. If done correctly you can get a little more performance. But - But - if done wrong, you can hurt the motor, it may not last as long. So like everything else. It's a balancing act.
We went to a race several month ago that drivers using another motor were coming off the track blazing hot, and replacing rotors every run, to maintain performance. Everyone has their own idea on how to make it work.
#5254
I would check the center diff/spur to see if its dragging. I temped 1 time due to grit in my sprur so I cleaned it all out and cleaned my center bearings and my temps went down to the 120 degree range and this was in a Nexx10sc the losi has more play in it that can cause drag on the motor.
#5257
Anyone have gearing suggestions/ESC setups for an 8.5 in a B44 and a 13.5 in a B4?
Most tracks are small to medium sized.
Right now im at 34/72 in the B4 with some timing, I used profile 3 and tuned it down some.
In the 44 im at 19/83, and same thing on the ESC, profile 3 and tuned down some.
The B4 temps at like 110-120, and the 44 usually at 160-170.
#5259
I have had sensor cables that would work then not work depending how it wiggled if it was freyed or loose pins going into the plug. If its doing it though 3 or 4 minutes into a run every time sure sounds like a heat issue to me be it the motor or at some point in the esc. Never had a viper esc apart but a cold solder joint or a plug inside of it thats loose/bad connection internally or externally get hot.
#5260
That's what I'm thinking it may be. I've seen issues very close to this, all slightly different, all running 550 size motors. The one issue I have seen with a 540 sized issue and offroad was in a 2wd SC. All of these issues have been completely different from the issues that I had personally had.
All I'm trying to is get a good solution for this kid so he doesn't have to spend even more money on this system or replacing the system with something else.
#5261
Last nights racing we saw a Viper system shut down. The F/R lights were flashing. We temped both the motor and ESC. Both were 140-150. Played with some settings that were in profile 2. This was in a 4wd Losi SC truck. Turned the throttle and brake PMW or whatever down to 4000, start power down to 40%. It was still doing it.
Losi 4wd SC, viper VTX10R/5.0L combo, stock spur, 14t pinion, good batteries, good solder joints, Spektrum radio, Hitech servo (not a Savox).
Just trying to help this guy out so he can make it through the race. It was cutting out at pretty close to the exact same time both in both Qualies, 4:30-5 minutes in to a 6 minute race.
#5263
4Likes
