Viper RC -
#3721
I can tell you first hand that I had a 3800/MMP before installing the Copperhead. I was very skeptical, but have since put the 3800 in the tool box. I can't say this enough, but the Copperhead is smooth....really smooth. It's a big difference from the 3800.
Not taking anything away from the Castle, I ran it for 6mths and never a problem. great little motor that should get more respect.
With that said....I'm staying with the Viper.
#3722
I get the same flashing red light when I plug into my comp. My computer makes the "bing/bong" when I plug in and unplug the Viper PC link cable.
I am still only getting COM1 and COM3 as options in the drop down. No USB option at all. I had trouble with this the first time I tried to use it. I was getting USB options but not USB0 options. Turned out that I had not fully plugged the two halvs of the PC link cable together. That is not the case this time. I'm not even getting USB options. I'm getting really frustrated with the whole process.
#3723
Still no luck.
I'm at the RCPro race this weekend, but can send it if you want when I get back.
#3724
Jamie, I would be more than happy to send you my cable. You can use it and send it back if it's the cable. I'm lost on this one, been thinking about it since you posted. I even tried to mess with mine and see if I could get it not to recognize.
There must be some tech wizards on here............
#3727
Hi everyone,
I just bought a vtx10r+orca RX2 10.5T motor for my 1/10 touring. I'm abit confuse of the start rpm and the end rpm setting. Can any expert help me what is the ideal esc setting for my local track. I need punch cause it has many tight turns and I need high speed cause the straight line is about 140 feet. Any suggest wud be appreciate
#3728
Hi everyone,
Both settings are associated with the Acceleration Boost settings in the VTX series speed controls.
For example, if your settings were:
Acceleration Boost Max Advance Timing: 30 Deg
Start RPM: 7500RPM
Finish RPM: 14000RPM
What these settings would do is start applying the additional timing when the motor reaches 7500RPM (it would add 1 deg of timing) and then gradually apply the 30 deg of timing once the motor reaches 14000RPM.
The relationship of the numbers will have allot to do with how the motor "feels". For Example:
Lowering the start RPM can give you more "punch" at lower rpm.
Lowering the Finish RPM so that it is close to the Start RPM will make the car feel like it has allot of "snap" in the mid range power.
Raising the Finish RPM will apply the timing more gradually and may be needed if racing on low traction surfaces.
You have to be smart and do some testing to apply how the settings feel to your car, your driving style, your motor, your gearing, traction, etc.....
Also be mindful that when applying the timing aggressively (lower RPM settings) can make it easy to overheat the ESC or motor. Remember, heat is the result of applying too much timing at too low of a RPM.
#3729
I had some issues at a big race this weekend. Ran blinky for the first time is stock buggy. The motor had a bad sensor board in it and took out my ESC. I am sending it in for warranty today but I don't have my receipt. I bought the combo back in Octobet of 2011. Since i don't have my receipt will there be any issues with my warranty? How do I go about ensuring this will go thru. Looks like I will be without some electronics for a while. We will see what happens. Thanks.
#3731
#3732
I believe their my be a new version coming, but priority is to work on the VTX8 at the moment.
The VTX8 is in a early prototype stage, and delivery will all hinge on how well testing goes. Too early to tell when yet.
4Likes
