Like Tree4Likes
Viper RC -
Old 11-25-2012 | 10:15 AM
  #5971
Originally Posted by AndrewTom
I think this would be a better asked question at your track. don't be afraid to ask the fast guys questions. If they are a good racer, they'll help you out.
otherwise I would start at 5% and see if you can notice the difference. and add more from there.
I am at 10% already and it doesn't feel like it is adding anything. I am just wondering what others are experiencing. I will keep adding more until it feels good.
C Branch is offline
Old 11-25-2012 | 10:16 AM
  #5972
godofcable's Avatar
also drag brake settings are going to be different for every driver. Some guys like to setup drag brake instead of actually using the brakes in corners.
godofcable is offline
Old 11-25-2012 | 10:29 AM
  #5973
These are all good suggestions, however, I am the only one running Viper at my track so as I am going through the trial and error process, I would just like to see what others that are running the same product are experiencing so I know if I am in the ball park, or if I am trying to over come some other setup flaw.
In case you have missed it, I have been doing this for a long time (over 20 years). I am not the type to come on here and ask for setups. Just trying to see if I am in the ball park.
Thanks for trying though.....
C Branch is offline
Old 11-25-2012 | 11:38 AM
  #5974
I started at 15% drag brake and just left it there. When I tried the really high amounts, it was just wasn't for me
Bob Barry is offline
Old 11-25-2012 | 11:41 AM
  #5975
Thanks Bob. I am at 10% right now, so I will slowly work my way up until it feels right.
C Branch is offline
Old 11-25-2012 | 11:45 AM
  #5976
Wildcat1971's Avatar
I use 5 to 20 pct drag depending on the motor and the traction
Wildcat1971 is offline
Old 11-25-2012 | 12:06 PM
  #5977
Thanks man. How is everybody in Tucson?
C Branch is offline
Old 11-25-2012 | 03:49 PM
  #5978
Grasschopper's Avatar
Well I tried REALLY hard (and dumb) to blow my VXT10BE up this afternoon. Don't know what exactly I was thinking but I plugged my neg lead into the positive terminal on my battery and then nearly plugged the pos into the negative. Huge spark, stinky smoke melted plastic and I thought I killed it. But I got lucky and the ESC works just fine still.
Really dumb...really lucky...glad the Viper is solid but don't suggest anyone else test this out. I'm going to avoid doing it again if I can.
Grasschopper is offline
Old 11-25-2012 | 03:55 PM
  #5979
godofcable's Avatar
All of my batteries are wired the same way, where the positive terminal is on the same side each time. That is except for one battery. When I plug in that battery I triple check the marks just to be sure. Friend of mine plugged in an esc from another manufacturer and it went up in smoke. You got lucky
Old 11-25-2012 | 08:46 PM
  #5980
silvalis's Avatar
I put whiteout on the +ve terminal on my batteries. Some of the markings are hard to see at night.
silvalis is offline
Old 11-25-2012 | 08:58 PM
  #5981
84 GT 5.0's Avatar
What is the box stock setting for motor timing?
84 GT 5.0 is offline
Old 11-25-2012 | 09:03 PM
  #5982
spider882009's Avatar
Well I'm hoping this is ok... Running my VTX10 w/ 17.5 in a 22SCT Mid Motor. Last night my average temp's were: Motor 161 degrees and ESC 102 degrees. Are these a good temp after a 5 min heat race???
spider882009 is offline
Old 11-25-2012 | 09:44 PM
  #5983
motor temps on the outside with a temp gun right?
I would think that the motor is a little bit high. Keep this in the back of your head....
for club racing, keep temps under 140, preferably 130.
for big races, keep temps under 160, preferably 150.
That's the rule of thumb I use. There's no perfect answer, but this has worked well for me in the past.
Old 11-25-2012 | 09:45 PM
  #5984
wow dude, that's both awesome and horrible at the same time. Horrible you had to experience it, awesome that the speed control survived.
Old 11-26-2012 | 07:47 AM
  #5985
stu541's Avatar
colin. I run between 8%-12% in blinky. I like my car to roll thru corners (esp in stock) to maintain corner speed. try and get more off power steering in your evo to help if needed. lighter front oil and lower front ride height helped me.
stu541 is offline
