Like Tree4Likes
Viper RC -
Old 11-03-2012 | 06:44 PM
  #5791
njnewc's Avatar
Just ordered the copperhead-r with the VX4R51 motor. It's going in a sc10 4x4. Can't wait to get it in. Used the military discount. Wow what a great deal. Thanks niko for pointing me in the right direction.
njnewc is offline
Old 11-03-2012 | 06:46 PM
  #5792
godofcable's Avatar
you wont be dissapointed
godofcable is offline
Old 11-03-2012 | 08:24 PM
  #5793
silvalis's Avatar
Hate to nag, but any chance of the VTX8 before christmas?
silvalis is offline
Old 11-04-2012 | 12:04 AM
  #5794
I am running a dex410 with a reedy 8.5. I have it set on program 2. How do I turn up the boost, and timing with the pro gauge. I can't find it in the menu. Also what is hz?
Beau
THE GOOCH is offline
Old 11-04-2012 | 05:56 AM
  #5795
nikos2002's Avatar
Great qualifying efforts from the Viper Team at the Spektrum Off-Road Championships this weekend. Kendall Welch is in the A-Main for Mod Truck, and Kevin Westindorf is in the A in a very tough field of 17.5 blinky buggy. More news to come thru the day!
nikos2002 is offline
Old 11-04-2012 | 06:15 AM
  #5796
nikos2002's Avatar
njnew- enjoy!!
silvalis - waiting on delivery of production units. I want to give a time frame, but don't want to be wrong. I feel pretty safe to yes before Xmas.
Gooch - if you are in Profile 2, choose Misc Control, Run Mode. switch to open. Then settings are under motor power. Hz is hertz, it's how the throttle and brake freq are meaured. More detail info in the users manual and on the speed control pages on the website.
Old 11-04-2012 | 09:56 AM
  #5797
Questions??
Just purchased the VTX10 w/controller card. Don't have USB cable (yet) for firm ware up grades nor have I even powered it up yet. Question is, do these ship w/ latest firmware or do I need to up it? Way to tell version?
REALLY EXCITED about this ESC!
RC Jay is offline
Old 11-04-2012 | 10:26 AM
  #5798
When you plug in your progauge it will tell you want firmware you have...
bring it on is offline
Old 11-04-2012 | 12:32 PM
  #5799
05PSD's Avatar
I'm having issues with my second VTX10R. After setting it up, I can ramp up the throttle slowly and it's fine. If I pull the trigger too fast the motor stops.
This is the second brand new VTX10R that has done this. My M11x was on a new profile so I don't think it's radio settings. This is used with a Trinity D3 10.5 turn motor in a DEX210. Has anyone else experienced this?
05PSD is offline
Old 11-04-2012 | 02:41 PM
  #5800
techpro's Avatar
Default vtx10r/vst7.5
After installing system tried to calibrate to radio, pressed the v-port button a light flashed and then no response,has anyone had this happened.Sending it to warranty office in the morning if no one has any insight
techpro is offline
Old 11-04-2012 | 04:31 PM
  #5801
savannahmick's Avatar
Originally Posted by FLHX1550
A 165 temp after 10 minutes isn't that bad IMO, it has allot to do with running that long. Also things like your drive-train, bearings, etc.... can make some heat. And driving habits (ripping hard on the gas on a high grip track at real low speeds can build heat quick).
Have you tried the 23/81 and 80-85% EPA? Many of the people I know running a B4 with a 8.5 are somewhere like that and just turn up to 100% if they have a real long strait.
I know in one post you said you were running 15 Deg of timing on the can, stock is 30 deg. The low motor timing could also be making it get warm, you have it turned down enough to start making the motor less effecient
I changed the gearing to 22/76 and the motor timing to 30deg. also lowered braking hz before the Fall Brawl warm-up race it ran all day perfectly with a 10 min. main and never went over 120f ESC or 130f Motor! So thanks for the advice/help and I ended up 3rd in 2wd 1/10 mod. buggy great run for my second time out with the setup.
savannahmick is offline
Old 11-04-2012 | 04:45 PM
  #5802
AndrewTom's Avatar
i am having some issues with my motor, vst 17.5. at the beginning of heats or mains, i have plenty of power, but as the motor heats up, i lose power. i am running this boosted 15 on the can, 30 deg. acc boost (St. 2500 Fin. 12000) and level 8 at 20 deg top speed. after the heats, my motor came off at 160.
AndrewTom is offline
Old 11-04-2012 | 04:58 PM
  #5803
I am in love with my Viper ESC and 17.5 motor!!! I have been running it in my 2wd buggy in blinky mode with the timing on the can maxed out. I have it geared pretty high and it never came off the track over 115 degrees. I have also never been passed on the straight either
I just pulled it out of my buggy and threw it into a touring car, and the temps never went higher than 135 degrees.
I can not say enough good things about the Viper equipment! The fact that they are orange is only icing on the cake
C Branch is offline
Old 11-04-2012 | 04:59 PM
  #5804
njnewc's Avatar
Is ur battery dying causing u to lose power?
njnewc is offline
Old 11-04-2012 | 09:56 PM
  #5805
AndrewTom's Avatar
could be! my gens ace is now 1 year old, along with most of my other lipos being about 6 months old. ill probably end up buying a few 5000 50c or asking for some for christmas.
edit: dear god, did i mention christmas in the first week of November!!!
