Like Tree4Likes
Viper RC -
Old 10-01-2012 | 02:19 AM
  #5581
silvalis's Avatar
If the thermal cutoff is occurring on startup, check your soldering - I seem to recall a post in this thread that had to do with a short across the esc terminals (or motor terminals?) tricking the esc into thinking it had thermalled...
silvalis is offline
Old 10-01-2012 | 04:27 AM
  #5582
FLHX1550's Avatar
Originally Posted by Throwindirt
Thanks nikos2002 I just ordered a 12 tooth pinion my lhs didn't have one in stock I have the pro gage so I'll adjust my punch according to track conditions. I thought timing had more of effect on temps? What would you consider running to long, on practice days I usually run around 10 to 15 Min's and always keep a close watch on temps witch have never been an issue.Again thanks for the help as I've only been in the hobby a Little under a year and I still have allot to learn
On thing to consider with the Copperhead is that it is uncensored, there is no motor temp sensor that can signal the ESC to shut down. That being said, the only temp effected issue situation that can shut down the system is the ESC itself. Gearing down can tend to RAISE the temp on the ESC, and lower the motor temp.
The Copperhead was originally designed as a RTR replacement system, it just happens to be very fast and a cost effective choice. That being said, the motors are potent, and work the ESC pretty hard.
My advice, run zero timing and gear with a 14T on the lost SCTE (5150kv) and set the end points at 80-90%, start power 3, punch 3-5, and limit your run time to 8 minutes. Running these systems for 10,12,15 minutes is just cooking everything.
FLHX1550 is offline
Old 10-01-2012 | 05:11 AM
  #5583
i didnt think about it being at start up. now that you mention that i am thikning the sensor wire might be the coulprit.
naffer is offline
Old 10-01-2012 | 07:04 AM
  #5584
tony montana's Avatar
Well I have the 4500 KV copperhead system. And we race 10 minute mains. I'm geared with a 14 tooth pinion. My motor and esc were warm this weekend. I don't have a temp gun but I could hold my fingers on the motor and esc but they seemed pretty warm. So what pinion and setting should I go to running 10 min mains
tony montana is offline
Old 10-01-2012 | 07:09 AM
  #5585
what type of car? losi? i have been running 13t on my associated 4x4 with the same set up it never gets hot .....what profile are you running? i always run the race #5 profile and tweak it way down .....the brakes on the copperhead can be turned down a good bit which will reduce some heat ....also i just never seem to use much timing either doent seem like it needs it ....just some things to think about ...its hard to get a good handle on without some more info
zixxer is offline
Old 10-01-2012 | 08:09 AM
  #5586
FLHX1550's Avatar
Just in general, the more gear will lower the ESC a little and raise motor temps.
Testing is the most important variable.
FLHX1550 is offline
Old 10-01-2012 | 10:00 AM
  #5587
Yeah it's in a scte. Track isn't very big can only hold full throttle for a second or to but I'm at half throttle quite often. I'm using profile 4. The rest I have not touched yet as I do not have the progauge yet. But it did turn the travel on my radio up for the brakes a little
Old 10-01-2012 | 06:52 PM
  #5588
Hey FLHX1550 can't understand why a viper tech would tell me to gear down from a 13 tooth pinion especially if gearing down is going to raise temps in esc and I never had any temp problems from what I could tell using my temp gun. The settings your suggesting are pretty close to what I've been using except for timing which I think are either at 3 or 4,I'm going to change it to 0. Guess I'll put the 12 tooth pinion I just bought in my spare parts bin and order me up a 14 tooth. Holy crap my heads going to explode
Throwindirt is offline
Old 10-02-2012 | 04:48 AM
  #5589
spider882009's Avatar
Please Please tell me we are closer on the 1/8 Scale Applications??? Just picked up my 2.0 this week. Don't feel like throwing the Tekin back in it. All my 1/10 Scale are swapped to Viper.
spider882009 is offline
Old 10-02-2012 | 07:19 AM
  #5590
FLHX1550's Avatar
I've raced both the 4500 and 5150 Copperheads in the SCTE, just offering up what my experiences were.
I also suggest using minimal brake also (reduce the radio brake EPA to 70-80%). Braking is a major contributor to ESC heat
FLHX1550 is offline
Old 10-02-2012 | 09:50 AM
  #5591
From what I understand the esc should be out really soon but not the motors yet
bring it on is offline
Old 10-02-2012 | 12:08 PM
  #5592
plasma327's Avatar
I just wanted to post one last time here. I had a viper system VTX10R and was having issues. It locked and i was unable to fix the issue my self. I was unable to rum the main because of it. So, i posted on here for help, Vipers FB page and sent an email from there support page on Viper .com. I have received more support from my fellow members here than i did from Viper support. Sadly, what advice i did receive(None from the email at all, One from the FB page and one from here) was amatuer at best. VERY dissatisfied with Viper. I have no faith in there ESC nor customer support, but do like the motors. I pitched the ESC and am now back with Tekin.. I had herd good thing from fellow recers about Viper but my experiences have left me sour!
plasma327 is offline
Old 10-02-2012 | 12:27 PM
  #5593
Grasschopper's Avatar
I assume you didn't really pitch it...I would be interested if you want to sell to recoup some of your loss. LMK.
Grasschopper is offline
Old 10-02-2012 | 01:07 PM
  #5594
plasma327's Avatar
Yes, i really did drop in in the trash can at my work bench. It is still there as i have taken the trash out yet.
Old 10-02-2012 | 01:18 PM
  #5595
davidfast's Avatar
Why don't you send it in if everything hasn't worked...it sounds like you damaged the system if it's "locked". I'm not really sure what you mean by that.
It's simple and fast.... http://viper-rc.com/contact.php
Did you try anything Nikos2002 suggested to you?
davidfast is offline
