Viper RC -
#5566
There is no one magical gear ration for 17.5 - more wide open the track is, the higher you can go - but naturally you could suffer on anything short (short run up to a jump, short straight etc). You got the right idea, look at your lap time and your temps to find the right balance. Remember to set yourself up for the race time of your longest run (normally a main event), not a 10-15 minute practice run - motors don't like that
Good Luck!!!!
Good Luck!!!!
#5567
Hey guys
I have a question regarding the Viper Capacitors
which capacitor set stores more power?
The 'VTX 4x Power Capacitor Module'
http://www.amainhobbies.com/product_...pacitor-Module
'Black Edition' Power Capacitor Set ?
http://www.amainhobbies.com/product_...-Capacitor-Set
I am running a Savox servo and the pos SR300rx.
opinions welcome!
opinions welcome!
#5568
Hey guys
opinions welcome!
opinions welcome!
That said I'm running the stock 270uF pair in my XXX-SCT with a Savox 1258 tg and have zero glitching issues...I'm running a VST13.5t boosted. You should only really "need" the bigger caps if your running a low turn motor or a 550.
#5569
Ran my Viper 17.5 last night on indoor off-road carpet!!! It did great lots of speed!!! Ran 82/26 Spur/Pinion. 15 Degrees Timing! And had 10% boost set w/ the pro-gauge!!! Did real well!!! Just started messing with some of the internal settings w/ the pro-gauge!!! Didn't need all this with the Viper 8.5!!!
#5573
I have a question for the guy's running the copperhead 5150 combo in a Losi SCTE. I've had the combo in my truck for a couple of month's and it's been running great until one night at the track practicing the esc just shut down, so I sent it to viper (great customer service) and they said the bec failed because of a voltage spike. My setup is 13 tooth pinion #4 throttle punch #4 on timing no drag brake and I never had any over heating problems. They suggested to go down 1 to 2 teeth and drop throttle punch to#2 didn't say anything about timing .I was wondering what you guy's are running on settings do any of you run punch as low as 2 I thought 4 was way low Just so you know this truck is only run on the track no bashing
Thanks for any help I'd appreciate it Bob
#5574
Sometimes a voltage spike can just be one of those things. Could happen lots of different ways. As for the punch - it really is going to depend on your feel and the traction available. I have been at tracks where I turned it down to 2 because I couldn't control it with more. I have also turned it up a little higher and geared down a tooth - so many variables. just remember to watch your temps - don't run too long, especially with 4wd SC. I really think that is the harded environment for these electronics in all of rc.
#5575
#5576
HI,
I have a VTX10R and a 6.5 in a dex410r. I was having problems thermaling the ESC. I went to a 10.5 motor playing with gearing and boost and got it to my liking. I ran a couple of packs in the qualifiers this evening and put a fresh pack in for the main. Turned on the ecs and all i get power up with the foward and reverse lights blinking together. servo is powered but no power to the motor. I re-clibrated, tried another pack, tried to access the esc with pro gauge and the esc will let me do nothing. I cannot even shut it down with the on/off button, i have to unplug the pack to get it to shut down, anyone know what is wrong??
#5577
HI,
#5579
Throwindirt - try not to run more than the longest main time you have to run. If you track runs 7 min mains, don't run too much longer than that - 10 minute main - only 10 minutes. This way you don't get the motor overly hot. Longer you run, hotter the motor will get. If your geared for racing - your geared to get the most out if over that certain amount of time.
Plasma - 2 things to try. First some basics - unplug everything (battery, rx connections, motor connections), then re connect. Also try another profile on your radio to see it if reacts correctly.
#5580
HI,
4Likes
