Viper RC -
#5416
Grasshoper - get the 10R if you plan on running a crazy low mod motor or use it with a 550 motor in the future. If not, save the coin and get the regular 10.
But we both know if you save money to get the 10, something else will end up in the cart on A Main - it always does
#5417
Grasshoper - same statement applies - if you plan on running a 550 motor, get the BE.
Rick - my son is jealous, he loves trains - its been 2 years since we did a dinner train.
Trying to find something in the direction of track having a big race - to invent a reason to stop by and say "hi" to everyone.
#5418
Do you recommend using "acceleration boost"/"top speed timing" on the VTX10R with a 10.5 turn VST motor in a 2wd SCT? If so, what we be a good starting point? Would the default profile #3 (off-road 13.5 boosted) be too much?
#5419
You could start with that profile, but I would tone down the timing and boost settings a little. To start. Plus go down a few teeth as well to compensate. Boost is a helpful tool, but it may take a little time to dial in. Everyone has a little different feel and style so what works for one person may be too strong or too weak for another.
#5425
have you guys figured out that BEC problem yet? i keep blowing becS in your speedos and losing reverse? im sending my system in again next week, had 3rd place locked up last weekend till esc shut down completely and pulled off a 7th place overall! frustrating! arrg but i know you guys will fix me up right.
#5426
#5427
Ok guys I have a vtx10r and 6.5 tekin motor gearing at 17 81 and after about 3 minutes it shuts down .. The moter temp was 134 and the esc temp was 138 ..the f and r were both blinking I dont understand can someone help me out .. I have 5 vtx10r and this is the onlyone I am have problems with..... Thamk u for your help......
#5428
#5429
stuntryda- we have no more of an issue than anyone else - these motors we are all using nowadays are pushing all systems to the limits. If you keep having the same exact issue, we should look into all the factors that could lead to this.
Bob- we will have team drivers there supporting the race, I am going to IIC in Vegas the same weekend for some on-road action. Last in the three 17.5 classes we took 1st in two classes and had 6 of 9 podium positions. Plus 2 podiums in modified classes - hope the team can repeat tose results!!!
Tibbs- check and see what your motor temp cut off is at - might be too low. Thanks Badger!!
#5430
4Likes
