Viper RC -
#5611
The length of that wire is about 3 inches...I wouldn't go much longer than that.
#5612
Are there any issues with running the BE caps on the regular vtx10? Or better to use the VTX 4x cap set? Wondering if I should upgrade the caps while i'm at it...
#5613
No issue at all and if you have the silver 270uF caps I would upgrade....the capacity of the BE set is greater than 5X the capacity you have now and nearly 3X the VXT 4x cap set.
#5614
On the subjects of caps, I'm at a two day race at the moment and tonight I was running a few practice laps after the race I crashed and broke both caps off my vtx. I didn't touch the throttle after the car was crashed, so I'm sure the esc is okay. I'll have to go to radio shack, what should I replace them with?
#5615
#5616
#5618
Is there a post or sheet on the Viper site (that I can't find) that describes all of the ESC settings in detail? My current question is what is Brake PWM? I was reading Dave Beam's ESC setup sheet from pg 200 and the brake settings on hie 22 are stated as 75%, stock PWM, and linear slope. In my B4.1 (VXT10-BE with a VST8.5) any brake setting less than 85% might as well be 0%...I'm now wondering if it is because the PWM is set to 9600.
Looking at all of the options on the setup sheet I guess I know what most of it does but I'm unclear on the PWM for both brake and throttle.
Edit: you know if you read the user manual it has some good info
. So What is "stock" listed in Dave's setup? Why when set to 9600 do I have to have my brakes so high to get any braking?
#5619
Fellas I dont know what I wanna get lol. Wanting a new esc and motor and I am torn between the vtx10r and the vtx1 and the black edition vtx10. But I need to buy one of them with the pro gauge. Suggestions?? Just want something that will last. I think Im a viper user for life now. I love the copper head 4.5 combo.
#5620
#5624
#5625
It is refined for use specifically with 2S batteries (3S not allowed) and has a stronger BEC and better caps.
4Likes
