Like Tree4Likes
Viper RC -
Old 06-15-2012 | 04:41 PM
  #4861
???E-Racer's Avatar
Im wanting a 10.5 motor that has adjustable timing.
Because one track is open while the other track is not.
I notice Amain has the 10.5 Viper motors back in stock.
???E-Racer is offline
Old 06-15-2012 | 07:02 PM
  #4862
DubDeuce386's Avatar
Originally Posted by nikos2002
As Dave stated above - its something that could cause an issue - it might be really fast - but definitely pushing the limits. Don't be surprised how fast the system is on a 2s - it hauls --
+ YouTube Video
Gotta Love that Sound...Sounds like mine in my SCTE goin down a Straight Away...
DubDeuce386 is offline
Old 06-16-2012 | 10:53 AM
  #4863
nikos2002's Avatar
Give it a try -- gonna like it!!
nikos2002 is offline
Old 06-16-2012 | 10:56 AM
  #4864
nikos2002's Avatar
We try and return any warranty items as soon as possible. We have been averaging about 2 weeks from when it leaves the customers house, gets to us, is processed and shipped back to the customer.
One of the longest parts of the process is how its shipped to use. BTW, we return the shipping Priority Mail (which should be 2-3 days to anywhere in the US). Also helps when all the paperwork is in the box correctly, so make sure to read the RMA to see what is needed.
Old 06-17-2012 | 11:02 PM
  #4865
How long is your warranty?
tdt1805 is offline
Old 06-18-2012 | 07:13 AM
  #4866
sewerdog's Avatar
Ran the 5150 for the first time this weekend in my SC10 4x4, all i can say is what a deal 150 or so bucs and a great combo performance, smooth and powerful, great bang for the buck, my only complaint the motor thermalled on me in the main after 6min or so. the track is outdoors and med size, had it geared 14 /62 . will 12 /62 keep it from thermalling or should i just put a fan on the motor?
sewerdog is offline
Old 06-18-2012 | 08:49 AM
  #4867
FLHX1550's Avatar
The Copperhead is a sensor-less system, meaning there is no sensor in the motor to shut the system down. A fan will lower the outside temp some, but not help a shut-down scenario at all, unless the motor is getting so hot that it fails.
If you are getting a temp warning on the ESC (both the F & R lights are blinking), you might actually want to try gearing up. This will lower the ESC temp (which has a sensor in it) and raise the motor temp some.
Also, try some less aggressive settings (lower punch and timing), and actually try less brake on the system. Brakes can do a good job of getting an esc hot, especially in a 4wd SCT.
FLHX1550 is offline
Old 06-18-2012 | 12:32 PM
  #4868
nikos2002's Avatar
Sewerdog- critters is a little track. Try the 12 maybe even 11. I ran 12 at island raceway last weekend ad my motor didn't reach fully rpm. I run between 3-5 on punch and timing depending on track conditions.
Old 06-18-2012 | 12:51 PM
  #4869
sewerdog's Avatar
Whats up bud , i didnt run it at critters yet but i will gear it down when i do. my issue was outside. can i change settings on the esc without the program?
sewerdog is offline
Old 06-18-2012 | 03:59 PM
  #4870
No9's Avatar
No9
All good now.
No9 is offline
Old 06-18-2012 | 09:44 PM
  #4871
nikos2002's Avatar
tdt - for what item? VTX series is 1 year. Copperhead 180 days. Let me know if it was something else.
sewer - there are 5 different profiles available to use without the progauge. Check out the instructions you will see they really differ from few different settings. ProGauge is a great buy, you can not only adjust your esc, but check radio modulation, test a servo and test battery. Sorry, saw Critters in your signature. I ran 13-14 at Motorama, which was really a 1/8 track with my 4x4 SC10.
No9 - does the switch show it has full power (solid red light)? If running in boost mode, make sure you start RPM is low enough. Also all the other fun things - connections good, battery chargered, sensor wires plugged all the way in.
Old 06-18-2012 | 11:29 PM
  #4872
No9's Avatar
No9
Yes it shows full power and all the connections are fine and the battery connectors are new.
No9 is offline
Old 06-19-2012 | 04:47 AM
  #4873
nikos2002's Avatar
No9- PM me with what settings you are running on the VTX, to try and diagnos what's up.
Old 06-19-2012 | 07:15 AM
  #4874
1/8 UPDATE PLZZ
Tim3 is offline
Old 06-19-2012 | 12:19 PM
  #4875
nikos2002's Avatar
Originally Posted by Tim3
1/8 UPDATE PLZZ
everything has been moving along as planned, I haven't heard of any major issues or ones that couldn't be foreseen. Waiting for the "pre-production" samples to make sure the production quality is what we expect -- everything is motoring as planned. I know the factory was "stress" testing the new motors last week. Would be interested to see what happens in those tests!!!
we are moving right along - but I know, its never fast enough when your waiting, right.....
