Viper RC -
#7248
sometimes you dont have a choice though. The tekin has tabs so you can directly solder, but some motors come with the wires exiting the case of the motor, and in the case of the VTX8 it has wires as well. no choice there but to use some method to connect the two.
#7250
i don't know much about the Copperhead ESC, but i know you can adjust the BEC voltage with the ProGuage on the VTX10 and 10R. you can set it even higher if you want to, up to 7volts.
#7253
I guess the bigger the better? The ESC wires are under 3mm, I just measured them.
#7258
I just picked up a Dex210 and was thinking of getting the VTX10R+motor+programmer. I have yet to decide on which motor but have it narrowed down to either the 13.5 or 10.5. I'm just looking for any help on where I should start with gearing should i go with either. I have the stock spur and 26,24,22,20,18, and 16 tooth pinions.
#7260
you can always throw some boost to it if you want more power/speed.
if you do run boost, then the 10R is not a bad idea.
the R is not needed, but it is just nice to have the R if you don't want to worry about heat. they seem to hold value a little better too.
4Likes
