Like Tree4Likes
Viper RC -
Old 04-02-2013 | 09:39 AM
  #7396
Originally Posted by rider313
What battery are you using and what motor are you using?
Also what is the LVC set at?
5400mah 50c SPC 2s & 6000 65-135C nano Tech 2s.
Motor Tekin Pro 4 4000kv.
Radio Futaba 4pl
servo savox 1258tg
LVC.. uh 3.2 ( 6.4 )? dunno whatever it defaulted to.
Nikkos PM sent thanks.
KTMDirtFace is offline
Old 04-02-2013 | 11:24 AM
  #7397
???E-Racer's Avatar
Hey lets just say im enjoying the Viper Copperhead R and 550 4500kv motor and esc combo in my 4wd SC10. No problems yet. Bought some street fighter street tires
so i can do pavement runs without tearing up my offroad tires.
Motor was barley warm after a 12 minute run. I can put my hand on it.
???E-Racer is offline
Old 04-02-2013 | 04:58 PM
  #7398
nikos2002's Avatar
KTM- check your PM. I answered before I saw your post. BTW, I was right about the one question I asked!!!!
Hope it helps. PM me with the answer.
nikos2002 is offline
Old 04-02-2013 | 06:13 PM
  #7399
I sent you a couple more PM's I don't think that is the issue.
However I just "fixed" it..( VTX 8 ) I turned my steering enpoints down to 60%( from 80% )... I dont have full steering now but the rebooting has gone away. I guess I will just keep bumping my endpoints back up to try to get full steering without it rebooting on me.
Old 04-02-2013 | 10:01 PM
  #7400
does the vlink for the computer link work with the viper copperheadr?
I used it and updated my v10s but when I connect to the copperheadr s I got it gives me it not the that type of esc. I guess what iam asking is their a version for the copperheadr esc or is it just programmable via the gauge box. which I have.
BIGDON18 is offline
Old 04-02-2013 | 10:45 PM
  #7401
nikos2002's Avatar
KTM, PM's answered - email sent.
BigDon - no there is no VLink for the Copperhead series, just the VTX series.
The VTX8 version is being finalized and sent to the website folks to post --- with some updates!!
Old 04-03-2013 | 07:58 AM
  #7402
Wildcat1971's Avatar
What is the difference between punch control and forward power? My guess is that punch limits the burst of power normally used from from a stop or slow speed when you get on it hard. Forward power is like an EPA for throttle?
Wildcat1971 is offline
Old 04-03-2013 | 08:01 AM
  #7403
DustinH's Avatar
You are correct sir
DustinH is offline
Old 04-03-2013 | 08:08 AM
  #7404
does anyone ever even adjust forward power on the esc? seems like epa would be better since you can do it from the driver stand if you really want to.
Old 04-03-2013 | 08:51 AM
  #7405
nikos2002's Avatar
Think of Punch Control as a torque control. Lowering it will help control wheel spin and the initial launch.
With Forward Power it is similar to the EPA as mentioned, that is the old way of doing it. Think if it like this. When you adjust EPA, you are messing with the throw of the throttle range, which could cause issues with some radios neutral point.
Old 04-03-2013 | 10:19 PM
  #7406
nikos2002's Avatar
Thumbs up
I am hearing the VTX8 page on the website is going to be updated in the next day or so...... interesting!!!!!!
Old 04-04-2013 | 06:31 AM
  #7407
DaveG28's Avatar
Hi, from the 2 posts is this a software change you guys are putting out?
Be interesting to see the changes....mine has run without skipping a beat, and nice and cool (120ish esc and motor after 8 minutes)...may avoid upgrading ha! Should older versions still work with the progauge?
One other Q, how do I reset a profile to factory settings? I have played with the profiles and on one esc would not mind going back to "stock"!
DaveG28 is offline
Old 04-04-2013 | 06:46 AM
  #7408
If you have the PC Link, you can reset them once they release the software. I dont think the PG has the ability to reset to defaults.
Old 04-04-2013 | 06:55 AM
  #7409
H0LESH0T's Avatar
So if you purchase the VTX8 is it recommended to buy the PC-Link and Progauge or can the PC-Link do all the adjustments the Progauge does?
H0LESH0T is offline
Old 04-04-2013 | 06:58 AM
  #7410
PC Link - Does everything but requires.... a PC
The PG - is the track side esc program box and lipo tester.
If you all ready take a lap top to the track or have no really need for track side tuning, just get the PC Link. Firmware can ONLY be done with the PC Link
