Like Tree4Likes
Viper RC -
Old 09-03-2013 | 07:00 PM
  #8896
silvalis's Avatar
Originally Posted by Motorman007
Can some post their VTX8 esc setup.
I just got the
Tekin 2050 motor
16 pinion
in EB48.2 buggy
I need a good starting point for a med. size track loose at times.
Thanx
I was at profile 1, 65% punch, 16000Hz throttle, 87% brake, 12000Hz, 7.4V BEC
15t pinion in an mp9e.
silvalis is offline
Old 09-03-2013 | 07:04 PM
  #8897
Motorman007's Avatar
Originally Posted by Bob Barry
profile 1, 16000 mhz throttle pwm, 60% punch.
Thank you sir..
Also, is there a way to put it back to factory so I can start over just in case I did something wrong? Like a Reset
Motorman007 is offline
Old 09-03-2013 | 07:46 PM
  #8898
BillyCaldwell's Avatar
profile 1, 80% punch, 95% brake and then turn it down in the radio with end points. 16k freq on the throttle linear throttle. 19/48 on a tekin 2050 on a d812 tekno v4. A61 I believe was the software version.
BillyCaldwell is offline
Old 09-04-2013 | 06:58 AM
  #8899
Thank you sir
Old 09-04-2013 | 07:14 AM
  #8900
SUPERLOOPER's Avatar
Originally Posted by Santi10721
Does anyone know if the VTX10 would be alright in a 4wd 1/10 buggy? Dex410v3 to be specific. I'd be running a 6.5t motor so it would be at its limit.
I run it with a 7.5 in my DEX 410 and it works great.
SUPERLOOPER is offline
Old 09-04-2013 | 07:19 AM
  #8901
I fried a VTX10 with a 6.5 in my DEX. I'd go with the R version.
Ivegotklas is offline
Old 09-04-2013 | 07:27 AM
  #8902
Maybe the 6.5 is too much for the setup then. My VTX 10 with a 7.5 after a 10 min main temped at 134. I am geared 22/87. I am running in blinky mode also. Do you guys have plenty of vents cut in the body?
Brian
Old 09-04-2013 | 08:04 AM
  #8903
silvalis's Avatar
Doesn't blinky actually generate more heat? Meant for stock motors, so delivers as much current as possible as quickly as possible?
silvalis is offline
Old 09-04-2013 | 08:21 AM
  #8904
Brian
Now I do. I even had a fan with the VTX10. I bought a Trakpower ESC to replace the VTX10. What a mistake way too many thermal issues. Should have gotten the R instead.
Old 09-04-2013 | 08:32 AM
  #8905
spider882009's Avatar
Running the Viper VTX10 and Viper 17.5.... I'm wondering how I can change this: When I pull the trigger there is about a 3-5 second lag where it spins slow the goes full tort. How do I change that intial punch??? Or do I have another problem.
spider882009 is offline
Old 09-04-2013 | 08:34 AM
  #8906
too many variables to give you a correct answer with out more info.
List your electronics first and then each setting for your ESC and then we can try to help
Bob Barry is offline
Old 09-04-2013 | 08:43 AM
  #8907
Thumbs up Thank You Bob
I'll get this put together when I get home. Have to hook it up tho the pro-gauge.
Electronics:
VTX10
Viper 17.5
Spektrum S6070 Servo
Spektrum DX3S Pro & S3001 Reciever
Racers Edge Glitch Buster
RevTech 100C 6900mah
Intalled in a 22SCT
Old 09-04-2013 | 08:48 AM
  #8908
I can't answer that. If so I am golden!
Old 09-04-2013 | 04:28 PM
  #8909
AndrewTom's Avatar
will we ever see Black Edition 540 motors?
AndrewTom is offline
Old 09-04-2013 | 04:54 PM
  #8910
This is nothing official, but I'm going to venture a guess and say not until next year. Simply because we are focusing on getting the 8th scale and 4pole SCT motors out there.
Rest assured that we will make the proper announcements when the time is right.
