NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 01-25-2012, 08:49 PM
  #7546
Originally Posted by olly986
35A with 3s in a buggy! not surprised it melted
The ezrun 35A's are rated for 3S as well. However in my case, the car was static (wheels not even spinning) and i was trying to push a heavy object with the car which resulted in a current overload and it killed a mosfet. I ran 3S for ages on those ESCs with no issues as long as you use a seperate BEC. Otherwise they will overheat and the green LED comes on flashing.
Clocked those buggies on 90km/h via a GPS
If i whacked my new xtreme stock ESC and motor combo in a buggy now, it would be insane...
Forgetful_Duck is offline
Old 01-25-2012, 11:19 PM
  #7547
Miholc's Avatar
Originally Posted by COBRARACING
you can run the x12's on any software from us as long as you dont go to aggressive on the esc settings and the adjustment of the x12 .
we have found that because the x12 has such a high degree of mechanical before you even add the dots that the esc will tend to go into sensorless mode .we have created new software the 930 mod and stock and the 508 and have adjusted the software for less sensor sensitivity but we cannot go lower as the sensor will eventually become useless .
conclusion dont go to crazy on the your settings and you will not have a problem running x12's
Thanks Angelo for your concern. I carefully read all of this and understand "problem" with X12 high mechanical timing.
However my problems were with the startup and loss of boost:
See post 7496.
Hope the 101224 will remedy this issues.
Miholc is offline
Old 01-25-2012, 11:39 PM
  #7548
CypressMidWest's Avatar
Originally Posted by dumper
Feel free to stop down and talk to Team CRC/Hobbywing drivers Brian Wynn (me), Frank Calandra and Mario Ficco for anything you might need.
dumper
Just ask Frank or Dumper. Mario is only helpful for spec truck oval info. LOL!!!
Nahhh, Mario's cool, and always good for a laugh.
Get it done CRC boys!!!
CypressMidWest is offline
Old 01-26-2012, 12:46 AM
  #7549
COBRARACING's Avatar
See post 7496.
yes alot of drivers say the 1224 is better for the x12's ,once michael is back ill be on conference call with him so we can make some changes to make sure the 930 stock relates to the 1224
COBRARACING is offline
Old 01-26-2012, 08:45 AM
  #7550
Trader Rating: 67 (100%+)
Thank you Cobraracing for answering my questions on 1/8th dirt oval. I think I will go with the 150 due to the massive amount of power being laid down on the track constantly in oval as opposed to off and on power on offroad.
nutz4rcyktw is offline
Old 01-26-2012, 09:39 AM
  #7551
send me an email to [email protected]
HI Angelo you got pm
big paul is offline
Old 01-26-2012, 11:01 AM
  #7552
Rick Vessell's Avatar
930 Stock is the fastest boosted software version for the Hobbywing.
Hobbywing is fast in Blinky too! I used the 120 amp 1s to win World GT and 17.5 12th scale at the Sweep Challenge at Middle River Hobbies this past weekend!
CRC has speed controllers in stock!! To order or if you have questions, log on to www.teamcrc.com, or call 315-338-0867. We will get you set up.
Also, Team CRC will be at the Snowbirds pitting down by the track, if you want help or just want to check them out. Feel free to stop down and talk to Team CRC/Hobbywing drivers Brian Wynn (me), Frank Calandra and Mario Ficco for anything you might need.
The hobby store at the Snowbirds will have Hobbywing speed controllers in stock.
dumper
Cool! Another reason for me to bug Mario next week.
Rick Vessell is offline
Old 01-26-2012, 11:45 AM
  #7553
Just ordered Hobbywing Xerun 80 Amp ESC, 2250 KV motor, and programming LCD.
Is there anything I need to do when everything is received other than setting the ESC to motor and radio. For example update the LCD box, update the ESC program? If so to what?
This will be in a 1/8th dirt oval car, running on 4S 5000 MAh 40C Lipo.
Probably dumb questions but the EZrun ESC that I have in my offroad buggy has never been changed in any way after initial set up.
Old 01-26-2012, 04:23 PM
  #7554
Trader Rating: 26 (100%+)
Guys. I loaded in sp software and now trying to load 930 in. It wont let me. I read somewhere that i need to reload 1.4 on the box first. This right and if it is can someone send me 1.4. Thanks
eddie10 is offline
Old 01-27-2012, 12:45 AM
  #7555
gogi108's Avatar
so 1.64 is still the latest firmware ? ive been using sp 303 stock but want to compare for myself if there are noticable difference between the companies . 930 is latest boosted , is this right ? cheers
gogi108 is offline
Old 01-27-2012, 02:57 AM
  #7556
Yes 1.64 is still the latest firmware.
http://www.hobbywing.com/product_show.asp?id=218
mcdoogle is offline
Old 01-27-2012, 03:16 AM
  #7557
gogi108's Avatar
cheers , got it done , but not wiyhout some problems . tried to change firmware from sp323stock to hw930stock but came up with unable to upgrade . i tried a few times with same result . i then went to 930mod no problems . i then went from 930mod to 930stock also no problem . has anyone else experienced this ? could it be that 323stock and 930stock are the same thing ? just a thought . cheers
gogi108 is offline
Old 01-27-2012, 12:29 PM
  #7558
Help
I have a120A Xerun 1s just updated the program box to V1.64 and then loaded the V3 no timing into the speedo all went ok it cam up loaded ok so shuy off and disconnected reconnected the spedo to the rec and now when I switch on I get a green light flashing on the speedo and 2 beeps fron a buzzer. What have I done and how do I undo it????? Need to race on Sunday
Bosscat is offline
Old 01-27-2012, 01:24 PM
  #7559
Originally Posted by Bosscat
Help
You need to disable the Low Voltage Cut Off in the 508 no timing software. It will work fine otherwise. A fix is coming Real Soon Now.
Shawn
Shawn68z is offline
Old 01-27-2012, 01:54 PM
  #7560
OK that is fine but how do I reconnect to the speedo I cannot get into it I conect the programming box it comes up connecting ESC and then the beep beep starts and I cannot get any further
Bosscat is offline
