NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#7396
I have a question for anybody:
This weekend a friend of mine's car took a big hit on the track. Afterwards the car would not run. The 1s was blinking the "low voltage code". I had loaded the v3 no_timing software in the esc earlier in the day so I hooked up the programmer box and it would not power connect to the esc. I then hooked the esc to a 2s battery and it worked but it was showing the mod software. I reloaded the no_timing and set the voltage protection to off as I had earlier in the day and everything was fine.
Just curious about the reset to mod. Has anyone experienced that before?
#7397
I was ruunning my TC last weekend with a 13.5 HobbyWing motor, final drive was about 6:1, I'm using 3300 Li-po's and I was only putting around 1500mAh back into them after a 5 minute run, usually with 3 or 4 warm up laps at the start as well. The track (asphalt outdoor) was nice and dry if a bit cold, (around 10 degrees C), but it is January in England! There was enough grip to make Sorex 24's comlpain. I'm no club champion, but I reckon your Nimh's will be OK if you don't get too greedy.
#7398
yes i have seen it before when the lcd box shows the mod software instead of the zero timing as the lcd box will appear to show any one of the 3 modes at anytime after a reset .i will talk to michael about it later todaY .
#7399
Any news on when the V3 is going to be out?
#7405
I have been a patient V2.1 user all last year and at christmas I could not be bothered waiting any longer for V3. I will still get one when they come out
I bet this is the date they have always been aiming for. Biggest event in Asia is not bad thinking but we are sick of waiting LOL
#7406
Does anyone know if there has been any word on the more advanced firmwares for the off road 150A ESC's?, there was a rumor last year, but it was ages ago now, even just some tweaks to make the firmware a little more advanced would be nice.
On that subject, what is supposed to be the latest firmware for the 150A Xerun?, I got one the other day, checked the firmware today, the software on my PC updated to a newer version, and I upgraded the firmware on my LCD, but the firmware on my ESC shows as being newer than any listed in the software.
#7408
#7409
Settings for Reedy 4T - TITC
Hi,
At the coming TITC in Thailand, I plan to run my HWv2.1 with a Reedy 4T.
Can someone recommend a good starting point for ESC settings?
Some of the low turn motor esc settings I have come across on this thread shows a very significant amount of boost and turbo timing. Are you guys running the stock software then with low turn motors? I believe the mod software does not allow so much timing to be added?
Sam
Sam
#7410
[IMG]http://i1179.photobucket.com/albums/x386/OwnIt-2-BeIt/Wonder-1.jpg[
