NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#7381
help
can someone point me to a setting with the HW and X12 13.5 motor when googling i come across allot of negatives with this combo however recently it seems that more people are finding a set up for it could someone please give me a successful starting point
indoor carpet track 30m straight thanks in advance
#7382
man, i need me some V3 action!!!
#7384
1/12, WGT, TC?....
If you ask for support, atleast give us important information....
#7385
Hi guys,
I will be racing for a first time at a carpet track Touring mod. category. My car is Serpent 411 and I will be using Hobbywing 120A 2.1 ESC with Robitronic 5.5t brushless motor(8450kv)
The track has 30m long main straight with technical infield. I dont want to put pressure on power system, so I dont want to use any sort of timing.
What can you guys suggest about FDR?
Regards
Regards
#7386
Hey guys.
need help setting up a SP 13.5 motor with a hobbywing xtreme stock ESC.
The track has roughly a 45 meter long straight with the infield fairly flowing with 1 maybe 2 slow corners.
At the moment my car is way slower than the guys with Tekins so I'm guessing my settings are just way off.
any help is appreciated.
#7387
Hey guys.
Try searching this thread for 13.5, there are plenty of set-ups here.
#7388
Most of the setups are for small carpet tracks so not really much use for me and there are too many pages to go through.
anyway below is my current setup
Motor: Speed Passion MMM 13.5
Software: 1.64 usb link with 110930STOCK
DDRS: 9
Boost Timing: 60 Deg
Turbo Open Time: 24deg/.01 sec
Turbo Timing: 40 deg
Boost Start RPM 10000
Turbo Open Delay: OFF
Boost Timing ACC: 500rpm/deg
cheers,
DDRS: 9
cheers,
#7389
DDRS: 9
cheers,
DDRS: 9
cheers,
I am running the same combo with the following settings
DRRS 7
Boost 42
Boost start 8000
Turbo slope 12
Turbo timing 12
Turbo delay 0.2 sec
ACC 500
FDR is 8.05
Have been trying higher FDR around 8 or so and playing around with boost etc
Car has quick acceleration and good but not great top end as yet so a bit more work to do yet
The higher FDR is keeping the temps lower as well
#7390
FW: stock 119
1: 1
Drag Brake : 0%
Voltage Prot: 3.2 V/Cell
DRRS Punch : 6
Brake Force : 100%
REverse Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 25
Turbo Slope : 18
Turbo Timing : 25
Start RPM : 6000
Turbo Delay : 0.3 s
Timing ACC : 550
FDR : 8
#7391
I'm no expert, but first thought is way too much timing happening there and bogging the motor down
DRRS 7
Boost 42
Boost start 8000
Turbo slope 12
Turbo timing 12
Turbo delay 0.2 sec
ACC 500
FDR is 8.05
DRRS 7
Boost 42
Boost start 8000
Turbo slope 12
Turbo timing 12
Turbo delay 0.2 sec
ACC 500
FDR is 8.05
Cool, thanks mate I will give that a go
#7392
MMM 17.5 and X12 17.5 recommendations
Hello I'm running an Xtreme stock with the latest boost firmware. This is our track layout at the moment.
http://youtu.be/2gpQC61hEbo
I'm looking for some recommendations on boosted settings for an LRP X12 and SP MMM 17.5 motor.
Thanks.
Thanks.
#7393
DDRS: 9
cheers,
DDRS: 9
cheers,
DDRS: 9
Boost Timing: 40 Deg
Turbo Open Time: 18deg/.01 sec
Turbo Timing: 20 deg
Boost Start RPM 2000
Boost Timing ACC: 250rpm/deg
FDR around 7.6
Make sure you have a fan, MMM's seem to run quite hot compared to the older V3's.
Cheers
Andrew
#7394
Can my Nimh 2000 mah 7.2v batteries feed this ESC with 17.5T sensored motor for full 6 min ? until i can afford lipos
spec are:-
Capacity : 2000mAh
Weight : 255g
Measured at 740mA (0.2C) discharge.
Max Discharge Current : 25,000mA (25 Amps)
Max Charge Current : 2000mA
spec are:-
Capacity : 2000mAh
Weight : 255g
#7395
Probably not but if your gearing is right and everything is running real free etc..it might just make it (depending how old are your packs too)
